Old 03-14-2005, 10:36 PM   #31
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
Can someone tell me what are the oil presure readings- used the search tool, got for sale threads mainly.
Idle sometimes I see 15psi, sometiems 20
mid throttle: 45-60psi
full throttle: 80-100psi.
during warmup the guage reads 45-60psi.
by the way Im useing a Megan Racing guage, it was cheap, so yea are these accurate?
autobahNESSA is offline   Reply With Quote
Old 03-15-2005, 03:05 PM   #32
blu808
blu808's Avatar
fyi all motors ahould have higher oil press when cold.
A good rule of thumb is 10 Psi oil pressure for every thousand rpm.
If you have at least this then your good.
Old 03-28-2005, 04:45 PM   #33
SequenceGarage
SequenceGarage is an unknown quantity at this point
Send a message via MSN to SequenceGarage
Just posting some things I did not see in this thread, however it may be in the links. Plz delete if overlapping.
SR = Block
20 = 2.0L Displacement
D = DOHC
E = Fuel Injected
T = Single Turbocharger
2.0L DOHC Turbo
Turbo Type: T25G
Compressor A/R: 0.80
Injector Size: 370cc
Bore x Stroke: 86.0mm x 86.0mm
Displacement: 1998cc
Performance: SR20DET:
Power (ps): 205@ 6000 rpm
Torque (kgm): 28.0@ 4000 rpm
Compression Ratio: 8.5:1
Speed Limiter:180 Kmh -112 mph
Stock Boost: 7 psi
ECU: 62 (redtop) OR E5 (blacktop). 63 (automatic) will also work.
MAFS: 89-90 240sx mafs works.
Rev Limit: 7500rpm (no need to really go over 7200)
Gear Ratios:
Gear Ratios - Manual Transmission
1st 3.321
2nd 1.902
3rd 1.308
4th 1.000
5th 0.759
Reverse 3.382
Final 4.083
S13 ECU Pinout (thanks to CM510.com)
Zenki S14 SR ECU Pinout (thanks to 200sx.org)
Classic battery area wiring diagram from heavy throttle:
Sasha Anis
Sequence-Garage
SequenceGarage is offline   Reply With Quote
Old 04-07-2005, 02:16 PM   #34
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
The power specs, and turbo that Sequence Garage listed are for s13 sr20det only. S14 is 220hp (I think) with a t28 turbo. The s15 is 250hp (again, I think) and uses yet another turbo.
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 04-10-2005, 12:27 AM   #35
BLT123
BLT123's Avatar
BLT123 is an unknown quantity at this point
Send a message via Yahoo to BLT123
S15 same turbo with cast divider wall, bigger injectors, and I think thicker beams but not sure. Both S14 and S15 blacktops have VVL.
BLT123 is offline   Reply With Quote
Old 04-11-2005, 03:33 PM   #36
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
Originally Posted by BLT123
S15 same turbo with cast divider wall, bigger injectors, and I think thicker beams but not sure. Both S14 and S15 blacktops have VTC.
there..fixed it for ya...would really be a fun motor if they have vvl...but sadly they dont..so dont spread incorrect info.
1990 240sx 5spd fastback
240Driver39 is offline   Reply With Quote
Old 04-16-2005, 01:49 AM   #37
closebyu26
closebyu26's Avatar
closebyu26 is an unknown quantity at this point
At the bottom of this tread they talk about bhoost for stock sr20det turbo. I have found from personnal experiance that the turbo will at least put out 1.3mb, or 18 psi, but I have stock everything, so detination was the final outcome, but it would put out more if you had bigger inj, front mount IC. I'm running it at 14 psi right now with no problems. Thats with a greddy boost controller.
closebyu26 is offline   Reply With Quote
Old 04-20-2005, 05:32 AM   #38
gerryb
gerryb is a well-known jackass
Z32 NA and TT AFM look the same but are different. The difference is that the NA AFM will read up to 350hp or so, the TT one will read up to 500hp. You want the TT AFM.
gerryb is offline   Reply With Quote
Old 04-20-2005, 05:37 AM   #39
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
your dumb as shit and your post should be removed at once, and when yours is, then mine should follow
btw I see you dont post much as youve been here quite a bit longer than your post count would show, I hope this doesnt discourage you from future posting, but I would hope you think next time before pushing bullshit into the mix.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 04-20-2005, 08:16 AM   #40
gerryb
Hey f$%K you you yanky piece of crap, when you turkey's were still running around in ka truck engine pieces of crap we'd been doing sr conversions etc here for years, (and had complete import s13 sr's here). There are 2 part numbers for Z32 AFM 1 for NA and 1 for TT. They have been tested for voltage to airflow capacity and that's the fact jack, so unless you have been involved intuning them and have the facts shut your stupid dumb shit mouth.
Old 04-25-2005, 11:46 PM   #41
SpeedRacerGTP
SpeedRacerGTP's Avatar
SpeedRacerGTP is an unknown quantity at this point
Send a message via AIM to SpeedRacerGTP
What's with the hate? It takes maturity to engage in intelligent discourse without namecalling. If someone says something you disagree with, make it known WITHOUT taking personal jabs. Didn't either of you two go to Kindergarten? Sheesh.
http://www.courtesyparts.com/Merchan...e=22680-Z32ALL
Apparently the Z32 MAFs have the same part number and are therefore the same for both the TT and the N/A (at least for the USDM, although I highly doubt it would be different elsewhere). So calm down you two!
SpeedRacerGTP is offline   Reply With Quote
Old 04-30-2005, 11:41 AM   #42
mike_fernandes
mike_fernandes is an unknown quantity at this point
s14 Oil Capacities
wow.. i think this is my first post ever.
This info is for the S14 blacktop motor, it's taken right out of the service manual. hope this helps some of you.
Engine Oil: (with filter change): 3 1/4 qt (3.7 L)
(w/o filter change): 3 1/8 qt (3.5 L)
Cooling System (including resevoir): 5 1/2 qt (6.2 L)
Manual Transmission: *GL-4* 4 1/4 pt (2.4 L)
Differential carrier gear oil: *GL-5* 3 1/8 pt (1.8 L)
Automatic Transmission: 7 qt (7.9 L)
Power steering 3/4 qt (0.9 L)
edit: if anyone doesnt believe this I can back it up with a pic of the page from the manual, but as you can tell I'm new and don't know how to upload pics yet... unless theres someone that can host them for me.
mike_fernandes is offline   Reply With Quote
Old 05-23-2005, 02:29 PM   #43
the head
the head's Avatar
the head is making a name for him/her selfthe head is making a name for him/her self
short block has no Head only pistons crank ect
I never knew you could do that with an eggplant
the head is offline   Reply With Quote
Old 05-23-2005, 03:47 PM   #44
Carlwill
Carlwill's Avatar
Carlwill is an unknown quantity at this point
Originally Posted by 420sx
spark plug seal is same is fwd SR from sentra.
ka and sr tranny are NOT interchangable. the rear housings are same. its basically same tranny, u just cant bolt it up.
I just found out the hard way that there is a difference between FWD and RWD seals for the SR. RWD are larger.
Linux System Administrator
rm -Vfr /etc/*nix "Love is a fist"
Carlwill is offline   Reply With Quote
Old 06-03-2005, 08:44 PM   #45
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
sr20det spark plugs are code BKR7E-11
by NGK
sepulchral is offline   Reply With Quote
Old 06-18-2005, 06:02 AM   #46
s13gonwild
s13gonwild is an unknown quantity at this point
heres a few had to search for the clutch and main seal that any us cars have...
-Front and rear main seal = 93 sentra SER
-Stock sr clutch = 89 Nissan Maxima
-Timing chain replacement = 89 Nissan Maxima
-o2 sensor = 87 300zx turbo
-Turbo gaskets = 90-96 tt 300zx
-Exhaust/intake manifold gaskets = 93 Sentra SER
Also found out you could use a ka radiator on sr but you need a top radiator hose that would travel from the pass side to the driverside and you will need to cut the ends a bit..
you can get the hoses from the following
-02 Dodge neon L4 2.0L
-96 Buick road master limited V8 8.7L
-96 chevrolet caprice classic V8 4.3L/5.7L
s13gonwild is offline   Reply With Quote
Old 06-24-2005, 10:40 PM   #47
Taffy
Taffy is an unknown quantity at this point
Send a message via AIM to Taffy Send a message via Yahoo to Taffy
-Jeff
The Japanese S14 and S15 turbo are basically the same. Both the compressor and exhaust housings are the same. The compressor and exhaust wheels are the same specs. The difference is that the S14 exhaust wheel is not made of the same material as the S15 exhaust wheel. I can not remember the materials, but they are NOT ceramic, they are steel alloys.
The S14 turbo in Australia is not ball bearing from what I have been told. The S15 in Australia is ball bearing though.
If it ain't turbo, It's crap.
Contact Me
Taffy is offline   Reply With Quote
Old 06-24-2005, 10:42 PM   #48
Taffy
The spark plug seals are not the same. The S13 and S14/15 RWD SR20DET spark plug seals are JDM only.
The SR and KA bell bousing have different engine side bolt patterns.
Contact Me
Old 06-30-2005, 01:54 AM   #49
Jeff240sx
I hate you too...
Jeff240sx's Avatar
DO NOT POST IN THIS THREAD UNLESS YOU HAVE AN ANSWER TO A FAQ!
I just pruned ~40 posts from this thread, too. I'm sick of fucking babysitting these FAQs, and WILL lock them if a simple rule like "Stop asking stupid questions" can't be followed.
You have a question without an answer? Step 1. Search. Step 2. Post in the Tech section, NOT THE FUCKING ANSWER THREAD!
-Jeff
Whatup?
Old 07-16-2005, 01:54 PM   #50
TKOs14
TKOs14 is an unknown quantity at this point
Send a message via AIM to TKOs14
sr20det s13 in s14 coolent capacity:
"with koyo s14 radiator"
1 3/4 gallons
thats all i got...
TKOs14 is offline   Reply With Quote
Old 07-18-2005, 07:32 PM   #51
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
did a search and found nothing
sr20det oil pan holds 3.5 quarts of oil but you can put in four.
>>don't know if thats a good or bad thing but i remember it being discussed.<<
hellion240sx is offline   Reply With Quote
Old 07-26-2005, 09:52 AM   #52
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
do not put anymore than 3.5 quarts of oil in your sr.. the rest will be spit out by your engine through your breather valve, unless you like your intercooler and intake to have a thick oil film on the inside.
yes it will hurt your engine.
I'm here to inform not to conform...
s14 blacktop is offline   Reply With Quote
Old 08-09-2005, 10:00 AM   #53
brrr
brrr is an unknown quantity at this point
s14 sr into 96 240sx help
Hey, I am doing an s14 sr into s14 96 240sx and I have the complete wring harness and the jdm ecu. There are four plugs on the inside-of-the-firewall end of the harness, the ecu plug, another large plug (which is obvious where it goes so ok), and then 2 blue relay plugs. On the 240sx harness though there is one blue relay plug, and then this 8wire little white plug that attatches to a plug that seems to run to the back of the car. What to I do with this difference? I found which of the 2 relay plugs match up, but I am left with an unaccounted for relay plug on the sr harness and a empty white plug in the car. what should I do?
brrr is offline   Reply With Quote
Old 08-18-2005, 05:16 PM   #54
oumu
oumu's Avatar
oumu will become famous soon enoughoumu will become famous soon enoughoumu will become famous soon enough
Send a message via AIM to oumu
by NGK
Those sparkplugs fit but aren't OEM and are one step colder than stock.
Be sure you regap them to 0.9mm (0.036in).
The correct OEM plugs are double platinum:
NGK PFR6B-9
And I think this is the Nissan Part Number:
22401-27N66
You can also use NGK Iridium:
BKR6EIX
BKR6EVX
BKR6EIX-P
Or traditional spark plugs like he listed:
BKR6E
You can change all those sixs to sevens to get colder plugs.
(e.g. BKR7EIX)
oumu is offline   Reply With Quote
Old 08-18-2005, 06:03 PM   #55
1121S13
1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about1121S13 has a spectacular aura about
mod said no questions.. fuk man read..
bigass letters
-incase of hotpipe clearance issue
to add; If you want your SR hotpipe to sit LOWER(S13 SR), use a S14 turbo inlet pipe..
hotpipe /w bov sits nice and low.
s14 inlet pipe is shorter then s13 inlet pipe.
1121S13 is offline   Reply With Quote
Old 09-04-2005, 02:26 PM   #56
Kingtal0n
Kingtal0n's Avatar
This is a diagram I made for converting your your #62 harness to work with a J4 ECU, and visca versa.
it illustrates the differences between #62, E5, and J4 ecus.very handy!
http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Old 10-09-2005, 06:17 PM   #57
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
Originally Posted by DuffMan
No its still 7psi. Think about it: A valve that restricts air to the wastegate can only raise the boost not lower it. So if the stock wastegate was really set to 11psi, theres no way a solenoid would bring it down to 7psi. The purpose of the solenoid is slightly faster spool up, by preventing the wastegate from opening part way at lower boost.
Does this thing have that solenoid?
neilsan is offline   Reply With Quote
Old 10-13-2005, 02:00 AM   #58
s13envy
s13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nice
Send a message via ICQ to s13envy Send a message via AIM to s13envy Send a message via MSN to s13envy Send a message via Yahoo to s13envy
I think with the NGK plug the higher number you go the colder the plug gets. example hotter - bkr6e ; colder - bkr7e Correct me if I'm wrong guys
s13envy is offline   Reply With Quote
Old 10-13-2005, 10:19 PM   #59
BoostInnovations
BoostInnovations is an unknown quantity at this point
Send a message via AIM to BoostInnovations
we've already discovered this...delete my post and his please
BoostInnovations is offline   Reply With Quote
Old 10-20-2005, 02:54 PM   #60
turbo_lover
turbo_lover's Avatar
turbo_lover is an unknown quantity at this point
Send a message via AIM to turbo_lover
Question
i have a real quick question ive been wonderin about for a long time... how much does a SR20DET weigh in a base model 240sx?(no power windows,sunroof,etc.)
thanks.
BOOST is BETTER!
1. Nissan
2. Honda
Oh, so you hate #2?
turbo_lover is offline   Reply With Quote
