Hey Heartwork, is that your friends S13 in the back ground? the one w/gold SSR's? Do you have the specs on those? SSR Reverse Mesh doesnt come in gold from at least what their website says, any info on this? pls let me know, tia
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
um..when the front 215/45/17 are slightly under front fender..it rubs. juuuust barely. a 3mm spacer should clear it ok. i only had a 5mm front lindsay hanging around.
#5 |
car: s13
Wheel: Advan Oni Wheelsize: 16X8 +12 front 16X8 -1 rear Tire size: 205/55/16 Bridgestone Potenza RE01 fitment modifications: Pull fender a tad probably didn;t even need it since im running a lot of negative camber -3 mm spacer all around just cuz i had them laying around Coilovers: yes Brakes: have not tried but most likely no on all 300zx brakes and maybe on Q45 sliding calipers |
#8 |
OMNOMNOMNOM
![]() Join Date: Dec 2000
Here are my front BBS RS 17x8 +35 235/45/17 - Will clear Z Brakes as seen, will not clear Coils without 5mm spacer or SUPER small tires.
Here are the rear's BBS RS 17x9 +35 - 255/40/17 - which arent on the car right now. Im waiting to get a alignment and finally set my camber so they dont stick out like this. They will fit fine with the right camber setting, right now id imagine the fuggers are set to like +3 camber ![]() Ill update pictures once I get the alignment. Last edited by West; 05-07-2004 at 10:56 PM.. |
#9 |
![]() Join Date: May 2003
maybe this thread should be stickied for people to look at when deciding on wheel choices, that way the enevitable question "will this fit" wont happen nearly as much
#11 |
![]() Join Date: Jan 2003
I have a 5 Lug S13.
I roll daily on S14 SE's. 16x6.5 +40 with 205/55ZR16 Kumho's For drift, I use my R32 GTS-T's, 16x6.5 +40 with 205/55ZR16 Falkens Both wheels clear my 30mm Z32 brakes and both clear coilovers, without spacers for brakes or coils. |
#12 |
Volk Racing CE28N
17x7.5 +25 215/45/17 Barely tucked in 17x8.5 +30 245/40/17 Flush Haven't tested it, but I'm 99.9% sure it will clear z brakes. It clears my kei office gu coils. I'll post pics when I upload them from my camera. |
#13 |
Enkei Mesh... 15x7 0 offset word up
-Austin ![]() My name is Shake-Zula, the mic rulah, the old schoolah, you wanna trip, I'll break it to ya. Frylock and I'm on top rock you like a cop, Meatwad you're up next with your knock-knock. Meatwad make the money see, Meatwad get the honeys G. Drivin in my car, livin like a star, ice on my fingers and my toes and I'm a Taurus. Cause we are the Aqua Teens, make the homeys say ho and the girlies wanna scream. |
#14 |
on strike three.
![]() Join Date: Mar 2003
oh yeah, i forgot the picture with mine...this was 17x9 +15 with wide body fenders..i think they needed a spacer and i would have wanted more camber because in my opinion they were still not flush enough..if i had it to do over again i would have stuck with stock fenders or i would have spaced them out at least another 5mm:
![]() Last edited by nokeone; 01-27-2004 at 12:22 PM.. |
#16 |
![]() Join Date: Mar 2002
Volk SuperFine Mesh
16x7 front +35 16x8 rear +38 ![]() ![]() Will clear c/o but will not clear z-brakes w/o 10mm spacers They do not have the JDM uber flushness
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP |
#22 |
front : Buddy Club P1 16x7.5 +22 225/45/16 yoko es100
rear : Weds Sport Fins 16x8 +23 245/45/16 yoko es100 clears 26mm z brakes by a mile and coilovers. rolled rear fenders needs alignment ![]() ![]() |
#23 |
Junkie
17x8 +35 wheels all around
215/45 tire did not rub in front but my new 235/45's do. This is on TEIN S Techs and KYB AGX. Pretty sure they will clear Z brakes since Mark has the same spec wheels and clears. But, I'm 100% sure they clear q45 brakes. I had to remove the lining inside the front wheel well and move the wiring that runs inside wheel well because the tires were eating it. SO, one piece of plastic removed and a ziptie later no more rubbing. Here's a pic of how the wheel looks like on the backside.
-Juan |
#24 | |
![]() Join Date: Sep 2001
![]() ![]() ![]() Feedback Score: 7 reviews
Thanks, Art N |
#26 |
![]() Join Date: Apr 2002
17x8 +30 17x9 +35 Hoshino Impul RS3
235/40ZR17 265/40ZR17 ES100 Clears most coilovers if you run a 5mm spacer or down size tires to 225 width. Clears my s15/z32 brakes no problem I like my quote its hilarious.
2003 G35 sedan, 03 m45, 06 S2000 |
#27 |
![]() Join Date: Jul 2003
5-zigen fn1r-c bronze... 17x8 +27 / 17x9 +35 235/45/17 & 255/45/17 hankook tires..
this pix was before my car was dropped.... looks so high..~ i have stock brakes and tokiko blue shocks.. i think wheels can go out a little more... |
#28 |
15*7 +5 205/55/15 clears coilovers but not even stock brakes up front. Rear clears brakes and coilovers, need to roll fenders or mucho camber to clear fenders (f/r).
15*8.5 ~+20 205/60/15 clears coilovers and brakes rear, probably won't clear anything other than coilovers front. 16*8 +36 205/55/16 clears brakes f/r clears coilovers R but needs 5mm spacer to clear coilovers front. Fenders no problem.
Instagram: @SX180HKG |
#29 |
hmm....im running stockos alloys on both cars
hmm....i think imma need a five lug swap to get access to some of those nicer wheels....
-Kevin Z31T s13 hicas |
#30 |
Super Advan SA3R 17"
http://members.shaw.ca/typh00n/47.jpg
CA18 is the only way to go! ![]() |
