Old 07-22-2013, 02:53 AM   #31
roushman90
roushman90's Avatar
roushman90 is an unknown quantity at this point
Originally Posted by jeffwiggins View Post
What would be the difference in modifying the dust plate or bending it as to getting a manual trans plate I haven't had luck with finding a manual plate and am Doing the swap today
Well I'm super late but for late reference you can either just use the auto dust plate and let the manual flywheel grind down the part that rubs on first start basically, OR you can get the proper dust plate. ORRRRR, you can get the proper dust plate! In any case, not too big of a deal.
roushman90 is offline   Reply With Quote
Old 12-11-2013, 07:25 PM   #32
91240coupe
91240coupe's Avatar
91240coupe is an unknown quantity at this point
Did you use the stock auto ecu or used a manuel ecu?
91240coupe is offline   Reply With Quote
Old 12-12-2013, 06:44 AM   #33
S13 nerd
S13 nerd's Avatar
S13 nerd is an unknown quantity at this point
I used auto ecu, you have to run the jumper to make the car think it's in park but it was easier to me
90 s13 hatch
S13 nerd is offline   Reply With Quote
Old 12-12-2013, 10:50 AM   #34
91240coupe
91240coupe's Avatar
Sooo using a manuel ecu is optional?
Old 12-13-2013, 02:26 AM   #35
S13 nerd
S13 nerd's Avatar
Yeah, with manual ecu you need to wire in a neutral safety switch in order for the car to start. With auto you basically jump out the park switch to where the car will always think that your in park
90 s13 hatch
Old 12-28-2013, 05:22 PM   #36
91240coupe
91240coupe's Avatar
What about the starter? I heard they are different or something like that.
Old 12-28-2013, 05:32 PM   #37
S13 nerd
S13 nerd's Avatar
Never had to change mine
90 s13 hatch
Old 12-28-2013, 06:02 PM   #38
91240coupe
91240coupe's Avatar
Alright thanks.
Old 01-03-2014, 08:32 AM   #39
91240coupe
91240coupe's Avatar
What the lower harness for the tranny? Am i gonna need that?
And by doing the swap is it gonna affect the mph? Spedo?
Old 01-03-2014, 10:18 AM   #40
S13 nerd
S13 nerd's Avatar
You have back up lights and all that, I just hooked up the the speed sensor but I haven't seen a difference in mph, there might be a slight difference
90 s13 hatch
Old 01-04-2014, 01:57 PM   #41
91240coupe
91240coupe's Avatar
So to wire up the reverse lights its just as simple as getting a new wire and hooking it directly to the reverse light?
Old 01-04-2014, 02:07 PM   #42
S13 nerd
S13 nerd's Avatar
I believe so, my plug was done for and I needed to get the car up and running for work so I had to do it quick
90 s13 hatch
Old 01-04-2014, 02:16 PM   #43
91240coupe
91240coupe's Avatar
Aahhhh ok i see. youre like the only one that answers my questions haha.
Old 01-04-2014, 03:06 PM   #44
S13 nerd
S13 nerd's Avatar
Yea most people on here will tell at you to search I'll just help the best I can haha
90 s13 hatch
Old 01-04-2014, 03:33 PM   #45
91240coupe
91240coupe's Avatar
Yupp. did you use this write up?
Old 01-04-2014, 03:48 PM   #46
S13 nerd
S13 nerd's Avatar
Yeah, it's the best one I could find really
90 s13 hatch
Old 01-04-2014, 04:03 PM   #47
91240coupe
91240coupe's Avatar
Oh ok yeah same here this is the only one i could find thats really good.
Old 01-06-2014, 01:18 PM   #48
91240coupe
91240coupe's Avatar
For the clutch pedal to the clutch master cylinder. The little rod part could i just use a bolt n a nut for it?
Old 01-06-2014, 02:11 PM   #49
S13 nerd
S13 nerd's Avatar
You can, but you can also go to any hardware store and get a pin anything that will fit in the slot and not lock up
90 s13 hatch
Old 01-06-2014, 02:26 PM   #50
91240coupe
91240coupe's Avatar
hmmmm... I see ok.
Old 01-07-2014, 05:33 PM   #51
S13 nerd
S13 nerd's Avatar
I used a cotter pin
90 s13 hatch
Old 01-08-2014, 10:07 AM   #52
91240coupe
91240coupe's Avatar
I used a cotter pin
Got a picture? And how long did it take you to do the swap?
Old 01-08-2014, 12:28 PM   #53
S13 nerd
S13 nerd's Avatar
I'll take pics when I get home from work today took like half a day
90 s13 hatch
Old 01-08-2014, 12:51 PM   #54
91240coupe
91240coupe's Avatar
Half a day for the swap? Damn. I was expecting a day or two
Old 01-10-2014, 12:29 PM   #55
S13 nerd
S13 nerd's Avatar
What all did you want pictures of?
90 s13 hatch
Old 01-10-2014, 12:41 PM   #56
91240coupe
91240coupe's Avatar
The rod holding your clutch master and clutch pedal. Where they connect.
Old 01-20-2014, 10:54 AM   #57
91240coupe
91240coupe's Avatar
What about the diff? do i need a manuel diff or its the same.
Old 01-20-2014, 05:23 PM   #58
S13 nerd
S13 nerd's Avatar
Dif is the same, just a standard Nissan open diff
90 s13 hatch
Old 01-27-2014, 02:14 PM   #59
blackrms13
blackrms13's Avatar
any tip on removing that auto pilot bushing? Seems like it's made of carbon steel or some kind of really hard material
rented the tool from Autozone, there isn't any spot for the bushing to grab onto...
Tried grinding it down, but not exactly working yet. Maybe I need a different tip
Chisel - didn't really work
Drilling - broke a bunch of tips, I think the tips are not for metal
Don't really want to use the grease/bread method
Now I'm left with this:
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 01-27-2014, 09:30 PM   #60
S13 nerd
S13 nerd's Avatar
I used a slide hammer the catches the lip on the back of the bushing
90 s13 hatch
auto, conversion, manual, s13, swap
