Old 07-24-2018, 09:56 AM   #1
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
1989 Nissan 180sx - SR20DET & much more
Thomas Morataya
Columbia, MD
Hey guys. Up for sale is my 1989 Nissan 180sx. I bought this in 2016 from Phil at Japanese Engine Imports in Manassas, VA under the 25 year rule.
The motor runs smooth and pulls strong. Not a single puff of smoke! Car starts up every time. No motor issues at all. Its honestly the strongest SR I have owned.
I bought the car with 64,xxx kilometers and I've only put around 6,000 miles since ownership. There are a bunch of aftermarket parts including RARE parts you will not find for sale often.
Back in December 2016 I had a minor fender bender with the car. I ended up taking this car to a body shop to have the front core replaced and engine bay painted. Rails are fine. I just didn't want to half ass a repair. The front end fitment is actually a lot better than when I first bought the car.
Here are the specs.
-180sx Kouki SR20DET (new valve cover and spark plug gaskets)
-155psi across the board
-T25 at 7psi
-ARC Oil Pan
-Xcessive Manufacturing Skid Plate
-Engine bay painted
Cooling:
-Greddy FMIC
-Aftermarket Radiator
-Powered By Max Intake Pipe
-Blitz Filter
-New OEM turbo crush washers
Exhaust:
-Powered By Max Cobra Downpipe
-ISR Test Pipe
-Trust Catback Exhaust
-New OEM Multi-layer exhaust manifold and turbo gasket.
-New OEM Turbo Outlet Gasket
Electronics:
-Greddy Boost Gauge
-Kay's Water Temp, Oil Temp, and Oil Pressure Gauges
-Data Systems turbo timer
-Nissan OEM S15 DRV Meter
-Blitz Boost Controller
-Pivot Headlight Controller
-Pivot Air/Fuel Controller
-Battery Relocated to the Rear
-Front Harness was properly tucked
Interior:
-Nardi 350mm Suede Steering Wheel
-Autech S15 Seats
-Works Bell Knock off Quick Release
-Trust Shift Knob
-JDM Drift Button
-Razo Pedal Covers
-White Face Cluster
-OEM 180sx Floormats
-OEM Digital Climate Control (A/C and heat works!)
-Full Interior
Exterior:
-OEM Folding Mirrors
-OEM Rain Guards
-OEM Z33 Wheels
-OEM 180sx turn signals
-clear front side markers
Suspension:
-Top Secret Coilovers
-Unknow Tension Rods
-S15 Front Spindle
-5 Lug conversion
-Unknown Brace between frame rails under the trans behind the crossmember
Brakes:
-Z32 30mm Calipers (Front)
-Project Mu Front Pads
-Braided rear brake lines
Drivetrain:
-Kaaz 2 Way Differential
-5 bolt axles (duh)
CONS:
-Bodywork was done
-No front door speakers or radio (might throw in a radio)
-1 crack on dash
-4th gear has a small grind at certain RPMs
-Coils are showing their age
Will throw in a bunch of S13/SR parts I have laying around as well.
That is all for modifications. I will edit if I forgot something.
Pics of interior were taken when cleaning. This car has a full interior!
Photos from 11/17
CLEAN title!
Please don't PM me unless you have cash in hand.
CASH OR CERTIFIED CHECKS ONLY!
NO TEST DRIVES UNLESS CASH IN HAND.
Asking $10,500
Ramonesfreak2010 is offline   Reply With Quote
