Old 08-07-2012, 10:02 PM   #1
Huntsman2007
Banned from the Marketplace
Huntsman2007 is an unknown quantity at this point
RB25 series 2 partout
Parting out my old rb25.
Bottom end lost compression in 2 cylinders, cylinder 1 and 5 only pulled 90 psi. Bottom end just needs to be honed and new pistons/ rings. Crank and rods are all still good. Looking for 200 obo
assembled head with cams- 125
cas- 50
Nissan quest alternator with bracket- make offer
2 rb25 s2 turbos, one is coming right off my new swap, no shaft play, no oil leaks. the other is off my old swap, no known issues, I put it on right before the motor decided to call it quits
8 370cc rb25 injectors, will sell as a set or individually
i have everything but ecu and wiring harness for sale. full set of coils, etc, if you need it, just ask. Pics coming soon
s2000 seats- pretty decent shape, drivers seat has more wear than passenger, comes with s2000 rails $450 obo
CAS
Turbo off of new series 2, unused in perfect shape
Tps sensor
coil cover
Rb25 alternator, will bench test before sale to ensure it works 100%
Rb25 ac compressor and bracket
rb25 s2 coils and coil harness
rb25 s2 head (other cam included its just not pictured)
Turbo #2 im not sure if its series 1 or neo, but it works like a champ, its just dirty
rb25 power steering pump
rb25 series 2 short block
cylinder 1
cylinder 5
turbo inlet pipe
Anything else, just ask. Ive got a stock replacement clutch with 3,000 miles on it, every little engine part, injectors, fuel rail, blah blah blah. Most stuff is best offer, so dont be scared to throw an offer out!
Huntsman2007 is offline   Reply With Quote
