#31 | |
They are the DMAX Dual position light / winker. with the 2 bulbs in the housing. not oem replacement ones. I already had Origin ones to replace the oem ones. I found a relay that plugs into the factory harness under dash locally, it allows led turn signal's at a normal pace vs rapid blink. |
#32 |
![]() Join Date: Nov 2010
just got my dmax in..im confused why does the actual light housing have holes for 2 sockets? i thought the harness does both? or can you just put it in either one?
#33 | |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
The OEM harness/position lights are not dual function. DMAX is dual function. Two sockets = two bulbs = dual function = DMAX 180 lights. Wire another light into your harness. Dual function. |
#34 |
I thought it was plug n play they came with one socket one harness one bulb for each.. I thought with the dmax you didn't have to any wire other sockets or anything
#35 | |
They made two models. ![]() ![]()
![]() Last edited by KiLLeR2001; 09-25-2012 at 12:43 AM.. |
#38 | |
never mind
#39 |
Sorry to raise an old thread, but just wanted to check and make sure that the Circuit Sports 180sx position lights will work fine for easily having them function as turn signals as well as position lights.
I don't mind running normal style bulbs or only using the included LED's for the position lights. I don't want fast blinking. And so the bulb sockets that come with the Circuit Sports dual bulb 180sx position lights are for normal 921 bulbs? Thanks for the help. I'm planning on running the kouki 180sx factory turn signals as fog lights. Figure I'll just wire them up in series with the fender side markers to stay totally out of the turn signal wiring neck of the woods.
#40 |
This modification works only if you have LED bulbs. Will not work with regular incandescent bulbs, dual filament or not.
However, with the LED bulbs you will have fast blinking. Add the resistors if u want normal speed blinking. |
