Old 11-10-2016, 05:50 AM   #6481
Da Beast
Da Beast is an unknown quantity at this point
a340 Collins - s14
Good day guys from South Africa. just wanted to find out. has anyone tried the Collins a340 adaptor with the s14 chassis? what clutch, mounts, flywheel, did you use
thanks
Da Beast is offline   Reply With Quote
Old 11-10-2016, 04:42 PM   #6482
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
Originally Posted by corkscrew View Post
Anyone have clearance issues with the oil filter and engine mount? Mine is probably 1/16 of an inch away...
yup very close. able to get on and off though. just fits.
Black240Ct is offline   Reply With Quote
Old 11-10-2016, 06:20 PM   #6483
kkaleher
kkaleher's Avatar
kkaleher is an unknown quantity at this point
Originally Posted by Black240Ct View Post
Im running the maverick kit on my 1jzvvti, I have a modified 350z shifter now. Im currently swapping chassis to a s14, planning on changing to the Gktech shifter. hope it is close to oem shifter location on FreedMotorsports mounts. will post pics as it goes in the car/ what cutting is involved.
I like not trimming the bellhousing and swaping to a 350z clutch, has been working great this season, but adding an adapter plate and not cutting the bell housing of course pushed the shifter location further back.
I emailed maverick and they said they dont offer a custom shifter to put the shifter in factory location on a s13 with a 2j. Im gonna need it to be in the stock location. Guess i may need to look into other options.
Also the 6spd i acquired is the rev match 370z 6spd. Hope its the same as a regular 370z 6spd other than the sensors for the shifter. Only #s i see on it is CD9
S13- 2jz, 370z 6spd, PT6262
Nissan Master/GT-R Technician
kkaleher is offline   Reply With Quote
Old 11-13-2016, 12:02 PM   #6484
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Hope this makes sense...having trouble putting my thoughts into words
Ok, for those with a stock 1j and/or 1j vvti; how much boost are you guys running and how are you controlling it? My wiring specialties harness didn't have the oem boost solenoid plug, so I'm running a GFB bleed style MBC which only allows me 11ish psi. My internal wastegate pressure is only about 5-6psi. Any way I could jump the oem solenoid to stay open, then tee the MBC into that to get to 14-15psi?
corkscrew is offline   Reply With Quote
Old 11-13-2016, 08:19 PM   #6485
NOLAGG
NOLAGG's Avatar
NOLAGG is an unknown quantity at this point
Finally went from my idle temp at 198-203 to a solid 178-180 ish and on the highway no fans on I'm at 168-172 ..
Basically added a bleeder valve to my heater core line (highest point in the coolant system), mishimoto 168° thermostat , and 150amp sequoia alternator to fully power my spal 20 amp each fans.
Car runs so much better and cooler!!!!
NOLAGG is offline   Reply With Quote
Old 11-16-2016, 05:21 AM   #6486
EnvisionMore
EnvisionMore is an unknown quantity at this point
Anyone running IS300 fans? Or know if they would fit?
EnvisionMore is offline   Reply With Quote
Old 11-17-2016, 06:38 PM   #6487
corkscrew
corkscrew's Avatar
Boost leak? This is 3rd gear about 3500 1/3 throttle. As the noise changes, the AFRs go from rich to lean. WOT is fine and so is cruising. Stock boost solenoid deleted, running 11psi on a manual boost controller
http://www.youtube.com/watch?v=PfxSY1AvbxA
Old 11-21-2016, 05:53 PM   #6488
JonathanPrem
JonathanPrem's Avatar
JonathanPrem is an unknown quantity at this point
Hey guys,
Is -6 AN fuel line big enough to support 650whp 2jz or will i need -8An Feed?
IG-jonathanprem
JonathanPrem is offline   Reply With Quote
Old 11-21-2016, 06:24 PM   #6489
IBoughtAS13
IBoughtAS13 is an unknown quantity at this point
-8 feed. -6 return. Done.
IBoughtAS13 is offline   Reply With Quote
Old 11-23-2016, 05:53 AM   #6490
corkscrew
corkscrew's Avatar
Putting this here for those that would be interested in a clean OEM+ BOV setup. Just ordered mine
http://www.jzx100.com/forum/topic/16...t-bov-adaptor/
Old 11-30-2016, 09:42 AM   #6491
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Any of you guys know what the limit is with an SAFC as far as injector size that it can compensate for?
Is it 880cc?
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 11-30-2016, 10:46 PM   #6492
alwyzDTF
alwyzDTF's Avatar
alwyzDTF is an unknown quantity at this point
Anyone know who can make a 2jzge vvti NA-t harness to s14 chassis?
alwyzDTF is offline   Reply With Quote
Old 12-01-2016, 09:44 AM   #6493
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
Originally Posted by kkaleher View Post
Hows my setup goin hmmmm, of course there has been more speed bumps. so here you go:
*Got the over heating issued fixed by running FAL440 pushers, its amazing the fans actually will shut off cause coolant temps drop back down to 170.
*Tried to get my dyno tune on and found fuel pressure dropping up top on a single walbro 450lph pump. Tried adding a 2nd feed line and filter, still dropped psi up top. Rebuilt my aeromotive fuel pressure regulator cause it was leaking vac/boost but still no change. Ended up adding a 2nd pump in tank. Upgraded the wiring on the S13 pump hanger cause that tiny 25yr old corroded shit had no chance. POW I have all of the fuel pressure now!
*So im out cruising one night and my lights go dim and the laptop shows 10.8V at idle and 12.8 at 2000rpm, FML what now! Apparently the stock 2j alternator cannot handle the extra load of these kickass fans, dual pumps, stereo, etc. So now I just put on a Tundra alternator and POW all of the voltages are mine again!
Just trying to get back to the dyno! Running great tho!.... for now
can you please show a pic of the wiring you have done to the hangar??
supersayianjim is offline   Reply With Quote
Old 12-01-2016, 03:44 PM   #6494
HypnoFish
HypnoFish is an unknown quantity at this point
There are a lot of shifter options available for the z trans. Look into serial nine, or CBF performance. Also if you are running the suprastore adapter or the new auto bell collins adapter the trans choice doesn't matter.
HypnoFish is offline   Reply With Quote
Old 12-01-2016, 07:45 PM   #6495
kkaleher
kkaleher's Avatar
[IMG][/IMG]
This is my ghetto hanger, but hey it works lol. I got a bulkhead fuel cell connector off summit
Old 12-01-2016, 07:49 PM   #6496
kkaleher
kkaleher's Avatar
Thanks for the info, hopefully i can make this cd009 work since i already have it and really like the shifter feel on these.
Old 12-02-2016, 06:35 AM   #6497
JonathanPrem
Anyone have experience with Russell quick connect fuel fitting?
Anyone have luck finding 5/16" to -8an fitting. All I can find is 5/16" to -6AN
IG-jonathanprem
Old 12-02-2016, 06:39 AM   #6498
supersayianjim
[IMG][/IMG]
What are u doing about the level sender wire?
Old 12-02-2016, 07:03 AM   #6499
cbfperform
cbfperform is an unknown quantity at this point
The CBF performance shifter will put it in the stock location. www.cbfperformance.net/store
Sent from my LG-D850 using Tapatalk
cbfperform is offline   Reply With Quote
Old 12-02-2016, 08:40 AM   #6500
HypnoFish
You'll be able to get it to work no problem. I'm waiting on a few parts for mine so i can put it in.
Old 12-02-2016, 11:44 AM   #6501
kkaleher
kkaleher's Avatar
I removed the 2 wires for the pump from the top of the sender completely so there were 2 holes. I then drilled 1 larger hole in the middle of those 2 smaller original holes and welded to fill in the extra gap. I had to do a little grinding and painted it so you cant tell.
For the sender i just used the factory wires and sending unit , i left that part alone. There were 4 of those little white porcelain plastic things, ... i left 2 for the gauge sender there basically. The 2 red power wires for the fuel pumps are on seperated fuses and relays. For the ground i used a 12g wire to the hanger inside the tank and then put a 12g wire grounding the top of the sender to the main chassis ground in my trunk.
Old 12-03-2016, 09:34 AM   #6502
greenpat01
greenpat01's Avatar
greenpat01 is an unknown quantity at this point
Hey guys, im about to order my bracket + mount for my swap (2jzgte 240sx s13) from xcessive !
But before I order, I need to decide which mount I want ..
Xcessive offer 2 mount set,
1: series 3,(N-S-UMM-S3) that is the 'oem' replacement
2: series 15,(UH-UMM-S15) they lower the engine by 10mm (3/8') so I can get better hood clearance for sure ...
Does anyone ever use the series 15 with jz swap ??
How is the oil pan ---> subframe/steering rack clearance ?
Thanks for your inputs guys
greenpat01 is offline   Reply With Quote
Old 12-03-2016, 11:05 PM   #6503
driftshark
driftshark is an unknown quantity at this point
Anybody know someone wanting to sell free engineering mounts? I have a gte with a v160 and need those mounts specifically, i cant find any other ones. Also, is it easier to just swap to a single turbo right away, motor is 100% stock twin turbo right now.
driftshark is offline   Reply With Quote
Old 12-04-2016, 07:05 PM   #6504
Koukiii
Koukiii is an unknown quantity at this point
I have the same goal in mind for my build but with a CD009 trans. From what I read it is way more convenient to just go single turbo from the start. Stock twins are hard to pull out once in the engine bay and they could already be on their last legs.
From what I gather you could run around 400whp with a completely stock ECU, injectors, pump, single turbo on low boost. Thats what I'm gonna do until I can afford a 2k fuel system and 2k standalone.
Koukiii is offline   Reply With Quote
Old 12-04-2016, 07:08 PM   #6505
240sxrb30
240sxrb30 is an unknown quantity at this point
I got the v160 mount from them if u still need it
240sxrb30 is offline   Reply With Quote
Old 12-04-2016, 07:28 PM   #6506
driftshark
yeah do you have the whole set or just the tranny? Pm me, yours is full
Old 12-04-2016, 07:33 PM   #6507
driftshark
Thats decent. What harness are you using? I'd like to get a piggy back or safc and go single. Seems to be worth spending the money and doing the single right away. What are you using for a intercooler/rad?
Old 12-06-2016, 01:02 PM   #6508
240sxrb30
Hey I inboxed u bout that mount
Old 12-06-2016, 05:24 PM   #6509
Black R
Black R's Avatar
In order to save time and $, I initially just kept the stock twins and drove them at 14psi for like a year.
When they died, a buddy pulled them out with the motor in the car pretty easily.
Couple hours and done.
Old 12-12-2016, 11:28 AM   #6510
korance
korance is an unknown quantity at this point
I read some where that can bypass the limp mode by removing temprature sensor for insaide the engine .is it true ?
korance is offline   Reply With Quote
