Old 07-08-2011, 01:18 PM   #31
BNASTYs13
BNASTYs13's Avatar
Trader Rating: (50)
BNASTYs13 is an unknown quantity at this point
Feedback Score: 50 reviews
Send a message via AIM to BNASTYs13
no.....
the deciding factor for HP in ANYONES setup is their weakest link. whether it be injectors,maf, turbo, cams, or what they are tuning on... This guys got 550cc injectors and a piggyback thats only good for a 50% fuel over lap. he needs to ditch both of these if he wants to get more out of his turbo setup. you can throw a t67 on a fullllly built SR and if you have 550cc injectors your WONT make more than 350-380whp safely period. the injectors will be running static.
all in all you have a nice little setup man. if you want more than 350whp id get some nismo 740cc and a pfc/nistune/ems
BNASTYs13 is offline   Reply With Quote
Old 07-11-2011, 05:17 PM   #32
Kingtal0n
Kingtal0n's Avatar
Originally Posted by HYPNOTIK View Post
Do you guys understand that on a turbo car the turbo is basically the deciding factor in how much power your gonna make? You can have 5 different setups with different injectors, different ECU's, different brand of cams, etc. and a good tune with the same turbo on all of them and you're gonna get pretty similar results. Just look up a compressor map of the turbo your using and you can guess ballpark power figures.
ALL that matters when making peak power is how much your turbocharger can flow, and will the engine handle that flow with the fuel type selected.
everything, including fuel, is up the owner to supply. We are only SUPPLYING the necessary fuel, though. It is not "making the power", peak power comes from peak airflow, properly used.
Old 07-11-2011, 05:29 PM   #33
herbieS13
herbieS13's Avatar
herbieS13 is an unknown quantity at this point
Send a message via AIM to herbieS13
not to thread jack or anything but i also just got a new tune
SR20
BC 2.2 Stroker
BC 264 cams
BC valvespring retainers
Greddy Intake manifold
Circut Sports Sidefeed rail
Tomei 740cc Injectors
Denso Supra Fuel pump
Sard FPR
Precision SC3431 turbo
made 430.3whp @18psi
power curve suggested my motor was begging to goto 8000k but i dont trust stock lifters enough
herbieS13 is offline   Reply With Quote
Old 07-12-2011, 12:35 AM   #34
Kingtal0n
Kingtal0n's Avatar
SR20
BC 2.2 Stroker
BC 264 cams
Sard FPR
Ive never even seen a BC stroker kit in use. Do you have any pictures of the parts, the assembly, or any information about what was done to make them fit (modifications to the block) and any information about the balancing needed?
And posting specs like that without posting pics or vids is pointless. Its just numbers watch I can do it too
RB30DETT Stroker kit, 280 duration camshafts oem lifters
8,500rpm E85
Garret GT42 1.06 a/r turbocharger custom in house manifold
Chevy powerglide transmission 4,000 stall with Trans-brake
OEM S15 Differential
940~ RWHP @ 38psi boost
Old 07-12-2011, 03:37 PM   #35
BNASTYs13
BNASTYs13's Avatar
Trader Rating: (50)
wow what a shitty made up setup.......
a twin turbo RB30 with only one turbo and and an automatic chevy transmission.
Old 07-12-2011, 03:59 PM   #36
fatduece
fatduece is an unknown quantity at this point
Lol. You want to hit 400 with Co-g@YMETIC and neo? Talk about no reliability.
fatduece is offline   Reply With Quote
Old 07-13-2011, 06:42 PM   #37
Kingtal0n
Kingtal0n's Avatar
I know right! what was I thinking, lets change that,
RB30DETT Twin Garret 67 Trim turbochargers
And lets make it a Th400 Chevy trans (yay for 3 gears)
better?
