Old 12-26-2011, 11:41 PM   #691
lflkajfj12123
any sheet metal will do and mix the bondo thoroughly
Old 12-26-2011, 11:55 PM   #692
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
If u do my method u use no bondo- actually it's called body filler not bondo. If u want a shave look then use some 18 gauge steel even thinner 20 gauge but it's up to u. Then weld it, but don't weld continuously, if u do u will warp the metal. From my experience do spot welds then shave them off as best as possible then apply body filler the less the better
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 12-27-2011, 12:03 AM   #693
godrifttoday
Trader Rating: (82)
Jeff do u soder each connection? Or crimp? I know oem crimps all connections if not mistaken
Old 12-27-2011, 12:07 AM   #694
Om1kron
Om1kron's Avatar
That all depends on the cheapness of the person paying j/k
Wayne Edwards
https://om1kron.blogspot.com
Old 12-27-2011, 12:09 AM   #695
anthonyr sil8ty
anthonyr sil8ty is an unknown quantity at this point
yea thats what i was trying to think of body filler, I heard its more durable than bondo???
anthonyr sil8ty is offline   Reply With Quote
Old 12-27-2011, 12:11 AM   #696
s13greasemonkey
s13greasemonkey is an unknown quantity at this point
Yeah alot of people generally use to much body filler and it then it cracks, I layed down a thin amount of body filler and I used the correct portion of hardener.(Making a perfect mix each time.) I used 16 gauge because 18 is pretty thin and would warp easily. I tried using a 220V welder and even at the lowest heat setting I kept burning holes so I just ended up using a 120V welder and everything worked out fine.
s13greasemonkey is offline   Reply With Quote
Old 12-27-2011, 12:18 AM   #697
godrifttoday
Trader Rating: (82)
lol, then call me cheap because i aint paying haha... i like to attempt thing first
i was looking throught the fsm on how the altenator works, do i need to connect the white/red plug which goes to the bulb check relay? or can i leave it unpluged? would i have charging issues?
bondo is a brand body filler is what people refer to bondo
Old 12-27-2011, 12:23 AM   #698
Om1kron
Om1kron's Avatar
just check an engine bay thread on somewhere like nwp for life.
NWP4LIFE: ***Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ***
plenty of reference pictures, tips, and tricks there.
and here is the race car, fab work, wiring thread
NWP4LIFE: **Race car wiring,fab work, plumbing , motor, forced ind, nut riding**
tons of nutriding going on in both, as well as hating. Now we can divert the honda cuntism displayed by the witty comments here =)
ball so hard, even if it's a gay mustang.
Wayne Edwards
Old 12-27-2011, 12:27 AM   #699
godrifttoday
Trader Rating: (82)
how much power? thing is a beast
Old 12-27-2011, 09:14 AM   #700
anthonyr sil8ty
camera needs to move to the left
Old 12-27-2011, 04:17 PM   #701
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Sorry, SLIGHT thread jack
That's one of Frank's hot rods...
Wanna see what that thing does?
http://www.youtube.com/watch?v=jI4lhXTXuvk
http://www.youtube.com/watch?v=U_HSE2SZT1s
Not 100% sure it's the same girl, but I'd bet on it being Frank's GF. Frank is the owner of PSI SpeedSolutions...they do huge dollar 180-200mph trap speed stuff.
Old 12-27-2011, 04:25 PM   #702
90240sx07
90240sx07 is an unknown quantity at this point
o damn those bodies are amazing
but got a question that a few of u should be able to answer
Question: For those of who that are redoing your wiring how did you or how are you gonna make that wiring work with the stock dash wiring and/or guages etc........
90240sx07 is offline   Reply With Quote
Old 12-27-2011, 04:26 PM   #703
codyace
codyace's Avatar
Trader Rating: (58)
Originally Posted by GSXRJJordan View Post
For general wire splices/etc and especially for doing stuff inside the car, I use the same Radio Shack huge soldering guns that I've used for over 10yrs. I keep replacing them every 6 months or so under warranty lol.
THat really is a badass main harness solder system yeesh! That's a few steps lower than a welder
Intersting on that radio shack solder iron, as I was always under the impression that those larger gun style ones weren't 'as good' and was always looking at the pencil style. Good to know, as I'm gonna be looking into a newer one here soon, probably before spring.
Old 12-27-2011, 04:26 PM   #704
boyou2
boyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura about
omagad ^^
boyou2 is offline   Reply With Quote
Old 12-27-2011, 04:37 PM   #705
DoobieS13
DoobieS13's Avatar
DoobieS13 is an unknown quantity at this point
DoobieS13 is offline   Reply With Quote
Old 12-27-2011, 04:48 PM   #706
godrifttoday
Trader Rating: (82)
I think If you are rewriting your car completely u won't use stock cluster.
Old 12-27-2011, 05:04 PM   #707
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I solder all day long during remote start season and a lot during the summer months for alarm installs. I also do a lot of repairs to circuit boards etc.... and this is what I use with GREAT results:
Edsyn - EDSYN 951SX - LONER Temperature Controlled Soldering Station
I have owned this particular model for 3 years now without a hiccup. Edsyn has around 20-30 tips that can be used with it: from very fine pencil tips to large tips for soldering heavy gauge stuff. I solder USA spec 4 gauge with no issues with this iron. When it comes to soldering irons you really do get what you pay for. I have around 5 different tip setups and that easily covers everything I throw at it. And really, I only use one 99% of the time.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 12-27-2011, 06:13 PM   #708
godrifttoday
Trader Rating: (82)
How fast would u say it heats up what u need to soder? Say 14 gauge ?
Old 12-27-2011, 06:14 PM   #709
Broadfield
Broadfield's Avatar
30 seconds... it's fast for a non-trigger style iron.
My Portfolio
Please Share
Check Out My Builds
Old 12-27-2011, 07:17 PM   #710
GSXRJJordan
GSXRJJordan's Avatar
Cody we got MIG and TIG welders, and an oxy-acetylene torch for those REALLY stubborn wires haha.
Awesome do-everything iron, grip's too far back from the tip for SMC stuff though =P
Totally get what you pay for with irons though, a good setup will last longer than your hands/joints.
Easy to use stock gauges, diagram is in the FSM. Clip the 3 (or 4) plugs off the under-dash harness and rewire what you need.
Old 12-27-2011, 09:24 PM   #711
R33E8
R33E8 is an unknown quantity at this point
Excellent question.
The shield needs to be chassis grounded somewhere, either you pull out a ground at the engine connector end or at the bulkhead connector end. There's no need to blow a pin on a shield ground, since it doesn't do anything for you on the other end, although if you had to it's not the worst thing in the world.
Trickiest thing working with shielded wire in a bulkhead connector is the 'strands' of shield that are left when you strip back the shield to pin the primary wire(s)... you need to be very careful to trim and then heat shrink the shield so these strands don't fall and short your bulkhead connector's pins.
I had an intermittent stat sync error (crank signal problem) on Conrad Grunewald's LS7 last year that turned out to be a 1/8" long, almost microscopic shield strand that fell out of the heat shrink (I'd used non-adhesive shrink on that) and arc'd across the crank sensor's pins. Ridiculously hard to figure that out lol.
Eh, I donno.. At my job most customers want the shield to go through a contact or through the connector itself (captured within an EMI backshell).. If you only terminate one side through a bulkhead, then the other end will be open to interference.. The proper way to do it is with a solder sleeve.. This website is a pretty good example: A lesson in shielded wire « Matt's RV-7 Project
I would also recommend grounding the shield only at one end (preferable not the engine connector end) to prevent a ground loop situation.. If you have a bunch of shielded connections to make you can daisy chain the solder sleeves and run them to one crimp.. like so:
R33E8 is offline   Reply With Quote
Old 12-27-2011, 09:26 PM   #712
90240sx07
k thats what i was thinking to do you happen to have any extra plugs for a 89 chassis
Old 12-27-2011, 10:31 PM   #713
GSXRJJordan
This is where application matters... on a car, there's very little interference behind the firewall, and no interference if the other side is shielded and grounded as well (which is usually the case).
That part is true, but then again, application-specific stuff here: the engine is the absolute best ground in the entire car. The OEM's almost always ground the shields to the engine, not the chassis.
I dig the sleeves though. That would be perfect for daisy-chaining shields.
Nope. Junkyard time for you!
Old 12-28-2011, 02:15 AM   #714
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Do you fellows use custom clutch lines? If so, what are some reputable online places where I could have one made?
I am running mine behind the firewall through the hood release cable opening and back out through the vent hole on the bottom of the passenger side. No aftermarket line is long enough, so I am actually using the stock rubber section as an add-on to my Agency Power or Circuit Sports or whatever line to make it longer. It works, but is probably unsafe and I would much rather have a one-piece line.
Old 12-28-2011, 02:41 AM   #715
GSXRJJordan
Yup, it's just -3an brake line. Any place that crimps brake lines can make one that'll hold a couple thousand psi.
If you absolutely have to make it yourself, there are some assembled/threaded -3an fittings for hydraulic lines, but I just pay Tom at Earl's Store 1 to crimp mine when I have 'em made.
Old 12-28-2011, 11:00 AM   #716
bb4_96
bb4_96 is an unknown quantity at this point
finally multiple bus
http://www.swecheck.com.au/catalog/a92.pdf
bb4_96 is offline   Reply With Quote
Old 12-29-2011, 01:52 AM   #717
godrifttoday
Trader Rating: (82)
i been trying to get my car started but nothing, i get fuel, crank but no spark, injectors have 12 volts, the car started before i did not mess with the engine harness at all, all i did was make the new harness, but i get code 21... i been trying everything so far and nothing here the diagram i used to get the car started, any info would be great
Old 12-29-2011, 05:04 AM   #718
bb4_96
Did you ground the coils harness to the rear of the head like the original harness? This will sound silly but also make sure your coils are getting juice. If you are running factory ignitor make sure the 5th(ground) wire is grounded properly.
-So 4 coilpack signal inputs into ignitor and one ground wire(thicker?/black/middle)
-Also the power for the coils runs past the ignitor(thick/blue&red)
-Then 4 ignitor outputs drive coils
-Ground on coilpack harness
If all that is straight you should be good. If you rotate the cas by hand very slowly with the ign on you can hear the injectors click, if they don't it could be ecu or cas wiring and not just spark.
Old 12-29-2011, 12:08 PM   #719
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
for the guys who relocated their fuse box, what did you do with the amps?
killer240 is offline   Reply With Quote
Old 12-29-2011, 12:36 PM   #720
r33nota240
r33nota240's Avatar
r33nota240 is an unknown quantity at this point
Facebook
r33nota240 is offline   Reply With Quote
