Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 02-14-2017, 02:43 PM   #1
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
NEW! 350z diff to S14/S15 subframe swap bushings!
UPDATED DESIGN! I took customer feedback and made the new ones easier to install. This design has a much larger lead in to help alignment. The last little bit is pressed on so there is no clunking or other issues.
Introducing a bolt in way to add a stronger 350z/370z/G35/G37 differential to your existing s14/s15 subframe! No cutting, welding or fabrication.
What are they?
Three(3) bushings that are precision CNC machined from 6061-T6 aluminum and then anodized to a MIL-8625F finish. The bushings are engineered to place the differential in the center of the subframe and maintain the proper factory driveshaft angle. The bushing kit is only able to be used with s14/s15 subframes or other Nissan subframes which use the 2 larger diff mounts on the rear cover.
What do they do?
The bushings allow you to drop in a stronger and cheaper Z/G differential into your s14/s15 subframe. Previous the only other way to do this was to cut and weld but there is NO cutting or welding required for this swap.
Benefits:
-Stronger, newer and more readily available Z/G differential
-Wider range of ratios available, OEM and aftermarket
-Ability to use larger and stronger 350z axles
-Better matched ratios those doing 350z transmission swap
-Uses STOCK 240sx hubs, works with 4 and 5 lug cars.
-Potential to use 350z speed sensor built into diff for actual wheel speed.
What is needed for this swap?
- Maverick Motorsports Z/G conversion bushings
- 350z/370z/G35/G37 differential, avoid the G37 AT diff because it has a different driveshaft flange
- 350z/G35 axles
- Driveshaft made to your length and drivetrain setup(not available here).
Need to know:
Due to the large variety of rear knuckles, arms, alignments please make sure the axles are not over compressed or over stretched. Failing to do so will cause premature breaking of the axle and other driveline components.
ORDERING:
https://www.maverick-motorsports.com...rsion-bushings
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
