07-29-2010, 10:06 PM | #31 |
Can you swith the units of measurement between standard and metric, or does it come programed with just one? If so, what does it come programed with?
Good looking product, especially for the price. I think this would nicely compliment other aftermarket gauges. Ex: you could have an aftermarket gauge for say, boost and water temp, that you really want to closely monitor, and the set this up for your oil temp and oil pressure on the side...I like this idea! Good job guys!
07-29-2010, 11:16 PM | #32 |
sorry for being stupid here... but just to clear things up, its NOT possible to run wtr temp, oil pressure and temp, fuel pressure and voltage off of one unit, I would need to run 2?
07-30-2010, 12:17 AM | #34 |
so, you get 2 gauges, AND a volt meter for 180 bucks, including sensors?? wow! I do think a better looking/ less bulky looking housing may be used and u would sell a bazillion. Gets my approval...
07-30-2010, 12:33 AM | #35 | |||||
All of the photos in the OP are photos of the actual display...but I did not take any of them. I'll do a professional shoot and install step by step like all our other stuff when they arrive in the USA. Heres a crappy low rez video of the screen I'll post a way better one later in HD Cant run 2 temps on one meter. Quote:
So how much more can I charge you for a CNC aluminum housing? Haha thanks!
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 08-04-2010 at 06:49 PM.. |
07-30-2010, 02:39 PM | #37 |
08-02-2010, 03:11 PM | #38 | |
Thanks!
08-02-2010, 04:12 PM | #39 |
possible to spl order but my stock arriving soon is all USA spec.
however theres a pretty easy solution google 1/8 BSPT to 1/8 NPT Fitting should cost $6, way less then spl ordering something from Japan.
08-02-2010, 08:47 PM | #40 |
i have some of those, however how would i use the temp sensor? i have not seen an adapter that will allow the probe of the temp sensor in.
08-02-2010, 10:22 PM | #41 |
Right. Not for the temp sensor. I'm sure we could get one for you. I'll look into the shipping and let you know.
08-03-2010, 03:58 AM | #42 |
Wow you guys are just coming along with all sorts of new products!!! If I didnt already have my important gauges I would seriously consider this!
08-03-2010, 09:37 AM | #43 | |
THANKS!!! msglngth
08-04-2010, 04:19 PM | #44 |
Japslapsilvia, Im sure we could get the temp sensor here for $30. For the pressure you'll want to use the thread adapter because its much more expensive to replace.
08-04-2010, 06:35 PM | #45 |
EVDM is In stock NOW!!!
...and its awesome! I'll post up a video running through the 6 display screens, 9 screen setup mode, 3 screen peak recall mode, 6 screen warning, and 4 screens of calibration mode (calibration is for advanced users only!). Install is super easy with plenty of included wire length: CAR SIDE is 3 wires ~12V+ ~Ignition ~Lights SENDERS are 2 wires ~Temp Signal ~Pressure Signal and common ground
08-05-2010, 10:30 PM | #50 |
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 08-06-2010 at 01:34 PM.. |
08-06-2010, 03:22 PM | #51 |
In-Person Impression!
Went to check out the EVDM in person today @ Parts Shop Max! I'm letting you know, it really impressed me. The measurements of the Digital Meter make it very compact and I was concerned about visibility issues with the screen being 1.1" The O.LED Display took care of any problems I had with the visibility. The lettering and numbers are Bright and VERY CLEAR to read. If mounted in the DIN tray, you will be able to read out the display clearly. I am definitely picking 2 of these up... next paycheck |
08-07-2010, 03:52 PM | #53 |
I agree, this is a bad ass unit. For that price you really really cannot beat it. Especially because it comes with all the sending units as well.
Hey Dan, does the oil pressure sending unit thread directly in to the stock port? So you could use just the sending unit for the EVDM in place of the stock sending unit for the dummy light? |
08-07-2010, 09:40 PM | #54 |
You may need something like this to use the stock location.
Auto Meter 2269 Auto Meter Extension Adapters & Fittings
08-09-2010, 12:19 PM | #55 |
Jap thread spec temp senders in stock now.
If you need the pressure sender adapted, cheapest method is the autometer link above. After you order the EVDM online if you need the 1/8pt-28 british pipe thread / Japan spec temp sender send us a separate email to request this non USA spec sender after you place your order.
08-16-2010, 05:48 PM | #57 |
You'll probably have them by the 20th
08-18-2010, 11:14 PM | #58 |
I hope Dan doesn't mind I'm posting pics in his advertiser thread (if you object, I will remove them)... but I found a decent place to mount the EVDM in my Chuki S13. The switch on the side is still accessible with a small screwdriver to toggle, even though... once you set it up, you don't really need to change it. Eventually I will get a second EVDM and use the right hand side as well.
08-19-2010, 01:32 AM | #59 |
Question (not sure if it was asked already, looked through the thread and it didn't seem like it):
Say I just wanted to monitor coolant temp and oil temp? Possible? Or can it only be one temp, one pressure for each EVDM? |
08-19-2010, 08:29 AM | #60 | |
It has already been covered, channels (1/2) are for Temp/Pressure. It cannot display both pressure or both temp. I am picking one of these up for my 510 This will be replacing my Autometer Mech. Oil Pressure guage, so i think its safe to say i can re-use the adaptor i have since i have the guage tapped into the stock Oil pressure sending unit location, correct? |
