#31 |
![]() Join Date: Sep 2005
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
Did some black friday things
Origin fenders, Origin carbon canards, s14 LCA for the subframe swap, some aero mirrors and Toshio Maeda for Supreme shirt ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#34 |
Trader Rating: (42)
Nothing really new just waiting on some bits and pieces
My buddie with his rb25 neo swapped 32 ![]() Got some s14 front LCA and s14 axles ![]() Grabbed some s14 knuckles as well painted it silver like my diff ![]() Grabbed some of these HKS garage moon power matts! ![]() Had some time to fit the rear bumper to glass it together ![]() ![]() Glassed it together and sanded this beast shits hard work ![]() Sanded it down with 40, 80, 120, and 400 ![]() ![]() ![]() ![]() Rear and front are DONE ![]()
#35 |
![]() Join Date: Jan 2014
Whats up with the big hex bolts in the rear bumper there? was that just a metal backing plate while you were laying the fiberglass?
either way, nice work |
#36 |
Trader Rating: (42)
Good eye! I mounted the bumper on the car and had 4 thin metal plates. Drilled 2 holes each side and put bolts through it to hold the bumper straight and together. I used foil tape on top of that and glassed the inside of the bumper. I also put resin in the front before I used body filler. Its my first time doing this after watching some youtube videos. Turned out pretty good sanding just sucked.... I did the same for the front and sideskirts
#37 |
![]() Join Date: Jun 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
Random question:
Not that it was uber durable to begin with, but after re-glassing is it a weak spot that you have to be careful of, or is it stronger now then before? I.e. if you bottom out or scrape will it split right up the middle? Regardless that aero is gorgeous and really unique in a sea of now obligatory r32's. |
#38 | |
Trader Rating: (42)
Its actually stronger on the spots where I glassed it. I accidentally dropped the car on the skirt and landed where i gladded the skirt. It bounced back and chipped the body filler thats it hahs. But I used resin on both sides to make it stronger.
#41 |
Trader Rating: (42)
Buddy of mine cut and extended my LCA's still gotta cut out the bump stops
![]() It was kinda nice out and the front shocks were blown. Swapped out the fronts for STANCE coils and relocated the harness as well as putting the front fenders on. ![]() This stupid fender liner was a bitch I was to lazy to take the wheels off ![]() ![]() ![]() ![]() Got that thing outta the way ![]() In you go! ![]() ![]() ![]() ![]() Blown ass apexi shocks VS STANCE ![]() ![]() ![]() Stay tuned.
#44 |
Trader Rating: (42)
Nothing too crazy just a small touch. The r32 did not have the trim around the key cylinder so I picked this one for a 180 off of ebay. Came with the "JDM" key ring!
![]() ![]() A lot of trimming was required haha ![]() End result is pretty cool! ![]() ![]() ![]()
#48 |
Trader Rating: (42)
Put my aero on!
![]() ![]() and then some lady hit me ![]() ![]() Fixed!! ![]() ![]() Car wouldn't start and found this on the intercooler so I picked up a Greddy for a good price ![]() ![]()
#49 |
Trader Rating: (42)
Small update
Did this little mod will change the hose later on haha ![]() ![]() ![]() ![]() Went ahead and swapped out the old apexi for a HKS ![]() ![]() Took me forever to find these ![]() Thanks to pacific nihon I got all 4 !! Took me a hot minute to find a full set of 18s on YAJ ![]() Also snagged these ![]()
#50 |
I'm stoked for this. Did you get that hose you are using on the Air filter from Home Depot?
私の恥ずかしブログです。 |
#52 |
Trader Rating: (42)
Got everything on!! Well the wheels at least.
![]() Got the rear coils on and added my bumper splitter and rear bumper canards. ![]() ![]() ![]() ![]() ![]() Dmax hood came in. ![]() ![]() Got these cusco hood pins to be like Koguchi but they didnt work with the hood =/ ![]() HOOD ON! ![]() ![]() ![]() ![]()
#53 |
Trader Rating: (42)
Got these guys from the land of Ebay they were for a 350z but, I made it work.
![]() ![]() Found this R33 GTR grill on YAJ needs a little work to make it fit. ![]() ![]() Got this thing in as well. ![]() I hand sanded this bitch down... ![]() ![]() ![]() ![]() ![]() ![]() ![]() Also put the rear overs on.. ![]()
#59 |
Trader Rating: (42)
Thanks man! and the support in IG haha!!! Sucks that pictures don't do the color any justice.
Copped these Origin bumper canards to go along with the other canards. ![]() ![]() ![]()
