Old 01-14-2016, 03:15 PM   #31
running_sideways
running_sideways's Avatar
running_sideways is an unknown quantity at this point
Sorry guys been really busy getting parts wrangled car cleaned up and figured out. Hopefully getting the block back from the machine shop tomorrow...its been two weeks. But on other. Note I seen everyone's comment on longevity. Let's say you guys were building a head for decent performance and longevity. What would be your set up.
running_sideways is offline   Reply With Quote
Old 01-15-2016, 03:00 PM   #32
TheRealSy90
TheRealSy90's Avatar
Dual rocker arm guides, JWT S4 cams. That's it for the head build.
Such a good signature.
Old 01-15-2016, 03:14 PM   #33
Bleakley
Bleakley is an unknown quantity at this point
Honestly.. Something similar to what he said. It's not worth it to put any serious money into he det head. The money you spend on the det head is worthless at that point while the VE head swap is an option.
Bleakley is offline   Reply With Quote
Old 01-15-2016, 04:13 PM   #34
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
I hope that this is not a thread jack, but the answer could benefit the op as well if they don't already know.
But why is the VE head a better option than the DE-T head?
I would think that the head developed for boost would have a better flow.
SoundEfx is offline   Reply With Quote
Old 01-15-2016, 05:24 PM   #35
Bleakley
Airflow...
The VE head flows way more than any DET head.
AND shaft-mounted rockers.
Old 01-16-2016, 08:41 AM   #36
SoundEfx
SoundEfx's Avatar
Thanks for that info.
It's weird that the head designed for boost is beaten by a standard one.
Old 01-16-2016, 11:24 AM   #37
Kingtal0n
Kingtal0n's Avatar
Longevity you say?
some stuff
OEM or near OEM spring rate springs
JWT S3 or S4 camshafts
valve job, ferrea valves, titanium retainers, guides (if you are in there anyways)
OEM engine bearings
tight piston/wall clearance
brand new oil pump
doctor clean assembly room
do not deck the block or shave the head if possible
7k redline max, since this is a .0008"~ main bearing and using 10W-30 oil for longevity/economy
Your engine is probably getting a tri-coat bearing (non OEM) with a .0022" clearance, and an enormous piston wall clearance as well. If so, you will need a thicker oil (the assembler would probably recommend a 40W or 50W oil) cold starts with will very rough on the engine, put additional wear on the cylinder walls and engine bearings, due to the massive clearances. Those clearances are there so you can make 500-600bhp, which is why I said to use a 60lb/min turbo and not a baby nearly OEM size turbo like the 2871.
tinyurl.com/4l80er
Old 01-16-2016, 11:31 AM   #38
JesusFreakDrifter
JesusFreakDrifter's Avatar
JesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud of
I hope a ve vs. det debate doesn't ensue, I would love to see more options on de and det heads as well as some others
JesusFreakDrifter is offline   Reply With Quote
