Old 04-09-2012, 08:10 PM   #1
TheBlaiant
TheBlaiant's Avatar
TheBlaiant is an unknown quantity at this point
s13 TheBlaiant's I need money to buy an S30 sale!
UPDATED: 4-29-12
New Items!!!!
3055881300 for the quickest response
All parts in Norfolk, va
Ok I got alot of stuff to sell. Here goes.
Q45 brakes with AP stainless F+R lines
$250 for everything plus stock parts.
SR stuff:
S13 Inlet and outlet $30
S14 Outlet $15
S14 T28 wastegate $30
S14 SR oil feed and coolant lines $20
KA stuff:
Front cover and oil pump. Has some chaffing from the timing chain.
$20
Upper timing cover
$20
r
Fuel rail with injectors, missing some hardware.
$20
T-stat water neck
$5
Oil fliter block with a good oil pressure switch.
$10
Block to trans Brackets
$20
Clean ass dip stick.
$5
Alternator bracket and tensioner
$20
Rear main seal housing thingy
$5
Water pump pulley
$5
S13 Single cam Maf $20
2 S13 MAF's one with a fucked up connector.
$20 each
S13 KA valve cover $20
S13 KA cams SOLD.
Sprocket $5
Clean ass S13 KA head
$60
S13 stuff
Apex'i N1 Has a hole from srapin' but you can just patch it
$100 plus stock parts
DOHC P/S Res $20
DOHC Throttle cable $20
S13 electric Fan $20
Side mirror covers for power
$10
KA24E #10 ECU ONLY
$20
Other stuff:
Brand new Knock sensor $40
TPS $10
Clutch forks
$5 each
Also got a PBM shift knob base. i got the steel one so I have a spare aluminum one in case anyone stripped theres.
$10
240's are money pits.
TheBlaiant is offline   Reply With Quote
