![]() Join Date: Oct 2014
Looking really nice man. It seems there are more and more 1j builds coming along in here. I can't wait to get back to the states and put the finishing touches on mine and take a bunch of pictures.
Is your trans internal or external slave cylinder? The mavericks guy told me I would not need the concentric slave cylinder spacer using the full kit but I have a significant gap between my throw out bearing and clutch diaphragm.
i had a similar issue with the clutch i was running on my SR with z33 trans. ended up putting a spacer to space out the pivot, solved it for me, on external slave
#5 |
![]() Join Date: Jan 2011
Guys, sorry there have been no updates, a bunch of crazy shit happened at work and I was freaking out so I didn't touch the car and it just sat for about 6 months. Now things have calmed down and I am ready to get back to working on it! So here is an update.
I got my ass kicked by the tube front, measuring a 3 dimensional space is the most difficult thing I have ever done.. And only having a tig welder makes things pretty interesting when welding at very awkward angles. ![]() This is the shot to the factory frame rails, mine are f'ed since the car has been in quite a few crashes. This was the most difficult part to weld and not blow through ![]() Then I set off to make the hood pins and radiator support, this is when my OCD started to cringe. I tried my best, but from side to side it's uneven which means things are not completely symmetrical. It took me a good 7 hours to make both side hood pins, and another 4 hours to make the radiator support, which after all said and done did not fix the headlights correctly.. So rather than re-making it, I just said screw it and cut the headlights to fit (thank got I dont do this for a living) ![]() I also ordered the CXracing aluminum upper radiator hose. Seen here ![]() ![]() ![]() Then it was time to make the throttle cable work. My engine came with a cut jzx100 cable, so I took the factory cable and measured from the firewall to the cut section on the existing cable and cut it. Then on the inside I just used bycicle brake cable stops, I don't like the look, but it should do the trick. If all goes to hell I am going to weld a washer to the end of it. ![]() I don't like that the brake booster nipples comes out of the wrong side in the JZs, I know everyone just routes the hose that way and calls it good, I decided to cut the nipple off and flip it to the drivers side. I also trimmed the coolant lines that run through the idle air control valve. ![]() I mounted the oil cooler where it used to be, except flipped it inward because I had to get rid of my powered by max high mount intercooler since it no longer fit (I was pretty bummed out), so I had this intercooler laying around, it's enormous but it will have to do. If you note I drilled a hole and welded a nut to the factory cross rail so I can bolt the FMIC on it. I also routed the lines, cut them and attached the AN fittings, they go to my thermostatic oil cooler sandwich adapter whatever you call it thing, and yes, I will use a NISSAN oil filter haha ![]() ![]() ![]() Next was intercooler pipes, I had some stuff laying around, but had to order some stuff, once it arrived cut and welded it. The guys sent me the wrong coupler (blue instead of black....god damn idiots). I will be runnning my old synapse bov. Later i will try to polish up the pipes so they look clean. ![]() ![]() Then lastly, the intake. what I did was I cut the factory turbo intake plenum deal and just cut it right at the entry of the turbo, took some bent piping and put the air filter just behind the bumper, I may have to run one of those air filter water sock things when it rains (hope I remember) ![]() Sorry it took so long! Sounds like you got this solved, I am running the last version of the external slave version. I would have no problem running the internal slave type though! They are equally a pain in the dick to bleed so it doesn't matter haha. |
#7 |
Looking good so far. Curious on how the g37 fans fit with the Koyo radiator. I'm currently swapping a 2j into my s14 and worried about how hot it might get crammed in there. Any better pictures of the fans mounted and how close they are to the belts?
Looking forward to more updates! |
#8 | |
I'm also running a excessive damper lockout so that doesn't help any with clearance |
#12 |
+1 to Press22. I kept mine and have no issues. Sounds like it's up to you if you want to remove or keep it.
Good progress dude! I like how you did the fuel lines, I might copy you haha. |
#13 | |
More progress: Made the coolant reservoir bracket, and realized I bought the wrong T-fitting for my coolant system, derp. I will be running the "live" cooling system in hopes it will further decrease the chances of coolant cavitation and keep air out of the system, who the hell knows it it'll work but we'll see! ![]() And modified the sway bar, this is pretty scary honestly, but I ran it by the girlfriend who is a mechanical engineer and she is not worried about it, so if it breaks I can yell at her for it! Haha. The sway bar needed to be extended toward the ground so it would clear the oil pan, while I was doing that I figured I'd get the PBM sway bar brackets as well. First and biggest issue is when done the sway bar sits inboard toward the frame more, so I needed to extend the sway bar link, I don't particularly like the idea of extending the bolt, so I welded a nut to the end of the sway bar and ran another one in front of it as a locking nut. ![]() Next was extending it downward ![]() And the sway bar strength deal that PBM sends with their kits, not sure why the angles look so weird on this picture, but it's straight haha ![]() and the end result, clearance wise ![]() I started making the exhaust, but ran out of argon for the welder... more next week |
#15 | |
![]() The diagram shows what I cut off, and basically the coolant will flow the same route except it will go from inlet (water pump) through the block, then head, thermostat and radiator, and to the turbo. That's it. I know what you mean, and I am slightly concerned about it, but them FD nerds are all blocking this stuff off, so I am pretty confident it'll be fine, otherwise I will be buying a VVTi head when I replace the headgasket on it! Haha |
#16 |
Gotcha, I've actually had it blocked off on mine for a year but my car ran hot... which is possibly unrelated, it's just really hot in Vegas.
I'm now building a second 1JZ car and wanted to weld a AN bung on there to cap it off (I can't weld though ![]() |
#17 | |
I can barely weld haha, gotta start somewhere tough! |
#18 |
Finshed the exhaust last night. I bought the CX racing downpipe added a brace to it, so it would bolt to the trans cross member (I learned on my SR that if you don't hang your downpipe, you are going to be replacing exhaust gaskets constantly. The weight of the pipe pulls down on it just enough to loosen the bolts and the gasket gives out).
The downpipe ends about halfway down the transmission, so I decided I wanted to make the exhaust out of aluminum, bought the flange, piping and rod to make the hangers. The piping is .065" wall and 3" OD. The reviews are extremely mixed, I wouldn't try this if it was a street car, but I am very intrigued. My main concern is cracks over time, so I will just have to keep my eye on it. I am happy with how close it sits to the car, since clearance is very important, I need to do more research on welding aluminum, the start/stop makes it very difficult to lay down consistent beads, but the welds won't break, that's for sure. and I apologize the pictures are out of focus and dark ![]() ![]() ![]() ![]() ![]() |
