Old 06-20-2012, 10:11 AM   #31
Lost8lives
Lost8lives is an unknown quantity at this point
Originally Posted by Guilty1s View Post
S14... I'm also gonna be figuring out the wiring based on that one writeup and hopefully improving it for others. Also I'm hoping to flash ecu myself with Osiris. Was gonna do mounts myself and resell some, but 210 bucks ain't bad.
I'm thinking they are exact copies of mcminney.
I did the wiring my self i did plan on doing a write up as well. but i was waiting to get it to start befor i did so. they told me at UpRev that only the Pro tuner softwear could delete the NATS. the $700.00 Tuner softwear will not do it other wise for $700.00 you could steal any 350Z or G35. I had the same plan.
John at Z1 motorsports did my ECU Reflash and NATS removal for $300.00
any wiring questions feel free to ask.
Lost8lives is offline   Reply With Quote
Old 06-20-2012, 10:26 AM   #32
Guilty1s
Guilty1s is an unknown quantity at this point
Word... I was waiting to hear back from uprev to answer that question. Looks like I'll be making another trip down to Z1. But I love those guys.
I'll definitely be looking for your help for wiring in a week or so. If you wouldn't mind, pm me your number if you don't mind texting about it.
Guilty1s is offline   Reply With Quote
Old 06-20-2012, 11:06 AM   #33
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
You're just missing painting something white. . . then you'll have a patriotic colored engine.
onehundredoctane is offline   Reply With Quote
Old 06-22-2012, 03:40 PM   #34
dorrifto
dorrifto is an unknown quantity at this point
Very nice brackets!!!
I got my shifter bracket from zfever and the reverse lockout is non existent. The shifter is in its lowest position all the time. Super annoying. But after looking at these pictures, I think I should be able to weld up a plate on the bottom to solve that problem
dorrifto is offline   Reply With Quote
Old 07-11-2012, 06:59 PM   #35
Lost8lives
Ok VQ swap installed wiring done. Will not start . No spark no fuel. I am wonding if the shop I sent the ECU to took the NATS out I am not throwing any NATS codes but am throwing a lot of other codes I am throwing a code for everything else 16 codes in all Any ideas ?????
Old 07-12-2012, 02:19 PM   #36
Guilty1s
Hmm... What codes are they. Who did the flash?
Did you do anything about engine grounds. You will need to add a few. And to the chassis.
If its not simply ground or main power, I'd say it is probably definitely nats. There isn't really anything we modify in the swap that would prevent the motor from firing unless you just straight up wired the wrong wires in.
Old 07-12-2012, 02:20 PM   #37
Guilty1s
Is the fuel pump coming on or is it just injectors?
Old 07-12-2012, 06:56 PM   #38
Lost8lives
Fuel pump is coming on
Old 07-12-2012, 07:13 PM   #39
HIGHFIVEBETA
HIGHFIVEBETA's Avatar
HIGHFIVEBETA is an unknown quantity at this point
Black and red painted chain covers and black and red axis wheels?? nice build but it could go a better direction with the touches...
HIGHFIVEBETA is offline   Reply With Quote
Old 07-18-2012, 11:15 AM   #40
darkroom1428
darkroom1428 is an unknown quantity at this point
Any luck on getting the vq started? What are your codes? Before I sent my ECM to uprev to get a flash to remove nats I decided to install it and tried to start my vq. There was no spark and the codes I was getting were p1564, u1000, p0183, p0462, and p0447. With the stock ECM installed and after doing a throttle relearn I was able to make sure the electronic accelerator pedal worked.
darkroom1428 is offline   Reply With Quote
Old 07-18-2012, 11:48 AM   #41
dorrifto
+1 on this.
Best to send the ecu (send it back? Sorry I only partially read the comments) in to have the nats removed, and send the peddle with it. A few of the shops I talked to REQUIRE the peddle when you send the ecu to them.
Old 07-18-2012, 11:57 AM   #42
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Where did you send your heads to?
SLiDe_WaYz is offline   Reply With Quote
Old 07-18-2012, 12:19 PM   #43
Lost8lives
Bill @ National Engine & Transmission here in Abilene
Old 07-18-2012, 12:20 PM   #44
Lost8lives
still no start but it looks like i do not have it wired in right
Old 07-18-2012, 05:23 PM   #45
darkroom1428
I could help out with wiring. What make, model, and year is your harness and ECM? Oh and was the harness auto?
Thanks
Lee
My 06 G35 auto harness had these connectors and made it slightly confusing for me to wire up the vq.
Old 07-19-2012, 08:59 AM   #46
Lost8lives
Thanks
Lee
i have a 04 350Z M6 harness and ECM i have not worked on it in a few days i have been studying the FSM and have found some things i did not wire in yet that need to i plan on working on it this weekend hopefully and fixing it . i am having trubable with the ECU relay and i need to wire in the throttle motor relay.
Old 07-19-2012, 07:45 PM   #47
Lost8lives
Well she finally gave it up and fired off today. So so happy
Old 07-21-2012, 11:13 PM   #48
eZiR- rps13
eZiR- rps13 is an unknown quantity at this point
awesome! wiring write up soon?
What the Math!?!
Originally Posted by Og Bobby Johnson View Post
hustle hard
eZiR- rps13 is offline   Reply With Quote
Old 07-22-2012, 06:12 PM   #49
Lost8lives
i will do one but i want to make sure i have it all right first
Old 07-22-2012, 06:41 PM   #50
Lost8lives
ok it will run and revup and idel... then i cut it off try to start it again and the throttle motor is not working cut it off clear the MIL codes and back to normal next time same thing ???
I think it may have to do with the fact that I dont have the trottle motor (or ECU) Relay wired in (just running them both right to a hot wire) but i cant get em to work I tryed wiring em in. I put the ECU relay in and wired it to wire 111 in on the ground side of the relay but i dont think that it is supplying ground. If I ground the ECU relay wire out on the body the relay clicks tryed wiring a relay in for the throttle motor to the ground on wire 104 and same deal i can only guess that the ECU is not getting ground but I have all the ground wires that i know of grounded????
Old 07-22-2012, 07:32 PM   #51
Lost8lives
this is how i am wiring the ECU relay in. any help or suggestions please?
Old 07-27-2012, 10:43 PM   #52
40flash
40flash is an unknown quantity at this point
I'm having the exact same problems. The car is ready to go but won't start. 2004 350Z wiring loom and ecu flashed by National speed. I did the wiring myself very close to Dudewutup. I've gotta believe that National speed did it right since they also did Dudewutup's ecu and it works.
No spark. No fuel pump although when I wire the pump directly to 12V to test the pump it works just fine.
It's like the ECU won't energize anything. Not sure what to do next.
Contemplating my options.
1. Getting a Nisan tech guy over here to look at it but they may not have experience with this swap at all. Not sure how important that is.
2. Sending the wiring to someone and having them trouble shoot the loom to see it the problem is there.
3. Flying someone with experience here to look at it with me.
What do you guys think? Best option is?
40flash is offline   Reply With Quote
Old 07-28-2012, 09:21 AM   #53
dorrifto
Break out the factory service manual and make sure all the wires and sensors are in the right spot. When I first did my mil spec plugs and wire tuck, I wired two of the cam sensors backwards and that gave me no fuel/no spark. After fixing the sensors, it started right up.
Old 10-09-2012, 09:27 PM   #54
Lost8lives
Gremlins
Car is running (sometimes) I even drove it around the block
But have a lot of Grmlins to work out. Will have pics and parts list up soon
Old 10-14-2012, 10:17 PM   #55
40flash
ECU relay
[/IMG]
This isn't my first attempt to post a picture on a forum but if it works it would be the first successful attempt.
This is the way the 240sx relay needs to be wired for the VQ swap. I wanted to post it so nobody coppies the relay wiring above.
Old 10-14-2012, 10:21 PM   #56
40flash
Drat -- I still can't post pictures. Not bad with mechanical things like cars. Not so good with computers. Sorry.
If you want the relay schematic, PM me and I will send it.
Old 10-23-2012, 07:28 PM   #57
Lost8lives
Update
did this all 4 months ago trying to back track and get the thread up to date wilh the car
Well it took me over 4 months to get all my parts from Chase Bays for there VQ 240SX fuel line kit. and then it did not fit and did not come with evey thing you need like it says on the web site. Big fat waste of money. Buy some -6AN Braided SS line get like 30 feet for the return line and feed line then some left over for you power steering line i wil get to the power steering later in the thread.
I used a Fuel Lab FPR you will need
-6AN Male to Male union fittings X3
-6AN Fuel filter x1
-6AN 90 deg. Female to Female fitting x1
-6AN 45 deg. Female hose end x 2
-6AN straght hose fitting x2
-6AN to 1/8" NPT 90 Deg. Male To Male
-6AN Fuel Rail Delivery Adapter for SR RB
this is best found on Ebay you can get it with a 1/8 NPT barb or a straight 1/8 NTP to -6AN Male but it hit my fire wall that is why i have the 90 deg. fitting listed above
buy this stuff and evey thing will fit good (better then me) and save you money and time i got every thing off Ebay
for now i bent the stock hard lines to come up threw the small opening in the side of the fender next to the wiper motor i will replace the hole line with -6AN soon i do not like the fuel line being next to the pass side header
this is the part that Chase Bays sent after 4 months
i know i could have made this fit but i did not like the idea and for $18.00
i could get somthing that fits right and looks better
i did not use this this tube just used it to show the fitment i put the adapter on the back off the fuel rail
I pulled my fuel take to get all the Old Crapy 87 Octane out
New daily 2011 2SS got it with 4k on it. it had never been sold. it was a pace car at Texas Motor Speedway
cut mufflers off they weighted 40ib each
sorry i know this is not a Camaro forum....
Old 01-22-2013, 02:07 PM   #58
rloera12
rloera12's Avatar
rloera12 is an unknown quantity at this point
Any updates!?
rloera12 is offline   Reply With Quote
Old 01-22-2013, 03:20 PM   #59
Lost8lives
update or lack thereof
I do believe i know what is wrong with my car. I am real close to having this thing on the road. However, with the holidays and then right after Christmas i was in a bad wreck and am OK I still am not getting around to good and do not feel like working on the 240. I will get going again in the spring when it is not so cold and am feeling better.
sorry
Old 01-22-2013, 03:32 PM   #60
rloera12
rloera12's Avatar
Sorry to hear about your accident man :/ hope all is well and that ur getting better. I will be eager to see ur finished project because so far everything is looking great post some pics and a video when done! Btw nice camaro
