12-19-2012, 11:23 AM | #32 | |
Headed down to southern cali this friday to pick up a bunch of aero parts and maybe another project car as im in the middle of another s13.5 rb25 project. |
12-31-2012, 01:37 AM | #33 |
Just got back from a 40+ hour road trip. Didn't keep me from trying to finish my turbo manifold. If it wasn't for my material supplier I would have finished it today...
Found a cool short clip on youtube someone made, working on getting more footage from the guy who made the video. http://www.youtube.com/watch?v=qWxWbKMoIqU Last edited by MC.Understeer; 12-31-2012 at 09:32 PM.. |
01-01-2013, 01:44 PM | #34 |
who did your cage?
Check Out My S13 Build |
01-01-2013, 06:50 PM | #37 | |
One more pic to stay on topic with your build.
01-01-2013, 07:44 PM | #38 |
You're better off getting a pre bent kit online and adding to it. Otherwise you're gonna spend tons of money for someone to do everything by hand. We're getting a tubing bender at my shop to do a new tube front end on my car and Nikolays FD car. Id make my own cage out of raw materials but id rather get a basic kit then add to it. Im running out of time as is. I don't want to spend more house bending tubing and measuring ect...
01-02-2013, 12:46 AM | #39 | |
what wheels are these???? |
01-04-2013, 02:47 PM | #43 | |
01-08-2013, 10:26 AM | #47 |
fuck me,..im doing so many things wrong
cONtRol FReAkS |
01-11-2013, 09:43 AM | #52 |
Thanks! I was actually just down at extreme dimensions from Seattle about 3 weeks ago buying a bunch of s13 and s15 aero parts! This Skyline is prolly the least nicest one I've owned out of the 5 I've had.
01-14-2013, 05:16 PM | #54 |
tightfit!
01-14-2013, 11:49 PM | #55 |
Cut some wires out of the harness lol
Got her all wired up pretty quick, just need to make it look all nice and tucked away. Need to figure out which turbo I want to use :P |
01-15-2013, 02:35 PM | #58 | |
I just marked all the plugs that im not going to need before I pulled the wiring off the motor and then cut everything open and cut each wire out one by one. Pretty easy, doesn't take much to run the motor. Most of the wires are for injectors and coil packs. Pretty basic, luckly I have my lower harness wired in from my RB so I just need to connect it to the 2jz starter and all my gauges are aftermarket including my apexi tach. |
01-15-2013, 08:58 PM | #59 | |
I'm also running all aftermarket gauges and my own custom relay/fuse box and rewired the whole car with what I need, so that should make it easier to wire the engine up. Quick question What are you doing with the coolant line at the back of the head that goes up( not the one that goes across right on top of the trans)? |
01-15-2013, 11:34 PM | #60 | |
Yeah im not using the twins so I don't need any of those solenoids. Im not sure about that line as im not running a heater box/core. Still need to look into it. Id like to block it off but not if its going to cause any cooling issues... |
