#31 | |
![]() Join Date: Feb 2003
![]() ![]() ![]() Feedback Score: 0 reviews
![]() '89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut '95 BMW 540i 6 speed: Ultimate Commuting Machine PFM Racing www.solo2.org www.midwest240sx.com |
#32 | |
![]() Join Date: Apr 2003
What I find humorous is that there are years and years of data that support that wider tires are better. People who autocross, don't really question this because it's widely accepted, and is BACKED UP by data. Seems there are lots of people who like to throw out formulas and use the results to prove a point, when they haven't accounted for all the variables. If grip is simply a function of contact area and weight, then wouldn't you increase the car's weight to increase grip? Anyway, like has been said before, a wider tire puts less stress on the sidewall, which in turn allows you to run less air pressure, which in turn increases the contact area. Basically what Rennen said. <rant off> Sorry for the rant. Yudalicious, don't take it personally, it's just frustrating to see some people (not you) try to justify themselves without testing what they are saying.
Jason '95 240sx SE |
#33 |
For anyone who doesn't believe that wider is better, find a friend with staggered tires of the same brand. Do an autocross run on them, then rotate them front to rear. Repeat that run and then decide for yourself.
Jason '95 240sx SE Last edited by jmauld; 04-11-2005 at 08:15 PM.. Reason: oops. Is, isn't, what's the difference. :) |
#34 | |
What I find humorous is that people KEEP insisting on telling me that there's data to prove wider tires are better when all along.... I'VE AGREED... read my above posts...all I asked was better explanations... not an outlash against those who have responded with good explanations, jmauld, rennen, etc., just my own little rant on why people don't read/comprehend what they read...
#35 | |
You sound like a very intelligent person, but you are confusing the hell out of me. You say you agree to the theory that bigger is better, yet you say I'm still wrong. The reasons for why it works or why it's better have been pretty much explained by those who replied to this thread. Maybe the answers you are looking for are not in text. I would recommend you do what Jmauld said and find out for yourself. -Tires contact patch area does not vary with its width - If we take a narrow tire and make it wider, the contact patch stays the same size, but gets wider and shorter. I think what this is saying is if you take for example 205/50/16 and stretch it you still have the same contact area but the tire gets shorter. However at the same time you could just use a 235/45/16 which is alot wider but just as tall) If I'm wrong can you explain to me why? I'm just trying to understand just as much as you are. |
#36 |
ghambino, your first post read
"I would guess to increase the amount of tire that makes contact with the road, which results in more grip." which isn't very clear, that was what I was refering to; your statement could be read in different ways (while ultimately it is true that wider = better times, it also could be interpreted as inaccurate by everything written above), however, this is not a personal attack, I was merely trying to get the point across that all I wanted was more reasons of "why," not "just because there's data." |
#38 | |
#39 |
![]() Join Date: Jul 2002
You should see your lap time drop by almost a full second with the hoosier tires. The only time I've seen the A032s do well was at an autocross in Houston in August. The hoosier tires got too hot and greased up.
Allen Delta Region SCCA SM 1990 240SX SR20DET |
#40 | |
from Canada, eh!
![]() Join Date: Sep 2001
I have a good idea on how Hoosiers perform... But I won't be running them all season... They'll die before. ![]()
-> HaLo Race Car: '98 E36 BMW M3 Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#41 |
how long to the a032's last you Halo? I dont have any problem making the azenis last an entire season, and we run all winter as well. How long the a032's last for you? Also, do you think i coudl run them on the street?
#42 |
from Canada, eh!
I used the A032s only for Solo II and they are still good.. they could last 2 racing seasons.
But mine were not street driven.
#43 |
hmmm. Well now that i'm in SM,i may look into getting another set of rims for the track,and getting some ao32's
#44 |
from Canada, eh!
See, in SM, A032R aren't really competitive. They are an entry level R-compound. You'd be better off with Victoracers... (V700)
#45 |
around here we have NO competitive SM cars. I ran my last event on my ES100's and placed 2nd in my n/a 240 only .2 behind an sr powered hatch. Theres no competition in SM here, its almost too easy
#47 |
and brad, you probably have the best set up vehicle out there (Not counting allen's car), but stil SM is supposed to be a big jump from STS because of the availability of race rubber (i.e Rcompound), I have no doubt that you'll be winning SM, however (not to take away from you at all), but if everyone else ran Rcompounds like they 'should' in SM, itd be a different story. And the reason for taht is the strict rules of SCCA, half the people in SM (you and I for instance) are only there because of RUCA's (which are pretty much NO advantage in autoX) and CF hoods, not because we have 250whp and hoosiers ya know?
#48 | |
from Canada, eh!
#49 |
no you dont, what fun is that?? im in between two regions SCR and CCR (basically N. Carolina and S. Carolina). anyways, the SCR region isnt competitive at all, i attended 6 of the 8 points events and tied for first. i won 5 of the 6 i went and took a second place when a friend co-drove. CCR is alot more fun b/c we have some fast cars up there. a fully prepped neon, 2.5RS, SE-R, a Mini-S. lots of fun cars to play with. actually, on my ooold victoracers, i only got 4th, im usually 1st or 2nd. the mini and 2.5 are new, and are on Avons (FAAAAST TIRE). ive missed the last two points events though b/c i dont have any race tires. oh well. i want a tire i can autox and road race and havent found one i like yet. i either kill them at the track, or they cant hang in autox.
![]() HighTach Motorsports |
#50 |
![]() Join Date: Mar 2004
Add my name to the "not much SM competition in my area" list at least in the Maine area, when i go down to NER i expect a little more. I'm boosted but i still just run ES100s, I'm expecting Halo to give me a good ass-whoping at one of them.
Auto-x can create an odd problem for some, if your really into it, you have to mod accordingly so you dont get bumped up a few classes for adding a few little things. I know i have made that mistake before.
ROUND 2 |
#51 |
well i did the same thing. I used to run STU, but then i got RUCA's to correct my rear camber and that bumps me to SM. Thats what i think is ridiculous, i know a line must be drawn somewhere, but i think its ridiculous.
#52 |
from Canada, eh!
Yup, NER is not that bad of a region. But I think I can do much better there next time around. I dunno when that's gonna be, but for sure, I am attending the National Tour event in NER. I am wondering which other events I will attend. Let's say I have tires issues this month and I hope my "blow-by" issue was simply a human error...
#53 |
i want more race tires so bad... i wish tire rack had a GT4 package. pay 5 grand and get new tires whenever you need them. id roll on A048R's all the time!
#54 |
from Canada, eh!
Hehe... I just got confirmation...
4x 245/45R16 Hoosier A3S04 coming my way!!! woot! That will kick some serious ass. ![]() I am slowly getting there. ![]()
#55 | |
![]() Join Date: Dec 2002
#57 |
^wondering the same thing, id be very interested. Which would be the best as a street/and autox tire out of the ao32/48? I thought the 48's came in 18's only?Also, Halo, why do you have Hoosiers AND a032?
#58 | |
#59 |
from Canada, eh!
I am keeping the A032 because I won't last the whole season on the hoosiers.
and i got a3s04s because they were in closeout at 126$ each!!!
#60 |
yah, they are hella cheap right now... the 05's will be out soon. so get a lead on the hoosiers, and cruise to a championship win on the A032R's? niice strategy, Jean Todt...
