Old 04-07-2012, 02:40 PM   #1
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
Wink The Ultimate For Sale Thread
Updated April 2018
SR20DET Valve Cover Grey $80
GReddy Adjustable Cam Gears SR20DET $120
Stock Injectors w/ Fuel Rail KA24DE $50
S13 Side Mount Intercooler $30
New in Box - SSAutoChrome External Wastegate #13b-1 $40
Above Fan Shroud Intake Tube S13 SOHC $15
Above Fan Shroud Intake Tube S14 DOHC $15
S13 Adjustable Tension Rods $50
S13 Reinforced Control Arms(good ball joints and custom bump stops) $75
Z32 Rear Aluminum Spindles $45
S13 Tanabe Front Lowering Springs $40
Z32 Front(30mm) and Rear Slotted Rotors(Good Condition) $80
New in Box - Q45 Front Akebono Premium Ceramic Brake Pads $20
New in Box - S13 Front PBR Pads (Non-ABS) $20
S13 Fuel Door $10
Jensen 4 Channel 600w Amp $30
Alpine 1000w 1 Channel Amp - #MRD-1001 $100
10" Polk/Momo Sub $35
S13 Sohc Manual #14 ECU $20
S13 KA24 Starter $20
S13 Radiator Support/Hood Latch Center Bracket $20
S13 Fastback and Coupe Trunk Release Cable $20
S13 Door Seals $20
S13 Hood Release Cable $20
S13 Driveshaft Carrier Bushing Bracket Set $15
S13 SOHC Upper Engine Harness $50
S13 SOHC Rubber Intake Boot $25
S13 Power Side View Mirror Center Console Button $15
S14 Power Side View Mirror Center Console Button $15
S13 Passenger Power Window Switch $20
S13 Passenger Power Window Regulator $25
S13 Rear View Mirror $15
S13 Dome Light $10
S13 Wiper Switch Stalk $20
S13 Exhaust Hanger Bushing $5ea
Convertible Top Button $15
S13 Time Control Unit(TCU) $15
S13 License Plate Light Harness $10
S13 Power Door Harness $15ea
S13 Manual Door Harness $10ea
S13 Hatch SOHC Automatic Body Harness $80
S13 Side View Mirrors $20ea
S13 Chuki Front Bumper Top Support Trim $25
4x114.3 Spare Tire $20
S13 Hood Latch $30
S13 Driverside Tension Rod Bracket $20
S14 Passenger Side Tension Rod Bracket $20
M53x2.0 Thread Z32 Upright Bottom Mounts $40
S13 Stock Rear 4 Lug Hub $15ea or $20pair
S13 Power Steering Reservoir $10
Oil Cap $5
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
240sx part out, interior, s13 s14 240sx, stock s13 suspension arms, window
