Old 01-29-2012, 02:20 PM   #1
Knapik
Knapik's Avatar
Trader Rating: (36)
Knapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to all
Feedback Score: 36 reviews
PART OUT!: Weld JP s14 Silvia Track Car...Officially!
PARTS ARE NOW AVAILABLE FOR PICK UP!!!!
this is just a quick list of things. if there is something not specifically listed and you see it on the car or know it is there please pm me. i will try and update regularly.
Prices DO NOT include shipping, or paypal fees.
I do not mind shipping, but please expect to pay for shipping.
ENGINE: $7000 obo picked up
Nissan 2.0L SR20DET
Block Bored 1mm Over
Balanced Crank
Trust TD06 20G Turbo
WELD Machined/Polished Head
WELD Spark Plug Cover
Trust Wastegate
Trust Exhaust Manifold
Z32 /300ZX Pistons
A'PEXi Camshafts
A'PEXi Cam Gears
A'PEXi 1.1mm Head Gasket
A'PEXi 550cc Fuel Injectors
A'PEXi Fuel Pressure Regulator
JUN Water Pump
Engine Related:
Z32 /300ZX MAF with Air Intake: SOLD
A'PEXi Catalytic Converter: $500
Trust Oil Cooler $650
Skyline R33 Fuel Pump: $200
Sun Automobile Hot Earth Hyper Ground System: SOLD
Sun Automobile Hyper Voltage System: $80
Shrouded Dual Flex-A-Lite Fans Located In Trunk: $250
Trust Profec B Boost Controller: $250
Trust Digital Speed Meter: $150
EXEDY Stage 4 Twin Plate Ceramic Clutch Kit (Flywheel Included): $1200
S14 SR transmission: $250
Nismo SSS Differential. $700
SUSPENSION
Zeal Endless X Coilovers: $2500
Ikeya Formula Tension Rod: $260
Ikeya Formula Tie Rods: $100
Ikeya Formula Tie Rod Ends: $300
Ikeya Formula Toe Rod: $200
Ikeya Formula Traction Rod: $200
Ikeya Formula Rear Camber Arm: $650
Ikeya Formula Front Lower Control Arms: $600
Ikeya Formula Rear Lower Control Arms: $600
Custom Weld Front Strut Bar: $250
WELD Custom Strut Tower Brace: $200
WHEELS
AME Circlar Spec R 17x9 +15 front 18x10 +15 rear $1500 w/ out tires $1800 with tires
TIRES
Yokohama Advan AD48's
AERO PARTS
Full Vertex Aero: $1200
A'PEXi Extreme Adjustable CF Wing: $1200
Craft Square CF Mirrors: $350
Forward-Tilt Vented Hood: $1400
Vented Trunk: $600
Lexan Front Windshield: $600
Lexan Rear Windshield: $600
Lexan Rear Quarter Windows: $150 each
Lexan Door Windows (driver and passenger side roll up and down also): $350 each
INTERIOR
Sparco 'Stripe' Pedals: $60
Sparco 'Globe' Shift Knob: $60
Sparco Racing 6 pt Harness: $250
Greddy Guages SOLD
Greddy Link Control Unit: SOLD
Oil Pressure: SOLD
Oil Temp: SOLD
Boost: SOLD
Water Temp: SOLD
Fuel Pressure: SOLD
Exhaust Temp: SOLD
Autometer Pro-Comp Tachometer - 5" 11k RPM limit: $165
Still Updating...theres just an overwhelming amount of hi quality parts
In case the pictures do not load please follow this link to the photobucket....it seems that the pictures are getting a good amount of views, and you are limited to how many times by photobucket.
http://photobucket.com/WeldS14
not anti-drift, just pro-grip
Knapik is offline   Reply With Quote
