#6245 |
Can someone tell me what I would need to replace on my front suspension to get stock alignment back and to have less wear on my front tires? I've got lowering springs/shocks, and when I run my 17x9 Fn01rc's up front, the tires wear out like hell. Its all stock besides some dmax pillow ball tension rods, can anyone tell me where to start so I dont have so much front tire wear? What parts can I replace to get it to the alignment shop and have a good stock front end?
#6246 | ||
take it to pepboys, they do it for free. A good scan tool costs a lot and isn't worth it. how often do you throw codes? Also, the ecu does it STOCK Quote:
street dancer. GLEAM |
#6247 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
#6248 |
I NEED a audio wiring diagram for S14 (97 USDM), for the speaker wiring. SEARCH IS NOT WORKING O_O
97 Starfire Blue/93 Coupe, Black-SOLD 98 Starfire Blue-Auto, 1 owner, 102k |
#6249 |
google 1997 s14 factory service manual
#6250 |
Question:
I recently purchased a 300zx Z31 Brake Booster & Master Cylinder from a 1987 non turbo 5 speed. I am putting it into my 95 S14 5 Speed non abs. I'm pretty sure the BMC fits but will the booster also work for me? ebay link for pics Nissan 300zx Z31 Brake Booster & Master Cylinder 1987 | eBay |
#6251 | ||||
can get better gas mileage than KAs depending on how you drive not cheapping out on maintenance and clean install is key to a trouble free SR find someone with Nistune I've use my friend's set up to trouble shoot problems monitor sensors and systems in real time Quote:
while you're at it Quote:
looks like it takes a good amount of room and may get in the way of things looks like it'll bolt up though |
#6253 | |
Brandon |
#6255 |
10w30...i use that on my ka and sr. thats in 100+ degree heat in Texas
#6256 |
![]() Join Date: Apr 2007
i'm having an exhaust made for me, will a 3 inch exhaust with slight bends and a muffler in the midsection be relatively quiet on a n/a ka? or should i get like two resonators? lol.
Full Time Student for Life |
#6257 | |
Trader Rating: (58)
so yes, resonators or race mufflers may help
#6260 |
need help on some heim joints
i just put them for sale and i have got many pm's of members ready to buy but i need to if the joints are good should they be able to move around with very little force http://zilvia.net/f/sale-items/38699...heck-brah.html please let me know i dont want to sell them until i find out if there good
looking to buy ka24de gaguge cluster |
#6262 |
#6263 | |
Trader Rating: (58)
IIRC The Z31 15/16 Master Cylinder is the largest MC that used a single diaphragm booster. Thread it in and find out? Should...
#6265 | |
Trader Rating: (58)
With that said the Z32 ones require 'fitting'...whereas the 240sx ABS cars do not...keep that in mind as well. Also, the booster needs to be from an ABS car...Automatic/Non ABS cars used the single diaphragm just manual/non abs cars.
#6266 |
![]() Join Date: May 2011
Just bought a s13 with s13 sr20det, a day later its running like shit, idles at like 1200 or so, has low power, sputters bad if i try to drive it. what should i be looking at here? maf? injectors? idk if it matters, but i hit a damn hidden pot hole and it ran like shit right after, i was only doing like 3mph though...
#6267 | |
Trader Rating: (58)
read the faq's it could be anythign
#6268 | |
#6269 |
Trader Rating: (58)
Old Setup:
Front- 300zx 30mm Aluminum Calipers, with Carbotech Xp12 pads 13" Cobra Rotors and Adapter Bracket Rear- Stock S14 Calipres, Carbotech XP12 pads Altima 11" rotor upgrade, Z31 caliper brackets 15/16 Z31 Master Cylinder Stock Booster Current Setup Front- Forged Wilwood 4 piston Superlites, with Carbotech Xp12 pads DefSport Conversion Bracket and Hat (DefSport 12.2" Wilwood Superlite Front Brake Kit GB Part 2!!! - Page 2 - Nissan Road Racing Forums) Wilwood Ultralight 12.2x1.25 caliper (huge differnce over the Cobra/Z33) 15/16 Z31 Master Cylinder Stock Booster Rear- Stock S14 Calipres, Carbotech XP12 pads Altima 11" rotor upgrade, Z31 caliper brackets Pics of new setup: ![]() ![]() ![]()
Want Air Conditioning in your SR20 Swapped car? Check out www.sr20acbrackets.com for more information! Quest Alternator Conversions for SR20! Check my Group Buy! Tired of lousy internal gates? Go external wastegate with one of my manifolds, Check out my group buy Last edited by codyace; 05-29-2011 at 08:49 AM.. |
#6270 |
Nice, and all this with a 15/16 bmc and stock manual booster.? I'm currently upgrading brakes on mine. I was debating on keeping stock rear calipers or not, but right now I think im just going to do similar to yours. 15/16-manual booster, z32 30mm calipers and rotors, stock rear with altima rotor. You say the pedal feel is same to stock?
