#661 |
![]() Join Date: Apr 2004
What's the width on that wing?
I think it looks good. Seems to have a good airfoil shape from the pics. You tried playing with the angle of attack at all? Big seat of the pants feel? I'm currently wingless... mulling it over in my mind if it's a big difference in feel. |
#665 |
![]() Join Date: Dec 2002
ummm yeah, i miss my cars a lot
![]() did some work on the s13 gauge cluster setup this should be the final product ![]() did the gauge cuts but haven't placed the defi controller or volt readout.. ![]() its 1/4" acrylic that will be wrapped in 2-way stretch black suede, should look pretty spicey. the LED voltage readout is green to match defi gauges lit up ![]() and i got to drive aubre's car on sunday after we put on the new ma knuckles and front susp. stuff along with tomei manifold, pretty damn quick for stock boost on a 28r! ![]() car feels pretty damn good and the angle is hilarious, once again, thanks to MA-MOTORSPORTS!!! ...ls1 teardown and rebuild coming very soon
www.stewartleask.com |
#667 |
the deck i'm trying on at this point in time is 1750mm wide d-drug
got the cluster all finished! ![]() gonna wrap it up in suede and toss it in hopefully sometime this weekend!
#668 |
![]() Join Date: Sep 2004
stu I feel like you got to pick every good genetic trait on the perfect woman and the first time you fucked her turns out she had a bad vagina.
I wish you luck getting this piece of shit back together my man lol. |
#671 |
finally finished
![]() ![]() off to go pull the ls1, ta-ta!
#673 |
![]() Join Date: May 2006
Damn, looks awesome! Definitely cooler than straight aluminum.
#675 |
ok, good and bad. the good...
![]() exedy is alive and kicking! looks new and surface material is 100%, my last one must've just been defective (thanks again brian 500hp zombie wilkerson for all of your help with that ordeal) ![]() finally finished this ordeal, i love it, looks great! voltage works as well ![]() the bad... ![]() elongated pushrod path (possibly from the bent oem pushrod we pulled out of motor originally) however, all the new manley pushrods were straight still hg had a leak on just one cylinder, small amounts of coolant had gotten in with zero smoke from exhaust or milky oil/etc. ![]() its the 2nd from left iirc the cam is still nice and good, only super barely slight hazy normal valvetrain contact patch the crank, haha, ohhh the crank. rods/pistons/arp rod bolts/crank/all bearings, trash the mains weren't BAD, probably just normal 70k wear plus a lot of redline at the end ![]() this rod bearing melted on, it only had 1 run on it..ever ![]() odd, haha ![]() so much metal dripping down the cylinder walls ![]() we suspect bearing material made its way into oil pump as well, via looking down in there haha motor needs to be bored, needs new crank, all new bearings, new pistons, new rods, new oil pump, new main bolts thats just in the bottom end, oh brother. time to bring her back to life ![]()
#676 |
I've been following your build on ziptied.
what is a furreal
http://bhworld.wordpress.com/ |
#677 |
![]() Join Date: Aug 2006
HAHHA oh shit. thats me in the middle. man!!!! i havent been on zilvia in a while. and im sure this has already been said a few times. but you are so dope!! i cant believe you fixed your motor on the track. and then had it ready for one more run!! this thing is nuts in person! i need to drive to texas.. btw if you didnt remember. i was the guy with the black coupe. stockish looking. with the KA |
#678 |
of course i remember
#679 |
haha thanks man! i wish we couldve seen that car drive some more.. is t-russel and/or tcox on this forum? i was goign to ship some vinyls out for you guys! ![]() and not to get this off topic. but i got 6th out of 32 at my last event. haha i am just trying to be like you. ![]() |
#680 |
Nutswingers aside, that motor is T>O>A>S>T ... toast.
Kinda depressing to see, especially because 70k isn't all that much on a non-high-compression street motor... and that's A LOT of material to find floating around everywhere. Nice that you have the funds to rebuild it right though, can't wait to see some more vids.
#682 |
#683 |
Yeah, a C6 Z06 I saw at A&A in Oxnard (famous Vette shop, apparently) was 12.8:1, forged internals, big cam, full ti valvetrain, made 560whp @ 6800rpm IIRC. 540ft lbs.
Pump gas, N/A. But big $$$.
#684 |
local lsx making 850ish wheel NA spinning to 8300rpm on pump. king of lsx
#685 | |
What're your plans with the motor? Stay N/A, go high rev? Boost, keep a meaty powerband? The people want to know.
#686 |
no no, not a dyno queen. that car holds a lot of track records as well...unfortunately just 1/4 mile though :\
i was gonna wait on this but here we go... ls1 comes back this week with fresh eagle h-beams, probe high compression pistons, arp mains, arp 7/16 rod bolts, another melling high pressure oil pump, MLS headgaskets, arp headbolts, all blueprinted and balanced for peace of mind. for the time being, its gonna jsut be super reliable bottom end at 6800 rpm. when i can afford it...stage 4 drysump and 7500+ rpm.
#689 |
hey theres tyler!
#690 |
![]() Join Date: Apr 2006
![]() ![]() Feedback Score: 4 reviews
when you gonna slap a sweet short shifter in this stew?
actually, no joke, Matt Davis and I agree with the pro 5.0 idea...your stock t56 shifter sucks man.... |
