#31 | |
#32 | |
![]() Quote:
And I was assuming zilvia was mature but i think I got called high off my ass like 5 times. And to those that call me stupid... It's crazy look at my name. To the op. I have had a turbo with messed up fins like yours maybe mine was a little worse but barely. I just cleaned out the little specs and continued on for about 8 months when I decided to upgrade. It stayed the same. No more shaft play. Perfect bearings. And i also have had a turbo t25 that had a broken fin and I didn't know till i upgraded to tge t28. So I've ran two bad turbos and they both spooled perfect. And I daily drove them about 800 miles a week. Sad to think this forum doesn't take posts from people that just signed up because if they are new they must be high |
#33 |
![]() Join Date: Dec 2002
Trader Rating: (50)
![]() Feedback Score: 50 reviews
well yea this forum is full of.....no comment...
people come here for advice and help not to be bashed on...lol
"get that nacho out of my face" |
#34 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
#35 | |
Trader Rating: (58)
Either way, I think you gave solid advice...while it wasn't the normal answer it was sound IMO.
#36 | |
when i replaced my chra i went with these guys Turbos Direct LLC – Authorized Garrett Distributor because they were over $150 cheaper than atp for the same service.
#38 |
those "FLAKES" arent really flakes. Like I said im 99.9 % sure the previous owner had this happen on him. They are chips in the housing. Whatever he sucked in really bounced around for quite a while. My plan is to remove the turbo soon and inspect everything. I need to replace the exhaust manifold gasket anyway, I still hear a small leak coming from it. The only part that sucks is all the bolts/studs on the turbo and any exhaust pipe are spot welded on..otherwise It would have been off this past saturday
#39 |
![]() Join Date: Jul 2011
They welded the bolts to the flanges? That sucks since they are already a pain in the ass. Good luck, hope it all works out.
#40 |
It's common to find that since the turbo tends to vibrate and break loose the nuts. Thus creating a exhaust leak between the turbo and manifold. Nissan tended to this issue on the z making turbo locking plates which are only like 10 bucks but if your not specialized in them you wouldn't know so the common thing to do is put a nut on and spot weld it a little the the stud so it doesn't vibrate and back off.
It's a mechanics trick and is a bitch to work with after. Most likely you'll need new studs so buy them first before you take it off and wont be able to put it back on |
#41 |
The Sr came with the same tab style locking plates. The reason most don't have them is because they break and are too cheap to buy new ones and do it the right way. That's where the "mechanics" trick comes in. As far as the downpipe nuts, they should be replaced after a few uses because the "crimp" that comes on them wears down or away and no longer "locks" on the threads.
#42 | |
Trader Rating: (58)
![]() In regard to the downpipe nuts and using the deformed thread, you would need to check their heat tolerance, as most deformed threads will loose their locking ability under intense heat unless you get the good ones. I learned my lesson with that ![]()
