#6781 |
Going to check that out tonight along with changing the plugs and re gapping them. The ones I have now are fouled and I never changed the gap out of the box apparently -_-
#6783 |
Won?t go over 4500 even with very light throttle input. Negligible little things found under boost leak test and tightened everything up. Leaning towards maf as well, trying to find one to try out
#6784 |
Trans tunnel with cdpro
Any fellas that put a 2jzgte with the Serialnine (Serial9) CDPRO bellhousing in the 240sx S13. Do you have to beat the trans tunnel for it to fit or does it clear the tunnel with no issue? I know the Stock one needs finesse but not sure about the CDPRO one because it is smaller in size. Having a hard time finding information on fitment. I have the Excessive mounts.
#6785 |
![]() Join Date: Sep 2012
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
It looks identical to the Fisch housing, I'd go with whatever information they have on theirs. Its a C-hair shorter than a A340 housing/adapter plate combo. minor firewall clearance needed, you're going to beat the shit out of your trans tunnel the same amount regardless due to the actual transmission size.
#6787 |
![]() Join Date: Sep 2014
![]() Feedback Score: 23 reviews
Anyone know the part numbers for the S14 heater hoses to 2jz? From the firewall to the engine. I saw the part numbers a long time ago, wanna say they were Dayco hoses but not sure. Anyone know this?
#6789 | |
Goleby?s, Xcessive, etc are a few that utilize rubber/urethane. With that said, in-line 6?s are naturally balanced, so even with solids, it would probably be smoother than a KA or SR.
#6790 | |
But if you make the bracket etc can't u fit rb25/26 engine mounts or orginal 1/2jz mounts ? |
#6791 | |
I'm not looking to "modify" anything. Just want it right, right out of the box. |
#6792 |
![]() Join Date: Nov 2009
hey guys, does anyone have a pic of their dakota 8 rpm signal converter setup for a vvti 1j into s14? i'm using the IGF wire as a source from the igniter to input to the dakota
just cant remember what position i need the green switches in and also which output to use on the actual unit.
http://zilvia.net/f/builds-builds-on...1jz-build.html |
#6793 | |
Are the vacuum valve and the variable steering valve the same? What does the valve do? |
