05-13-2013, 09:06 PM | #571 |
Equips
Can anyone help me with this please. Want to swap the lips around as the fronts currently have a 4inch lip compared to 3.5inch on the rear. Current specs are:
18x9.5-3 outside lip 4inch disk face 1inch inside lip 4.5inch 18x10.5 +18 outside lip 3.5inch disk face 1inch inside lip 6inch so it would be 18x9 and 18x11 if i swap the lips but what would the offset be? Thanks for any help |
05-26-2013, 06:44 AM | #573 |
05-28-2013, 05:22 PM | #575 | |
If you have equips, vsxxs or rezaxes, you can cheaply and easily relip them by just buying new outers. |
09-01-2013, 04:24 PM | #580 |
I'm terribly curious, anyone have any idea what it would take to widen a set of Volk GTUs? I have a set of square 17x8 +27, and I want at least 9 front 10 rear, and it'd be nice to have some lip. They're two piece, so everyone's been telling me I'm out of luck, but can't hurt to ask.
10-09-2013, 06:12 PM | #581 |
OK it is my understanding than on a three piece wheel if you add to the barrel the offset will go up and if you add to the lip the offset will go down. Here's my stupid question of the day. what if the wheel has been flipped, is the barrel and lip "position" on a wheel that makes the offset go up or down or does adding to the original lip make the offset go down no matter where the lip is located on the wheel?
10-11-2013, 01:41 AM | #582 |
The offset is the difference between the mounting pad of the wheel and the wheel's center line. So if you flip the face, generally, the result is an extremely negative offset.
10-11-2013, 04:25 AM | #583 |
does any one know what barrels fit ssr vienna kreis 18's? the barrels are going to be split and machined, just looking to redo the outer barrels. ive tried searching but i cant find any info on bolt patterns or what lips fit.
11-09-2013, 01:05 AM | #584 |
Sorry to ask again, but anyone have any insights into widening some Volk GTUs? They're 17x8 +27 square, I'd like to make 'em to like 9 +12 and 10 +15 or so. Anyone know if they're a welded two piece or if I can just get barrels and lips, and if I can just get barrels and lips any suggestions where to go?
11-11-2013, 12:34 PM | #585 | |
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
11-13-2013, 11:38 AM | #586 |
Bought these Shallens a year ago and was planning on getting new lips and barrels but found out only after they arrived that the AX's are two piece welded. So I had my uncle who is friends with the owner of Alberta Wheel repair up in canada convince him to weld in new rings on them, inside and outside on the rears was the thing no other company would do for me. However I do have to rock the welds on the lips haha.
Front 18x8 +30 -to- 18x10.25 +1 Rear 18x8 +30 -to- 18x11.75 +8 Usually I just refer to them as 10's an 12's.
https://www.facebook.com/HeatBloom |
11-14-2013, 09:18 PM | #590 |
11-14-2013, 10:10 PM | #591 |
Trader Rating: (22)
Feedback Score: 22 reviews
Your wheels are looking tough. Very nice.
What shop in NJ did the widening work? I assume these were welded rims and had to be cut apart and new custom lips made...?
11-15-2013, 02:16 AM | #592 |
took a set of work vs-xx 17x7.5 +35s
got some 3" & 4" lips which changed them to 8.5 +16, 9.5 +3
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
11-26-2013, 12:06 PM | #593 |
Hey guys, in the process of rebuilding and refinishing my 19" ssr vienna courage wheels and cant seem to locate hardware for them. Can someone point me in the right direction of a vendor or company stateside that has the bolts i'd need? Thanks!
11-27-2013, 12:38 PM | #594 |
There's a few spots and all have different pricing but here are a few I know of:
www.imadeskidmarks.com www.vrmotoring.com www.inifintewheels.com Good luck! Sent from my iPhone using Tapatalk
12-22-2013, 12:06 PM | #596 |
Don't know if anybody will know here, but does anyone know if VS-XX lips will bolt up on a VS-KF? I'm trying to build a pair of KF's, but can't find lips anywhere
12-22-2013, 01:41 PM | #597 |
^^^^^ I'm sure someone more qualified will chime in but basically VSKF's are welded 3 piece wheels unlike Equips or VSXX's which are true 3 piece wheels. In order to resize them, you have a couple of options. The most effective option in my opinion would be to have them be sent to a company like Wheelflip or VR Wheels. They will cut the welds with a lathe and then they rebuild them with VSXX or Equip lips. If your wheels already have the weld cut or you opt to have a machine shop cut them locally then you can order the VSXX/Equip lips yourself, which do fit to answer your original question. I hope this makes enough sense, I'm typing from my phone.
12-22-2013, 01:42 PM | #598 |
Does anyone know where I can get BBS wheel bolts/rivets that holds the wheels together? I need 20 of them. I checked VR wheels and they don't seem to have any available right now.
-Don |
12-23-2013, 02:22 PM | #599 |
Cool.
To you guys who have rebuilt wheels, what would you recommend for someone who has never done it before? I'm about to pick up a 19x8 +38 KF and a local shop can lathe the weld, but I'd like to try actually putting it all back together. |
12-23-2013, 06:59 PM | #600 |
Anyone ever Build Some 3pc 19" Work Meister S1's Into Flat Lipped 18" sizing combos? I wanna see Pics if so. Im thinkin about buying a set of some beat up 19s and rebuildin them. Wondering what this looks like beforehand. I thought it might look really good.
Sent from my SGH-T989 using Tapatalk 2 |
