Old 06-03-2016, 02:28 PM   #6181
Sky80
Sky80's Avatar
Sky80 is an unknown quantity at this point
Originally Posted by 2stepGoesPowPow View Post
Dont feel like dumping the $2500+ to put my cd009 in this chassis. Ready to upgrade to a different car.
Gotta pay to play with this motor, people often look past this when starting and then we end up with lots of part outs
'98 Kouki Build in Progress
'10 Subaru Legacy 2.5GT
Sky80 is offline   Reply With Quote
Old 06-03-2016, 02:55 PM   #6182
2stepGoesPowPow
2stepGoesPowPow's Avatar
2stepGoesPowPow is an unknown quantity at this point
Lol i know this.. Haltech platinum sport 2000, id 1300, ball bearing gen 2 6266, and much more all purchased new. Ive lost count how much money ive dumped into my car. I spared almost no expense cosmetic and performance wise. Im just bored of the chassis and want to put the swap in something nicer than a 1991 240sx.l ive had the car for nearly 5 years, driving it around with the 2jz for 2 & 1/2 years.
Follow on Instagram For The Latest Imported Inventory!: @2JOHNZ_GTE
2stepGoesPowPow is offline   Reply With Quote
Old 06-05-2016, 04:13 PM   #6183
kkaleher
kkaleher's Avatar
kkaleher is an unknown quantity at this point
Ok sorry for the long break there, i had an injector go out. Decided to just switch over to top feed and an aftermarket radiator. Starting upping the boost and at about 16psi i couldnt get traction in 3rd gear which made tuning difficult. So, i got some drag radials amd now it hooks, boost is at 20psi!
Anyway its still running hot after driving down the interstate for 30min and i have to pull over, especially if i get on it. I got rid of the crappy fan bracket/shroud and put the fans directly on the radiator, this seemed to slightly help. Added more cooling panels, and put on a turbo blanket which helped as well. Temps are still creeping, takes longer but still. I guess now its time for better fans since i just run dual 12in (?) Fans i got off summit.
S13- 2jz, 370z 6spd, PT6262
Nissan Master/GT-R Technician
kkaleher is offline   Reply With Quote
Old 06-05-2016, 04:20 PM   #6184
NOLAGG
NOLAGG's Avatar
NOLAGG is an unknown quantity at this point
Spal fans only.........lol made in Italy what do you expect?but all jokes aside spal are the best fans all around.
NOLAGG is offline   Reply With Quote
Old 06-05-2016, 05:11 PM   #6185
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Do these dimensions match your radiator?
https://www.jaycorptech.com/p-57-spa...th-shroud.aspx
https://instagram.com/e_lemonation/: @e_lemonation
Old 06-05-2016, 05:13 PM   #6186
Mister.E
Mister.E's Avatar
Trader Rating: (53)
This is what I have, but the SPAL's move more air. The problem with that particular SPAL setup is that it's not a slim setup.
https://www.flex-a-lite.com/electric...ctric-fan.html
Old 06-05-2016, 08:04 PM   #6187
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
Does anyone use the B3 plug for the 2jz-gte vvti ecu? Looks like everything is for the automatic transmission other than pin 12 and 16, or would you recommend depinning automatic stuff?
Pin 12 is Exhaust Bypass Valve
  • This pin is used to control the VSV which is used to open / close the Exhaust Bypass Valve that is a component of the sequential turbo system. The Exhaust Bypass Valve allows exhaust gas to pre-spool the rear turbocharger prior to it coming online as part of the sequential turbo system.
  • This pin is connected to Ground inside the ECU as required to turn the Exhaust Bypass Valve VSV ON allowing pressurised intake air to open the Exhaust Bypass Valve. One side of the VSV should be wired to this pin and one side of VSV should be wired to battery voltage (Main EFI Relay switched).
Pin 16 is the Fuel Pressure Up Vacuum Switching Valve
  • This pin is used to control the VSV which is used to increase fuel pressure during hot soak starting.
  • To reduce the possibility of fuel vapour formation in the fuel rail during starting from hot soak conditions the Fuel Pressure Up VSV is used to increase the fuel rail pressure for a short period of time after hot soak starting. This pin is connected to Ground inside the ECU as required to turn the Fuel Pressure Up VSV ON which vents the fuel pressure regulator reference to atmosphere resulting in increased fuel rail pressure. One side of the VSV should be wired to this pin and one side of VSV should be wired to battery voltage (Main EFI Relay switched).
Better image:
http://wilbo666.pbworks.com/f/131581...U%20Pinout.png
bova17 is offline   Reply With Quote
Old 06-05-2016, 09:06 PM   #6188
kkaleher
kkaleher's Avatar
Yeah i may have cheaped out on fans .... damnit. Went on a sunday cruise with a buddy today who has a 2014 camaro ZL1 with a cam, ported blower, head work and full exhaust on e85. He barely got me on a highway rip, with a little more boost and practice ill def get him lol. Coolant temps stayed around 200 today for that
Old 06-06-2016, 06:54 AM   #6189
EnvisionMore
EnvisionMore is an unknown quantity at this point
You're using a koyo rad right? Any modifications to make it fit?
EnvisionMore is offline   Reply With Quote
Old 06-06-2016, 07:38 AM   #6190
Mister.E
Mister.E's Avatar
Trader Rating: (53)
No mods at all. It actually fits the S14 koyo perfectly.
Sent from my iPhone
Old 06-06-2016, 04:37 PM   #6191
TJ_240
TJ_240's Avatar
TJ_240 is an unknown quantity at this point
If you're on a highway you have air assisting your fans, so the fans can't be your problem, at least speaking highway, if you got all the bubbles out, good thermostat and pump, than you should start thinking about head gasket, but you may already know that.
TJ_240 is offline   Reply With Quote
Old 06-06-2016, 09:24 PM   #6192
kkaleher
kkaleher's Avatar
I have a new pump on a fresh engine, no sign of air pockets and im not losing any coolant so i doubt its a HG. I run pusher fans and theres also a 4in thick precision FMIC out front, so the air on the hwy probably doesnt get thru the radiator so well. Its gotta be the cheap pusher fans or the KA koyo radiator ... or both.
Old 06-06-2016, 09:26 PM   #6193
kkaleher
kkaleher's Avatar
Oh yeah if you leave the hood its fine too, problem solved! Jk
Old 06-06-2016, 09:28 PM   #6194
articzap
articzap is an unknown quantity at this point
Have you put an air damn under the car to drive air up in to the radiator?
articzap is offline   Reply With Quote
Old 06-06-2016, 09:37 PM   #6195
Sky80
Sky80's Avatar
^^^ he already knows what his problem is. Replace the KA radiator for one for an SR so that it forces the coolant to utilize the entire surface area of the radiator and ditch the pusher fans... I can't believe how many people are still trying to run pusher fans and then complain about them
Old 06-07-2016, 12:54 AM   #6196
TJ_240
TJ_240's Avatar
Smile
Personally I've never liked the pusher fan setup, i'd rather get as close as it comes to a supra setup with cross flow rad. and no pusher fans, like you said, fmic plus pusher fans on hte way, theres gotta be some kinda hesitation there, I'm currently on the middle of my build (2JZGTE s13 hatch btw) i'll be posting pics up once I figure out how haha.
Old 06-07-2016, 08:56 AM   #6197
stevecorrado88
stevecorrado88 is an unknown quantity at this point
Guys I need help. I really need a iacv or iscv for a 1jzgte. I've been searching and can't find shit.
stevecorrado88 is offline   Reply With Quote
Old 06-07-2016, 10:57 AM   #6198
kkaleher
kkaleher's Avatar
Anyone have a spare upper coolant neck from a 2jz i can buy $$$$$$??????? $$$$$$ I need to replace mine and go with a sr20 radiator amd crossover pipe
Old 06-07-2016, 11:36 AM   #6199
stevecorrado88
If you use a ka radiator you don't need that donkey dick of a cross over. Just trim the pipe so it's not bending that way.
Old 06-07-2016, 05:56 PM   #6200
kkaleher
kkaleher's Avatar
Read the previous posts, i have a KA koyo rad. Some people have had problems not using a cross flow radiator. I already hacked my coolant neck which is why i need another.
Old 06-07-2016, 06:02 PM   #6201
stevecorrado88
Haven't had any over heating or any cons of using a mishimoto ka rad. I had to switch rad caps to my old greedy one cuz it's stronger.
Old 06-07-2016, 07:53 PM   #6202
TJ_240
TJ_240's Avatar
I've seen these blocked off and idle adjusted on the throttle set screw.
Old 06-07-2016, 08:26 PM   #6203
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
2JZGTE Swapped S-Chassis thread
I'm actually running a derale pusher fan on my swap and that one single fan keeps my temps perfect in south Florida
BiG MiKE86 is offline   Reply With Quote
Old 06-07-2016, 08:38 PM   #6204
stevecorrado88
That's all fine and dandy That's what I'm doing now but when it's cold out it doesn't like that idle. So I have to hold the gas until it warms up for a min.
Old 06-07-2016, 10:31 PM   #6205
Mister.E
Mister.E's Avatar
Trader Rating: (53)
I'm gonna just leave this here: http://www.powerhouseracing.com/p-48...r-2jz-gte.aspx
Sent from my iPhone
Old 06-07-2016, 11:09 PM   #6206
TJ_240
TJ_240's Avatar
post a picture, i think if you search aliexpress hard enough you'll find a kung fu one
Old 06-08-2016, 06:28 AM   #6207
EnvisionMore
I believe CX Racing sells one.
Old 06-08-2016, 08:47 AM   #6208
kkaleher
kkaleher's Avatar
Originally Posted by BiG MiKE86 View Post
I'm actually running a derale pusher fan on my swap and that one single fan ]
My dual pusher fans are derale, what radiator do you run?
Old 06-08-2016, 09:48 AM   #6209
kkaleher
kkaleher's Avatar
NM i stalked you and see its a SR20 style koyo radiator... damnit lol
Old 06-08-2016, 11:30 AM   #6210
BiG MiKE86
BiG MiKE86's Avatar
Yep [emoji16] that radiator, TRD thermostat, Toyota coolant/distilled water, and 1 fan keeps me cool
