![]() ![]() ![]() CALL 239-540-6385 OR 804-690-2452 and mention BILLY to receive special pricing ON ZILVIA!!!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() **COILOVERS NOW HAVE A BLACK COATING TO PREVENT RUST** Zilvia, We are now the Master Dealers of Fortune Auto coilovers! **Join their Facebook page!** Fortune Auto's Facebook Page Fortune Auto | Facebook All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification. Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers. Features: * Dyno tested*** * Stainless steel body / piston * 30-way adjustable dampers * Pillowball mounts * Forged aluminum locking collars * Dust boots on all pistons * 50mm piston (beyond the industry standard of 44-47mm) * Anodized aluminum camber plates** on front upper-mounts * Fully anodized body * 1 year Manufacturer's Warranty * Height adjustment independent of preload * ISO 9002 certification Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() THEY GO LOW! ![]() ![]() ALL FORTUNE AUTO COILOVERS CAN BE UPGRADED WITH SWIFT SPRINGS FROM THE FACTORY!! HELPER SPRINGS ALSO AVAILABLE! Add $375 for Swift Springs! OR Add $475 for Swift springs with Fortune rear helper springs! Add $500 for Swift springs with Swift rear helper springs! Spring Upgrade? Why Swift Springs? Swift springs of Japan noticed that most spring manufacturers use old silicone chrome material, which is not strong enough for automotive springs. Other manufacturers use a heat tempering method that damaged the strength of the material that inevitably require more coils, in turn, more weight. The material was also suffering from a shortened life span. With springs like this leading the industry, Swift saw massive room for improvement. Swift's R & D team created material, called H5S.TW, which is stronger then regular silicone chrome material. Because of this material, Swift could make the spring wire thinner, and could wind the springs with fewer coils, which greatly decreased weight while dramatically increasing available stroke. Helper Assist Springs: Assist springs have two functions. The first is the spring adds a progressive rate to the initial portion of the stroke. This progression can add increased comfort is used on a daily driver coilover setup that has stiff springs installed. It provides racers added softer spring rate progression. Once the assist crushes, the normal spring rate will take over. The second job is the same as helper springs. They prevent the loss of traction during rebound, and extreme cornering. Assist springs are designed to repeatedly be fully crushed. Every assist spring crushes to the same height. That allows drivers to change assist springs without resetting the spring perch on coilover without changing ride height. ![]() ![]() ALSO INQUIRE ABOUT OUR DRAG SPEC OPTION!! ![]() CUSTOM RATES AND VALVING AVAILABLE FREE OF CHARGE! ![]() Multiple Time Attack Winning Fortune Auto Evos! ![]() ![]() ![]() Introducing the NEW Fortune Auto Dreadnaught series! ![]() Fortune Auto Dreadnought Series features: Street-able track suspension Inverted Mono-Tube damper with high pressure nitrogen housing Swift springs standard Helper springs standard Titanium fasteners standard Dyno tested Rebuild-able Revalve-able Assembled in the USA Dyno tested Oversized digressive 50mm piston Italian IP synthetic shock oil Compression adjustable Forged Aluminum mounts and top hats Height adjustment independent of pre-load 1 year warranty Applications: Evo 8 Evo 9 Evo X S13 S14 S15 E36 E46 S197 Mustang EP3 Civic FC RX7 B15 Sentra Porsche 996 Subaru GC8 (all years WRX & STI) Subaru GDB (all years WRX & STI) Subaru GDF (all years WRX & STI) Toyota Yaris ![]() ![]() |
