#1 | |||
Oof, the shop I got recommended to by a friend is filled up today. Gotta go in tomorrow. But I definitely have enough fuel pressure, but I will make time today to double check my fuel filter and fuel pump to see how it goes. For a leak test Imma probably gunna have to do it at the shop since I don't have a compressor laying around but I might get that done first before an ECU read.
But all in all, I'm taking it into a recommended shop tomorrow noon, this time with a proper booking (since I was told to just rock up last time ahaha). If that doesn't work, I've also gotten a proper booking with a store that specifically dyno's imports. God I wish Nissan just made new 180s. Once again, thanks for everyone's input, issue isn't solved but at least I'm learning things on the go. Much appreciated. |
I was born a tad too late I guess. Early 20s here, I'll never experience a new silvia unless I completely rebuild my own from the ground up (which I hope to achieve one day) ahahaaaaa
Hey all, so I just got back from the shop. Turns out it was a blocked injector all along that was causing it spazz out. So far it hasn't had any RPM drops or stalling like symptoms. I'll have to monitor it for a few days to see how I go then I'll update it one last time for people who may have this issue in the future.
Thanks for all the inputs you guys have given. |
#5 |
Ok! Fuel, air, spark!
Has the car sat for some time? Maybe fuel drying up and gelling out? Victory in finding it, and now you have all these nice clean peripherals ![]() Sent from my iPad using Tapatalk |
#6 |
Yea, the car did sit for about a month without movement because I was overseas. But is that enough time for it to get clogged like that? The car is definitely running on all 4 cylinders now, but the starting of the car is still a bit uhh I guess the best word would be slow. So it might not be all over yet ahaha
#7 |
Not really. Mine sat for two and a half years before firing first go. There was some lifter rattle that subsided after a while idling, and is all good now.
Though that said I only ever put premium 98 in and drained the fuel before continuing with new oils etc. Still, it?s something to sort out why it happened, have you had the firm times of opening the tank and getting the pump out etc yet? Always a good moment for upgrades. Sent from my iPad using Tapatalk |
#8 |
I think I got some lifter rattles right now, it's either that or my injectors are rattling lmao. I still need to figure that out. The next things to replace on the list is the fuel filter and the pump. I'm scared of that giving out next aha
#9 |
![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
sr's do have noisy injectors, so don't drive yourself too crazy. A mechanics stethoscope would be a good thing to have around, just to check in on things periodically. Cheap too, like borscht.
#10 |
Well, I'm back with an update. While the engine is definitely running on all 4 cylinders, it occasionally still dips. I'm taking it to a different shop this time to see if I can get it cleared up. Also struggles to crank, rarely does it, but still happens.
Seems like it's multiple things at once that's causing this outcome. |
