Old 07-07-2020, 09:30 PM   #31
shinhed
shinhed's Avatar
shinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of light
Saw the YouTube video before the actual thread. Good shit!
shinhed is offline   Reply With Quote
Old 07-12-2020, 08:17 PM   #32
G33kin
G33kin is an unknown quantity at this point
Tubs look good!
G33kin is offline   Reply With Quote
Old 07-14-2020, 07:43 PM   #33
koukis13
koukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the roughkoukis13 is a jewel in the rough
Hey, sorry about no updates. Been doing some side projects for some friends.
Anyhow, I finally painted inside my 240sx. I used 2 stage paint, so that means a white base coat followed by a quality clear coat. My favorite part is where there is seam sealer but it's smooth. ( all bottom panels have been stitched with 1 inch beads by the way ) All this won't really matter anyways because it will be cover in Dyna mat and full interior. Also you can see in the first pic why it's masked off. I originally painted the rear section of the car and all sections above, allowed that to dry over a week and then masked that all off and just focused on the front half of the 240sx. This allows me to put down some nice coats without having to reach so far and potentially touch the wet paint, it also keeps the fumes down. Enjoy these photos...
koukis13 is offline   Reply With Quote
Old 07-14-2020, 07:58 PM   #34
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
That looks fantastic.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille
e30gangsta is offline   Reply With Quote
Old 07-15-2020, 11:47 PM   #35
S13project
S13project's Avatar
S13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of light
Not even the factory looks that good. So clean!!!
S13project is offline   Reply With Quote
Old 07-16-2020, 08:49 AM   #36
JrDarknes
JrDarknes's Avatar
JrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud of
That looks beautiful.
Instagram: Nismo_Lk
JrDarknes is offline   Reply With Quote
Old 07-16-2020, 12:08 PM   #37
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Do you have any plans to reinforce and stiffen up the chassis? Perhaps some OEM S15 Spec R braces or something similar?
spooled240 is offline   Reply With Quote
Old 07-17-2020, 11:49 AM   #38
koukis13
Thanks guys!
Spooled240 , I stitched the front end of my chassis and all bottom panels been stitched with each other and stitched to the side panels.
Old 09-13-2020, 07:10 PM   #39
koukis13
Hey Guys, I'm still alive. Just took a long break from the 240 as summer was pretty hot and busy. But, I'm back at her again. Pretty much used 3M sanding guide coat on the entire engine bay, blocked everything smooth, wipe it down with wax and grease remover. Started masking everything for seam sealer. Also there is these two gaps at the top of the frame rails in the engine bay, I think Nissan really fucked this up. The gap allows water to go inside the frame rails and rust it over time. Especially on the Driver side, Brake fluid will drip in there and started deteriorating the paint which allows water to start rusting metal. So, I SUGGEST YOU ALL GET SOME SEAM SEALER AND PLUG THAT BITCH UP.
Old 09-14-2020, 06:08 PM   #40
S14rebuild
Pics dont work for me...
Old 09-15-2020, 06:44 PM   #41
SERADAMEL
SERADAMEL is an unknown quantity at this point
This is just incredible, I wish I had space and your skills to do exactly the same to my car.
SERADAMEL is offline   Reply With Quote
Old 09-16-2020, 12:14 PM   #42
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
Very nice work here! I like the picture of you holding sealant with a flammable symbol and a cigarette in the same hand lol.
C. Anderson is offline   Reply With Quote
Old 09-20-2020, 05:24 PM   #43
koukis13
Thank you, you can learn bro.... if your determined.
It's more exciting when I'm smoking and pouring paint thinner.
Old 09-20-2020, 05:29 PM   #44
koukis13
Okay guys... So Exactly 1 Year ago, I made all the fab work for the front tubs... The proper preparation got it to where it is now... Painted my engine bay in a Toyota Super White II . By the way, the front end has been stitched, most of them all under the body out of sight.
Old 09-22-2020, 06:14 AM   #45
MeSs
MeSs's Avatar
MeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura aboutMeSs has a spectacular aura about
Great work! Looking forward to see the rest
2011 BMW F11 5-series and 2003 Nissan 350Z
MeSs is offline   Reply With Quote
Old 09-22-2020, 12:15 PM   #46
PoorMans180SX
PoorMans180SX's Avatar
Such gloss! That is a fantastic looking bay there sir. Well the entire chassis actually hah. What are your plans for the car? I see you mentioned 2JZ, but is this thing going to be a nice weekend kinda vehicle or?
Old 09-25-2020, 06:52 AM   #47
koukis13
Thanks!
Most likely going 2JZ and yea, this will be a spring - fall daily!
Old 03-01-2021, 05:52 PM   #48
koukis13
Hey, been away from the 240sx project during the winter. It's getting warm now so I'll be getting back on that grind. Here's a 6 mins video on using Eastwood Internal Frame Coating on the 240sx frame rails, cross member, any other cavities, if anyone is interested. Sub up if you haven't, maybe it will give me motivation to grind harder haha.... Thanks
http://www.youtube.com/watch?v=BUELr-46674&t=14s&ab_channel=WeldingOCD
Old 03-02-2021, 05:52 AM   #49
PoorMans180SX
Looks good. I was planning on using that stuff on my long term resto project too, good to see a video of someone using it on something other than a truck box frame, haha! I definitely subbed a while ago.
Old 03-05-2021, 07:40 AM   #50
Avayo
Avayo is an unknown quantity at this point
Excited to see more on this, I?ll check out the YouTube channel!
Avayo is offline   Reply With Quote
Old 03-14-2021, 09:16 PM   #51
koukis13
Hey guys, just wanted to share the process of redoing my engine bay if anyone is interested.
This is a small clip on how dirty the engine bay is, the cleaning of it is pretty dirty. You have to do it no matter what.
http://www.youtube.com/watch?v=rf5pfZFe39k
This is a 12 Mins video on how I choose to cut and weld my tubs. I tried to be as detailed as possible.
http://www.youtube.com/watch?v=LfgV-7u5VmU
Sub,Like,Comment if you find this stuff useful, I'm trying to pump out more content. To be honest, I'm gonna go broke building my dream car.
Old 07-30-2021, 03:59 AM   #52
OpsWest
OpsWest is an unknown quantity at this point
Subscribed, very satisfying to see. Favorite thread for sure
OpsWest is offline   Reply With Quote
Old 08-08-2021, 08:17 AM   #53
koukis13
Thanks bro! Holay, I been mad busy with shit, sorry, no updates. I'll try to keep this thread going more.
Old 08-08-2021, 08:44 AM   #54
koukis13
okay, so this project been a long ass drag. Sometimes I drink just to get some mind numbing motivation. The worse part of this whole project is definitely the underbody. It was time to raptor line the underbody. The body was coated in Epoxy primer. So I gotta sand it again so that the raptor can have something to mechanically grip to. Raptor suggest at least 180 grit sand paper which I used along with this red brush that helps speed up the process since the underbody is full of contours and not friendly sanding surface. I used a black guide coat so I can see what I missed. Then I seam sealed every fucking seam, no fucking water is entering between panels 100%. I bought the raptor liner Vari Gun, which has an adjusting knob so you can fine tune and choose the texture you want with the raptor. I highly suggest this. After carefully masking this up, I SPRAY AND PRAYED. This is the last time you will see my underbody, Thank GOD!
Old 08-08-2021, 08:56 AM   #55
koukis13
Anyways, I'm taking a break from anymore body work. The only thing left is the exterior but that can come last. I wanted to get to the fun part now! I seen a set of used MAX JAX lift for sale, designed for low ceiling garages. My garage is only 8 feet 9 inches tall. This lift will do me good. It's made so you can bolt it down into the anchor bolts in the ground which sits flush. I can unbolt it when I want and move the lift out of the way.
Check out my rusted ass Canadian rear subframe. Started taking her apart. I picked up a non rusted, non hicas rear subframe for $80. Wire wheel the rust off my rear diff, sprayed it in Eastwood Acid treatment to neutralize the rust, sprayed it in acid etch primer, followed by some high performance satin black paint in a can. Did up my drive axles in the same manner. Using these until I can afford better axles. Broke ass 240 lift
Old 08-10-2021, 06:01 AM   #56
PoorMans180SX
Looks killer as always dude!
Old 04-06-2022, 04:46 AM   #57
tuzzio
tuzzio's Avatar
We're gonna need updates on this one as well.
tuzzio is online now   Reply With Quote
Old 04-06-2022, 12:16 PM   #58
Om1kron
Om1kron's Avatar
bless your heart bro, I don't even like my car this much lol.
Wayne Edwards
https://om1kron.blogspot.com
Old 04-06-2022, 02:38 PM   #59
Corbic
Corbic's Avatar
Hawttt Dayum!
Old 06-30-2022, 08:06 PM   #60
run-matsuo
run-matsuo is an unknown quantity at this point
Great work. Loving the attention to detail! Have you taken any shots of the full car after you welded on the flares? I'm curious about how it all turned on.
run-matsuo is offline   Reply With Quote
240sx, 2jz, nissan, s13, type-x
