Old 09-14-2010, 10:00 PM   #31
doyle4281
doyle4281's Avatar
doyle4281 is on a distinguished road
Update
During the disassembly of the rear suspension a couple of the eccentric bolts were damaged due to rust. Not needing eccentric bolts for alignment adjustments, as I am using adjustable arms, I needed to find compatible replacements. After some research I stumbled upon Ballerbolts.com, and my prayers were answered. Thank you Ryan
BallerBolts.com offers, not only eccentric bolt lockout kits for the 240sx, but they offer nearly every suspension bolt for the car. Aside from that they offer full SR20 engine fastener kits, titanium dress up kits, titanium suspension bolt kits, and much more. Every fastener far exceeds OEM strength, and cosmetically is not even comparable to old rusted bolts. These are a must for anyone wanting to take their build to the next level. Contact Ryan, and he will get you anything you need.
240SX Bolts, S13-Bolts
I purchased the full S14 suspension set, which replaces all of the rear suspension bolts, axle bolts, driveshaft bolts, and eliminates the eccentric bolts. They have 12-point heads, amazing zinc coating, and U-lock nuts.
Eccentric lockout
U-lock nut
Axle bolts, driveshaft bolts, tension rod bolts
A lot better than this, don't you think?
doyle4281 is offline   Reply With Quote
Old 09-14-2010, 10:15 PM   #32
Slikk Logic
Slikk Logic's Avatar
Slikk Logic is an unknown quantity at this point
dam fresh frame.i jus picked up my s14 from pa.its not that bad but i got this wierd click in reverse sounds lyk the frame moving
no success without excess
Slikk Logic is offline   Reply With Quote
Old 09-15-2010, 06:47 AM   #33
bb4_96
bb4_96 is an unknown quantity at this point
How much did full set of arms run you? The full set of hardware from baller?
bb4_96 is offline   Reply With Quote
Old 09-15-2010, 07:37 AM   #34
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
good job mans!! shit looks dope. definately have to see pics of this up under your car.
mattack69 is offline   Reply With Quote
Old 09-15-2010, 09:30 AM   #35
Edwin562
Edwin562's Avatar
too clean, u can just eat off it... keep the good work going
Old 09-15-2010, 02:39 PM   #36
doyle4281
doyle4281's Avatar
If you contact Donovan at Yamato Garage, he will be able to give you a quote. Contact Ryan at Ballerbolts.com for any bolt you can imagine. For the price, Yamato Garage products are unbeatable, and upon request can be coated a custom color. Ballerbolts are far superior to OEM in every way, and are cheaper. Any bolt that I need replaced I go to Ryan, and he helps me out. Make mention of this thread to either of them and they may just hook you up.
Thanks for all the comments, I will keep the updates coming......
Old 09-20-2010, 12:32 PM   #37
shinhed
shinhed's Avatar
shinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of light
One of my favorite build threads, despite the lack of a car.
My S13 subframe build was almost exactly the same except, Ballerbolts and Yamato didn't exist at the time.
Will definitely be using both their services when I begin my S14 tear down in October.
shinhed is offline   Reply With Quote
Old 09-20-2010, 04:08 PM   #38
doyle4281
doyle4281's Avatar
Thanks man, you did a great job on your subframe as well. I highly recommend both Ballerbolts and Yamato Garage products, not only for the price, but the quality. When you are ready, make mention of this thread, and they may hook you up.
As for the lack of car in the thread.....I wanted to make this thread dedicated specifically to the suspension, so the products that were installed were highlighted. Even though the rest of the car is too far along to start a build thread from the beginning, I will still be making a thread starting from the point I am at now......Thanks again for the comments
These are some old pictures of the car.....
http://zilvia.net/f/tech-talk/229178...25det-s14.html
Everything roughly in place.....
Old 09-22-2010, 11:36 AM   #39
schrapnel85
schrapnel85's Avatar
schrapnel85 is an unknown quantity at this point
Send a message via MSN to schrapnel85
thanks for making this thread,gave me alot of info and makes me really excited to do mine over the winter!
schrapnel85 is offline   Reply With Quote
Old 10-04-2010, 06:44 PM   #40
doyle4281
doyle4281's Avatar
My pleasure, I will be posting updates soon, which will include the rest of the rear and the front. Thank you for all the comments.
Old 11-23-2010, 08:30 PM   #41
Backintoans13
Backintoans13's Avatar
Backintoans13 is an unknown quantity at this point
Fucking sick shit, this is what im planning to do with mine, waiting on which links im going to go with so i can paint the subframe the same color. Great attention to detail man, updates??
Backintoans13 is offline   Reply With Quote
Old 11-24-2010, 12:03 PM   #42
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
why not go with aluminum subframe bushings ?
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 11-24-2010, 12:12 PM   #43
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
Originally Posted by eklips3 View Post
very nice , keep up the good work dude , everything looks clean.
i am learning from this
apparently you're not
He already went over that
Originally Posted by doyle4281 View Post
Thanks man
The flanges were only coated with a copper anti-seize compound to prevent corrosion. After dealing with that rusted disaster, I wanted to be sure I would not have problems like that in the future. Anything that is susceptible to rust, I apply anti-seize to.
I opted to install polyurethane bushings as opposed to solid because the car is not going to see enough track time to merit their benefits. For that very same reason, I did not fill the subframe with foam, weld supports, or other track preparations. I knew realistically that the benefits of those type of upgrades would were not going to be utilized.
Thank you for the comments, and I will keep the updates coming.....
dudermagee is offline   Reply With Quote
Old 01-03-2011, 01:23 PM   #44
schrapnel85
subscribed, any updates?
Old 01-04-2011, 06:35 AM   #45
doyle4281
doyle4281's Avatar
Sorry for the lack of updates, I am at work and school full time now. I will post more updates later tonight, thanks for the interest.
Old 01-04-2011, 07:14 AM   #46
hammy
hammy is an unknown quantity at this point
Nice work, tedious. gives me inspiration for my extra subframe i have.
hammy is offline   Reply With Quote
Old 01-04-2011, 11:58 AM   #47
RTB.1054
RTB.1054 is an unknown quantity at this point
Nice to see people take pride in their work I'm in the process of doing the same I have all the rear arms by circuit sports wanted to go with stance but couldn't wait to save some more money also stance diff sold bushings Z32 diff with axles (NA) that I will paint as well.hopefully it fits I will also do Z32 brake swap with E brake I got calipers powder coated,I just need rear subframe.
RTB.1054 is offline   Reply With Quote
Old 01-04-2011, 12:07 PM   #48
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
looks great man, not many people think about redoing the bushings when they do there suspensions hah its good you're doing it all in one shot though
Imarvin240 is offline   Reply With Quote
Old 01-04-2011, 05:04 PM   #49
doyle4281
doyle4281's Avatar
As promised, here are some more pictures from the rear suspension build. This portion of the build has actually been done for quite some time, so this post will take us right to the finished product. Thanks to everyone following along, and I will begin posting the front suspension next....
After test fitting all the suspension arms, to verify the fit, everything was disassembled for prevent damaging anything during the installation of the heavier components.
The red Energy Suspension subframe bushings were removed, in favor of the black, for cosmetic reasons only
The subframe was theN placed on jack stands, and then the differential was raised into placed. The factory bolts were used, however they were all bead blasted and powder coated.
Anti-seize applied
Next up was installing the rear Z32 Emergency brake drum assembly to the spindles....
The backing plates were acid dipped and powder coated gloss black...
The hubs where properly taped off, bead blasted and sprayed silver. I was hesitant to powder coat them, as I was unsure if the seals could handle the 500 degree temperatures.
The large hole in the spindle that the post on the drum assembly goes through needed to be opened up a bit, as the post would not fit. I am unsure if that was due to the powder coat or if it is normal with this conversion. I simply used a steeper drill bit and opened the hole until the post fit properly.
Of course, anti-seize was then applied....
The backing plate was then placed on the spindle, the drum assembly was secured to the plate by the springs, and the spindle was bolted through the back of the spindle.
Prior to installing the suspension arms, I applied and aircraft decal edge sealer. We use it at work to prevent decals from lifting off the airplanes at 600 mph.
The suspension arms and the spindles were then installed to the subframe...
The axles were then slipped into the splines in the hubs, and then bolted to the differential using the BallerBolts.com fasteners. The axle nut is then torqued, the retainer and cotter pin are installed. The axles are different lengths, the driverside being the shorter of the two, from what I remember.
I will cover the braking setup, at a later date, but when all is said and done, you end up with something like this. Thanks to Donovan at Yamato Garage, and Ryan at BallerBolts for offering such great products. Subscribe to see the rest of the build. Thanks
Old 01-05-2011, 03:03 PM   #50
boyou2
boyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura about
awesome
great job
boyou2 is offline   Reply With Quote
Old 01-05-2011, 07:04 PM   #51
RTB.1054
Very nice, I found a subframe that I'll be bringing back to life. Please post alignment specs when you get to it.
Old 01-05-2011, 07:57 PM   #52
doyle4281
doyle4281's Avatar
Thanks guys. As far as the alignment goes, I made a jig to accurately measure the length of the OEM arms, and adjusted the Yamato arms to the same length. I wanted to have a drivable baseline, so I could drive the car to get an alignment.
Old 01-05-2011, 08:10 PM   #53
doyle4281
doyle4281's Avatar
These are the wheels that are going on the car. They are Work Emotion XD9's that have been custom coated by Work. The XD9's only came in a matte silver (MGS) finish, however I really wanted more of a gunmetal finish. I contacted Work and they agreed to coat them in their matte gunmetal (MGM) finish for an additional cost. It took 6 months, but they came out great.
18x9 +20 Front/ 18X10 +18 Rear
245 Front/265 Rear
Old 01-05-2011, 09:11 PM   #54
M11's
M11's's Avatar
M11's is an unknown quantity at this point
what are those type of bolt ends called, eccentric? why did you choose over regular hex bolts
M11's is offline   Reply With Quote
Old 01-06-2011, 03:20 AM   #55
schrapnel85
great job again, keep it up! looking forward to the front suspension!
Old 01-06-2011, 06:23 AM   #56
doyle4281
doyle4281's Avatar
All of the suspension bolts are from BallerBolts.com. They are zinc plated, 12 point head, and far exceed factory strength. The fasteners for the upper control arms and toe control are eccentric lockouts. Since they control arms are all adjustable, there is no longer a need for the eccentric adjustment. These fasteners were one of the components that motivated me to go the extra mile with the rest of the build.
Contact Ryan at BallerBolts.com, make mention of this thread, and he will help you with whatever you need
Old 01-06-2011, 08:07 AM   #57
MIKE-240sx
MIKE-240sx is an unknown quantity at this point
subframe looks sick keep up the good work ! what part # are those es bushings for the spindles?
1992 Nissan 240sx Project
MIKE-240sx is offline   Reply With Quote
Old 01-06-2011, 08:22 AM   #58
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
all this work and still keeping stock wheel studs?
onehundredoctane is offline   Reply With Quote
Old 01-06-2011, 05:46 PM   #59
doyle4281
doyle4281's Avatar
I was considering changing them to longer studs, but I had already purchased the closed face lug nuts. I may install longer studs in the future if needed.
Old 01-06-2011, 11:07 PM   #60
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
^I think your RUCAs are backwards.... they typically point down so they don't hit the pinch weld in that area. Yours are pointing up.
Also I said it before but I'll say it again. Those ES bushings that go in the spindles/LCAs SUCK. They create a ton of stiction so the suspension cannot travel as easily even when well greased (the grease only lasts 2 months max anyway). You end up feeling everything in the road like it's train tracks or something. I could not move my suspensioin at all by hand when I had the shock disconnected and ES bushings installed.
If you have the money sphericals are a far superior option (the sphericals do wear out quicker but replacements are only like $10 each and they slide right out of the housing for easy replacement). If not i'd try to source some OEM/nismo bushings.
