Old 07-01-2014, 10:59 AM   #31
70ina30
70ina30's Avatar
70ina30 is an unknown quantity at this point
Originally Posted by blueshark123 View Post
A+ for effort but go get a newer dash. What u tried doing came out terrible no offense and then with all those ricer gauges everywhere doesnt help.
Thanks for the A.
First build just going with what feels right.
Next time there are a few changes I may tweak.
70ina30 is offline   Reply With Quote
Old 07-01-2014, 02:44 PM   #32
70ina30
70ina30's Avatar
not much to do today as im waiting on Mr UPS.
i did prep the crossmember for the new mounts.
removed old KA mounts and cleaned the surface.
didnt quite line up
drilled out a bit
perfect
installed but not tightened down yet.
probably gona need some wiggle room when installing
removed craptastic carbon fiber looking graphic and preped spark plug cover
bought some cheap ass place mat material
testing out best way to do this
not too bad. im still not happy with it, so i may do it again..
Old 07-01-2014, 03:00 PM   #33
1GR-FE
1GR-FE's Avatar
1GR-FE is an unknown quantity at this point
Pretty creative solution with the foam for the pattern. Some people may not like it, but those are the types of things that makes a car yours. Keep up the good work!
1GR-FE is offline   Reply With Quote
Old 07-01-2014, 03:02 PM   #34
70ina30
70ina30's Avatar
Thank you. Trying to "do it myself". While now on a budget with the baby on the way.
I know rb25 build and budget dont realy go together lol
Old 07-02-2014, 12:07 PM   #35
70ina30
70ina30's Avatar
Worked on the harness today
laid it out to see what i need to work on.
its not much as the longest part past the rubber seal, was all for the engine.
since i bought the car as a shell it didnt have an ecu or engine harness to mess with
this is the plug that has been posted that needs to be modified
it is a direct fit into my 95 240sx base
this can be done indoors in the nice cool air
looking up the wiring diagram online to write down all the wire codes
now im going to use the rb25-s14 guide that has been posted about which wires to move where on this M63 F3 plug!
Old 07-02-2014, 07:43 PM   #36
70ina30
70ina30's Avatar
All done repinning. Now to tape up
Got some goodies today.
New z32 fuel filter and new fuel line
Old 07-03-2014, 10:17 AM   #37
PLAYERO_LOKO
PLAYERO_LOKO is an unknown quantity at this point
nice build brother! keep it up!!!
PLAYERO_LOKO is offline   Reply With Quote
Old 07-03-2014, 05:10 PM   #38
BossHogg
BossHogg's Avatar
BossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really niceBossHogg is just really nice
http://www.youtube.com/watch?v=watch?v=B2C5GaQPP0o
BossHogg is offline   Reply With Quote
Old 07-03-2014, 05:13 PM   #39
ksuberk54
ksuberk54 is an unknown quantity at this point
Yeah, I would have gotten an actual carbon fiber piece, hydro dipped it or just painted it black or blue. Either way, nice progress!!!
2006 Black 350z - K&N, Megan, Motordyne, Nismo, SPC, Tanabe, XXR
ksuberk54 is offline   Reply With Quote
Old 07-03-2014, 06:22 PM   #40
70ina30
70ina30's Avatar
More parts.
Freddy intake
New ex gasket
Old 07-05-2014, 11:37 AM   #41
70ina30
70ina30's Avatar
removed all peices from intake to prep the new one
all done and installed
as welll as exhaust side
Old 07-05-2014, 01:43 PM   #42
70ina30
70ina30's Avatar
F!! I lost the damn water pump pulley....
Anyone have a spare? Anyone whos rb25 did an upgrade to aluminum pulleys. Ill take your old one please
Old 07-05-2014, 03:20 PM   #43
ksuberk54
Nice work. I see you decided to paint it all blue.
Old 07-05-2014, 03:32 PM   #44
70ina30
70ina30's Avatar
Yeah wasnt happy with the other paint job. Still not
Gona invest in a nice cover eventually
Old 07-06-2014, 08:26 PM   #45
70ina30
70ina30's Avatar
Found one from a member. Thanks again jc
Old 07-21-2014, 05:26 PM   #46
70ina30
70ina30's Avatar
update.
got some more work done and more parts too!
stage 2
old one out
new one on
back together
going in. lol
halftime for my amigos
and she is
[IMG]http://i1286.photobucket.com/albums/a612/blacks_350z/20140720_174956_zpsaaf27d6f.jpg
[/IMG]in
Old 07-21-2014, 08:59 PM   #47
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
-you are better off getting a r32 or cefiro x-member
-you should just remove those valve covers and replace those gaskets.
-did you change your REAR MAIN SEAL?
-you should just replace that stocker turbo with a holset hx30-35
supersayianjim is offline   Reply With Quote
Old 07-21-2014, 11:44 PM   #48
70ina30
70ina30's Avatar
Stock 240 x-member + zero lift mount kit + rb25 rubber mounts = great fit.
All the parts lined up. Sits low and back.
Even clears the steering rack
Gaskets..... check
Rear main seal..... check
As for turbo, stocker for now. Not sure after that.
Old 07-29-2014, 07:19 PM   #49
70ina30
70ina30's Avatar
Btw here are my notes from using rb25 ecu pinout guide to configure the f3 plug that needs to be changed
Final f3 configuration looking at the plug from the backside
Old 07-29-2014, 07:27 PM   #50
70ina30
70ina30's Avatar
Front mount and radiator in place. Waiting ona few more parts.
Old 07-29-2014, 09:30 PM   #51
jr_ss
A suggestion for you, remove those fans and get a shroud that covers the entire radiator, not just the 12" where the fan is. You're car will run much cool this way, rather than how it's setup now.
Old 07-29-2014, 09:52 PM   #52
70ina30
70ina30's Avatar
I only have enough room for 1 of these fans closest to the intake mani side.
The other side fan hits the belts.
The stock clutch fan was too far foward to fit.
So if i do 1 fan on that side, can i get a shroud that covers the rest?
Like this but single fan
Old 07-29-2014, 11:14 PM   #53
Apex Eight
Apex Eight is an unknown quantity at this point
Great build so far. Keep it up man
Apex Eight is offline   Reply With Quote
Old 07-29-2014, 11:25 PM   #54
aga
aga's Avatar
aga is an unknown quantity at this point
are you gonna have air con? if not, you can build a radiator that fits in the space previously used by the air con radiator, and use the isis shroud. it will have to be shorter in height, but you can make it a bit thicker. bear in mind that thicker radiators take longer to cool down.
the easier way is to install two push fans in the front of the radiator. a friend with an rb25 has done that and says he has no problems with temps.
My Build
aga is offline   Reply With Quote
Old 08-04-2014, 12:59 PM   #55
70ina30
70ina30's Avatar
New wheel!
Getting closer. Almost done with intercooler piping
Old 09-17-2014, 10:02 AM   #56
70ina30
70ina30's Avatar
Sorry its been a while.
Finally had the courage to start it.... Sounded great minus not having any exhaust on.
No smoke at all.
No oil leaks
No water leaks
Little rough on the idle. But i will get that dialed in.
Pics uploading now and i will post soon
Old 09-17-2014, 10:18 AM   #57
70ina30
70ina30's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 09-17-2014, 02:53 PM   #58
enderr
enderr is an unknown quantity at this point
nice build man keep it up
enderr is offline   Reply With Quote
Old 09-23-2014, 01:26 AM   #59
808_s13
808_s13's Avatar
808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future808_s13 has a brilliant future
keep up the good work man.
you're making me want to go RB25 over v8
Originally Posted by ILoveMyRHS13;
Tomei or Megan? Is like comparing Trojan condoms and Ziplock bags.
808_s13 is offline   Reply With Quote
Old 09-23-2014, 02:41 AM   #60
Akiros
Akiros's Avatar
Akiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfection
Send a message via AIM to Akiros
Originally Posted by 70ina30 View Post
Agreed. I contemplated either having someone doing the upholstery or buying a sewing machine. But I wanted more focus on the engine!
god damn texan.
Akiros is offline   Reply With Quote
