#6151 |
![]() Join Date: Nov 2003
![]() ![]() ![]() Feedback Score: 7 reviews
Can I use the JDM DC5R Integra Type R (RSX Type R) brake kit (Calipers, pads + rotors) for my S14?
My friend has a set, they are made by Brembo, and apparently they are the same type that is used on the 350Z and EVO. They are the same pads as well; he couldn't order the DC5R pads from Honda of America, but he ordered 350Z pads and they fit and worked. If it does work, what would I need to get it done? I'm currently on stock S14 brakes with SS brake lines, that's it. I'm guessing I would need the 300ZX BMC, probably custom brake lines, and a mounting bracket of some sort (like how other 240s fit EVO brakes on their S-chassis) Any thoughts? Thanks in advance.
268generation.com -United for His Renown- |
#6152 |
![]() Join Date: Jan 2009
So I just got my crankshaft back from the machine shop and the guy said he went 10 under, what size bearings do I need and where do I get them?
Jessefuckinwood Street Prowl |
#6153 | |
![]() Join Date: Dec 2010
that said, how much would you pay for the brakes? i mean ive seen people pay WAY too much for those damn DC5R brakes, and they were used, when in comparison you can get into a full wilwood brake kit for your car for just as much brand new...think about it |
#6154 |
![]() Join Date: Dec 2007
whats the max power output with the following set up
-s13 redtop t25 -fmic -full exhaust turbo back -apexi power intake -apexi power fc L-jet 12psi of boost I am forgetting a few things oh yea car is running on a 50 50 mix of 91 and 100oct so whats the most power you think can be reiliably made on this set up with a really really good tune I am going to be having my car tuned at shadoworks and I plan in the future on some 550cc injectors and a 18g but that might be awhile thank you |
#6155 | |
My friend will give me a good deal on them (pretty much at his cost, when his brother bought them when he was in Japan), but I'll need to buy rotors, brake lines, and the 300ZX BMC. I'm sure I need at least the rotors and BMC. My brakes should need to get replaced by the end of this year, I already have a brand new OEM replacement set of pads and rotors, I'm just wondering if it will be a hassle to upgrade to his DC5R set and sell my OEM replacement set.
#6156 |
![]() Join Date: May 2009
![]() Feedback Score: 27 reviews
I cannot get my timing right at all, the marks are all correct and the cas was installed correctly. The only way I can get 15* is when the cas is all the way clockwise. Is my cas bad?
#6157 |
Yea it could be a problem with your cas. You might want to check that out, also just be SURE that everything is installed correctly because I had the exact same problem and it turned out to be a problem with the installation even though everything seemed good.
#6161 | |
My question: I have a power steering leak at the banjo bolt above the pump, can I use silicone tape or would that get eaten up? What would the be the best way to seal this?
Thanks, Brad Quote:
#6162 | |
and I am praying for like 240hp if I can put down 240whp I would really be impressed. Like I said I do plan on going with a 18G that will pop me up into the low-mid threes |
#6165 |
![]() Join Date: Dec 2003
I can tell you i have like 3 complete sets of coupe seat belts if you need.
But I dont think the will work since hatch rear set ups are completley different.
![]() **CoUpe LOve** Member #00 |
#6167 |
If im installing an aftermarket header and the egr pipe wont fit onto the header due to angle can i just plug up the egr pipe with no problem or do i need to do the complete emissions delete if i plug it? Just wondering if there will be any ill effects
thanks |
#6168 |
AFC #1
![]() Join Date: Oct 2003
Won't help on a banjo bolt. Oil goes through the bolt. You need new copper washers on both sides.
#6169 |
![]() Join Date: Nov 2007
so I just bought a s13. and it's 4 lug.
going 5 lug. and it looks like I would have to run s14 suspension in the front? it says ichiba hubs are direct bolt on...does that mean you can still use s13 suspension? ...................PLEASE PM ME.................. |
#6170 |
![]() Join Date: Oct 2010
180sx running/postion light pigtails, i cant find them anywhere online.ive read before theyre the same as the us side marker pigtails but therye not. has any one made/fabed up pigtails?
#6173 |
Do Nismo thermostats have a break in period???
It was not opening until the car would almost completely over heat and then after that it would be fine and it seemed you couldn't possibly get the car to over heat. Now It seems as if the thermostat Is Working intermediately. Did I get a bad part or what??? |
#6174 |
![]() Join Date: Jan 2010
![]() Feedback Score: 10 reviews
1. what oil should i run in my twin cam
2. can you put to much tranny fluid? if so what could happen? how much are you supposed to put? i put in 4 bottles of royal purple is that to much it makes a kinda loud noise when i hit the gas and its louder then my exausht and my exausht has 2 4.5'' tips so i think i put in to much fluid is that possible? thanks for the help |
#6175 | |
S12 || KN13 || S13 || B16 |
#6178 | |
Trader Rating: (39)
![]() Feedback Score: 39 reviews
lmk how that goes ![]()
IG - allen.kerose |
#6179 |
My 240 recently got stolen and I just got it back but the brake lights dont work the pigtail and bulbs are intact but it's only needs the rear side maker bulb and socket/pigtail could this be the reason?
