Old 05-08-2016, 11:43 AM   #1
sterlinge
sterlinge's Avatar
sterlinge is an unknown quantity at this point
s13 part out! would you just look at that..
not really needing to do this but i feel the car needs a bit of work to bring it back to life at this point and im not super motivated to get it running again. with that said heres what i have for sale.
stance coilovers (less than 4k miles) $680 local
pbm flca combo (less than 2k miles) soldd
sikky sway bar (less than 4k miles) sold
full brake setup soldd!
300zx calipers 30mm aluminum (full set) sold
300zx rear brake rotors sold
agency power 300zx conversion brake lines sold
350z track rotors sold
adapter brackets for 300zx 30mm calipers to fit 350z track rotors on s13 sold
pbm inner tie rods $70
gktech outers $50
all spl rear links ruca, toe, traction package deal Soldd!
spl ruca Sold!
spl traction rods Sold!
spl toe rods Sold!
s13 sr20det koyo N flow new new soldd
synergy green subframe with spl solid bushings soldd
s13 5 lug conversion rear hubs, one needs 2 new studs $85 shipped
s13 5 lug conversion front hubs sold
s14 front seats soldd
silvia triple projectors good bulbs no broken mounting tabs just the one for the corner lights sold
silvia corner lights not the best $soldd
silvia gtr style grill, from japan abs plastic $100 shipped
1jzgte vvti with 5 speed wiring harness engine is super clean inside and i started it on the ground sounded perfect. maf, ecu and igniter all included
$1000
1jzgte vvti newer model R154 transmission sold
spec stage three r154 1jz clutch good condition $220 shipped
like new stock 1jzgte r154 flywheel $soldd
s13 2jzgte excessive man. eng. swap brackets new soldd
s13 2jzgte excessive man. swap r154 bracket used $45
shipped
s13 stock height solid aluminum motor mount new $55 shipped
s13 stock height solid aluminum motor mount used soldd
2jzgte aristo sard 540cc drop in injectors, used maybe 1000 miles included connectors and original boxes solddd
call or text 8302373273
[/URL][/URL]
sterlinge is offline   Reply With Quote
