Old 10-21-2004, 10:13 PM   #1
DORIMON
DORIMON's Avatar
DORIMON is an unknown quantity at this point
Originally Posted by kazuo
DORIMON, where is your gauge getting its source from?
The Autometer mechanical boost gauge (which is known for inaccuracy, I know) is teed off from the vaccuum line that goes from the fpr to the throttle body. The Blitz Type-X Dual Turbo Timer has a boost gauge as well in bar, and the peak hold function never goes past .5 bar. Its teed off in the same location. My autometer's accuracy is pretty on point as it reading the same as the turbo timer, awhile back I also swapped the autometer gauge with another autometer gauge that didn't have a vacuum just to test if mine was off, this was before I got the digital turbo timer. Anyway, with the turboXS manual boost controller turned all the way down, the peak boost hold is the same as when I had no boost controller installed at all, so the actuator isn't faulty, just to rule that factor out.
Originally Posted by Silverbullet
nice numbers benji, i have the exact same setup as yours except instead of an FMIC i have an ARC SMIC. alot bigger than the stock side mount but not exactly riding with the big boys yet. - oh and I have an S-AFC. Its not installed tho...
do u run those NE points on the stock boost setup only? do u have a different settings for when you run higher boost?
i hope to get simlar results as you.
Yea, I only had enough time for 4 pulls which I was able to tune for 7psi, which was enough for me for last Thursday and Sunday's events. I'm not planning on raising the boost anytime soon. I'm pretty satisfied with how the car is running right now. I really wish I could've done more pulls so we could see how the a/f changes as the boost increases. I'll go back sometime next month when they're not so backed up with appointments.
DORIMON is offline   Reply With Quote
Old 10-22-2004, 07:06 AM   #2
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
which place and how much for 4 pulls?
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 10-22-2004, 09:12 AM   #3
duey
duey's Avatar
duey is an unknown quantity at this point
Those numbers are basically right on with my numbers when i originally dyno'd my car. Our setups are very close too. My dyno sheets are on my cardomain site if you wanna compare them.
Maybe u got a freak motor like me
http://members.cardomain.com/duey170
12.3@111mph - basic mods/STOCK t25
duey is offline   Reply With Quote
Old 10-22-2004, 09:58 AM   #4
DORIMON
DORIMON's Avatar
This was in College Park, MD at SwiftRacingTechnologies (www.swiftracing.com). They charged me $60 for 3 pulls, I got a free pull because they accidentally did a 4th gear run twice instead of once. They usually charge $95 for an hour session, but I believe they might be raising their prices pretty soon.
Ok cool, glad someone else has similar numbers.
Old 10-24-2004, 04:14 PM   #5
Phlip
Yes, I look like that
Phlip's Avatar
Steeles also had similar numbers on stock boost with similar mods.
Weirdo
And I write too!
Old 10-24-2004, 09:33 AM   #6
WhiteGLX
WhiteGLX's Avatar
WhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to allWhiteGLX is a name known to all
Send a message via AIM to WhiteGLX Send a message via Yahoo to WhiteGLX
those numebrs are sweet for stock boost.....congrats!
my car with your setup basically put down 208whp on stock boost, i have Stainless Tubular manifold and a cat still, andmine was tuned on the dyno with SAFC II. Didnt get much power out of my SAFC, the guys just played with the fuel, so i wasnt running too rich or lean anywhere basically. All pulls were in 4th for me. If my compression wasnt evenly bad across my cylinders i think i would have pulled closer to your numbers or even close to 270now
Compression Results:
Cly1 Cyl2 Cyl3 Cyl4
150 130 140 130
and its been like that for athe past 5 months or so...
***NASA HPDE Instructor***
WhiteGLX is offline   Reply With Quote
Old 10-24-2004, 03:37 PM   #7
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
junedmwsm,dfndnsdomv dz i know!! i even did the math in my post to show what it would measure for whp..... wtf mate?
wootwoot is offline   Reply With Quote
Old 10-24-2004, 05:04 PM   #8
RedSuns
RedSuns's Avatar
RedSuns is an unknown quantity at this point
Send a message via AIM to RedSuns
my stock S14 SR with similar mods did 201 to the wheels..
Johnathan
2005 Titan
1996 240SX
1991 240SX
1974 260Z
1996 Honda CBR 600 F3
RedSuns is offline   Reply With Quote
Old 10-24-2004, 05:32 PM   #9
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
My redtop w/ FMIC (crappy piping, not a kit ), stock outlet/downpipe, 2.5" testpipe and tanabe exhaust, boost controller, 255 lph pump and old fuel cranked out 210hp/228tq at 8 psi
Benji, next time u go up there for a dyno, hopefully my shit will be running again, and we can go at the same time. I'd like to see what i'm puttin down with all the new parts
Ian is offline   Reply With Quote
Old 10-24-2004, 08:42 PM   #10
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
man, am i closely following this thread... I switched back to T25 and hope to achieve similar numbers.
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
