Old 07-03-2012, 07:41 AM   #1
iJDM
iJDM's Avatar
iJDM is an unknown quantity at this point
Clean RB20DET engine part out. all internals, harnesses, lines, etc. *cheap prices*
Update: 2/04/2013 bump from the dead, all parts are still available. I have another S chassis so trades will be considered. Feel free to make an offer, ask questions, etc. All parts are in great condition and ready to get your RB running. Will trade for sr parts, s13 coupe parts, 4 lug rims, etc.
Contact: Mike @ 410-330-1138 (text prefered)
Prices are all OBO and don't include shipping. (but I will ship items that are reasonable at your expense)
Located in Baltimore, Maryland.
Here's the main stuff I know I have:
Engine block- Comes with all hardware. Was taken to a machine shop and honed, it is in fantastic condition - $150
Lower Intake manifold- with all sensors and hoses, also comes with fuel rail and injectors - $75
Upper intake manifold- comes with throttle plate and all other hardware - $50
crankshaft - SPOTLESS - $60
Cams- with cam gears - $50 for both or $30 each
pistons with connecting rods- labeled 1-6. includes connecting rod nuts - $75 for all or $20 each
All 24 valves with springs and retainers labeled intake/exhaust along with number- $100 or $10 each
coil packs with hardware and harness- $75 for everything
Engine harness, no spliced connections- $100
IACV- $10
oil dipstick- $5
timing belt- $10
timing tensioner - $15
turbo down pipe hardware- $5
coil pack bolts- $5
oil pan bolts- $5
transmission bolts- $10
turbo/exhaust manifold hardware- $5
lower intake hardware
oil pump hardware-$5
cam angle sensor with cover- $15
ngk spark plugs- $10
ignitor with hardware-$15
spark plug cover with plate- $25
Both valve covers- comes w/ valve cover screws- $50 for both or $30 each
oil cap, good gasket- $2
Oil filter w/ gasket - $2
water pump with pulley- $25
oil filter housing - $10
motor mounts-$20
This is just a little of what I have, if you need something feel free to ask. All parts are OBO. The more you buy, the cheaper ill give it to you for. I need everything gone. Make offers.
If I don't answer I'm at work and ill get back to you asap. Thanks
1990 s13 hatch sr20det
2001 Lexus is300
Last edited by iJDM; 02-11-2013 at 12:54 PM.. Reason: bump from the dead, added pic.
iJDM is offline   Reply With Quote
