Old 10-12-2011, 01:25 AM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
Two built engines (RB25det and Mazworx sleeved SR20det) and TONS OF OTHER PARTS!
1. NO BASHING PRICES OR PARTS! if you dont like it, please leave!
2. If you PM, please also bump the thread.
3. Im always adding more parts and pictures to the thread, so check back every so often.
4. More parts have been added as of...10-12-11
I don't need to sell the engines and parts, I am only doing it to speed up my other projects...so don't bother lowballing me.
Mazworx SR20DET Engine- I WILL NOT PART OUT THIS SR!
HEAD-
New SR20DET Head- $500
Stage 2 Port and Polish- $800
Polished Combustion Chamber- $210
Full Radius Valve job- $200
Tomei Intake Cam Gear- $200
HKS Exhaust Cam Gear- $200
Tomei Solid Lifters- $280
Tomei 270 Cams- $600
Brian Crower Springs and Titanium Retainers- $220
Supertech Valves- $300
HKS Rocker Arm Stoppers- $100
SR20DET Powder Coated Valve Cover- $150
Greddy Oil Cap- $80
New Muli-layer Exhaust Gasket- $80
New Cam Angle Sensor- $330
New Rocker Arms- $150
BLOCK-
SR20DET Redtop- Cost of a core block- $100
CP Pistons 86.5mm 9.0 CR- $525
Golden Eagle Sleeves- $375
Manley Turbo Tuff Rods- $725
Calico Coated ACL Race Bearings- $210
ARP Main Studs- $185
Balanced & Polished Crankshaft- $200
ATI Crank Pulley- $425
Greddy Oil Pan- $300
New Water Pump- $65
New Oil Pump- $375
Upper Oil Pan- $50
Sleeving- $280
Bore/Hone- $320
Whatever I Forgot- $X
TOTAL= $8,535.00+
ASKING= $5,000 OBO if you disagree with my price, either make an offer or go have Mazworx build you the same engine and see what the price ends up being.
PHOTOS:
RB25DET Engine- I will part out some of this setup now, due to my friend needing some of the parts.
R33 Rb25 series II~15k miles since rebuilt- $2,000 obo (just with the arp, tomei hg, and new bearings it is about 800 in parts)
Arp head studs
Arp main studs
Tomei triple metal head gasket
Greddy intake manifold w/ q45 tb- SOLD!
Greddy exhaust mani ceramic coated- $850
Precision 5557 t3 t4 turbo- $650
Mcckinny mounts- $300
Rb20 trans- $200
Competition stage 4 6 puck clutch- $300
Has 4/6 spitfires that come with it- make offer
Waisted spark assembly- make offer
rb25 to s13 Engine Harness w/ ecu- make offer
rb24 to s13 driveshaft- $250
6 370cc injectors- $150
OTHER PARTS
TurboSmart Megasonic Blow Off Valve
- ~1-2k miles
- $150 + shipping
Kisuu Custom Made Fuel Rail
- NEVER USED
- $150 + shipping
S15 Hoods
- NEVER USED
- $250
ETS Custom Made Intercooler 24X8X3
- NEVER USED
- PERFECT SHAPE
- $175
Greddy Intake Manifold Modifide and Comes w/ Q45 (90mm) Throttle body
- Roughly 500 miles
- PEFRECT SHAPE
- $600
Unknown Brand BOV
- Slightly Used
- PERFECT SHAPE
- $50
ROSS TUFFBOND Water Pump Pulley
-ONLY MOUNTED
-PERFECT!
-$100
S14 SR20 88.5mm Cometic Metal Head Gasket multilayer
- NEVER USED
- PERFECT SHAPE
- $70
OEM SR20VE Valvetrain (IN+EX Valves, Springs, Cams, Gears)
- 15,000 Miles
- PERFECT!
- MAKE OFFERS ON WHAT YOU NEED!
S14 Non-ABS Driveshaft
- Used
- $120
S13 Non-ABS Driveshaft
- Used
- $120
S13 SR Transmision - SALE PENDING
- Roughly 30k miles
- PERFECT SHAPE
- $150
These are all the make an offer items...i dont want or need them all so just make an offer...pictures of these upon request...its to many pictures for the thread.
S13 SR OEM Coil Pack Cover
BNIB SR Multi Layer Exhaust Gasket
BNIB OEM SR Exhaust Gasket
SR OEM Exhaust Manifold w/ Heat Shield
(1) V1 Godspeed S13 Toe Arm
(1) V1 Godspeed S13 Traction Rod
Valve Cover Gasket
Valve Cover Coil Plug Gasket
Water Outlet
Water Inlet
(4) Cam Oil Tubes (2 Sets)
(16) OEM Spring, Retainer, and Keeper (1 set)
(8) SR OEM Intake Valves (1 set)
(8) SR OEM Exhaust Valves (1 set)
(8) SR OEM Rocker Arm (1 Set)
(8) SR OEM Lifter (1 Set)
SR Block (bare) w/ 87mm bore (needs align bore...roughly 200 at any machine shop)
SR20 Front Cover w/ Oil Pump
(2) Oil sandwich plate Galley w/ sensor
(2) Upper Oil Pan
(2) Water Pump
Water Pump Pulley
(3) Rear Crank Case Cover
Crank Pulley
(4) SR Oil Squirters (1 Set)
(3) SR OEM Rod
(4) Upper Oil Pan Screen (2 Sets)
(3) Different SR20 Timing Chain Guides
(3) SR Timing Chain Tensioner
(2) SR Main Cap Girdle
(2) Alternator Bracket
AAC Valve
(3) Knock Sensor
(3) Coolant Tubes
(2) Thermostat Housing
(2) Coolant Temperature Sensor Housing
3” S14 Exhaust that was very hacked up but it has a Very good condition HKS muffler
Turbo Blanket (was on a T67)
SR Transmission Plate
SR OEM Turbo Lines
S13 Rear OEM Chamber Arm
S13 Rear OEM Traction Arm
S13 Rear OEM Toe Arm
stock KA24de fuel pump (in working order)
stock KA24de header + stock heatsheild
stock KA24de airbox intake system and Filter is still clean
Summit Liquid Fuel Pressure Gauge
Thank You For Looking!
https://instagram.com/eck_matthew/
Imarvin240 is offline
