03-10-2010, 11:56 PM | #781 |
wat about a 5 lug rotor?
SPEED KILLS!! Drive a Honda and live forever!! |
03-11-2010, 12:37 AM | #782 | |
It will still be a 5x114.3 lug pattern. The axle/diff swap only changes the axle and diff. The hubs are unchaged.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
03-11-2010, 08:08 AM | #783 |
i know the bolt pattern but from a 4 lug to 5 lug i should need a different rotor then wat i already have.. my question is wat rotor will i need
03-11-2010, 08:15 AM | #784 |
do Nissan Altima upper and lower injector o-rings work on an s14 sr20det?
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd Boycott Berkeley and code pink |
03-11-2010, 03:02 PM | #785 |
Trader Rating: (44)
Feedback Score: 44 reviews
I just installed my S13 DCC, and it stays on when I press the Off button. It still blows air. What's the reasoning, anyone know?
www.realize-jp.net |
03-11-2010, 04:00 PM | #787 |
twist and pull harder
'89 Sil80, SR20DET, GT2871r .64 |
03-11-2010, 04:34 PM | #788 | |
Trader Rating: (56)
Feedback Score: 56 reviews
US on top JDM on bottom
03-11-2010, 09:27 PM | #789 |
Anyone????????
03-12-2010, 07:51 AM | #790 |
A 240SX one. Use a 5lug S14 rotor. The rear brake rotor sizes are the same.
BRICKHOUSE PRODUCTS
03-12-2010, 08:50 AM | #791 |
how much size difference is there between a Z32 rear caliper and an S13 rear caliper?
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please. |
03-12-2010, 10:07 AM | #792 |
Buying a used OS Giken clutch, I know it's rebuildable...is there any damage I should look for that isn't fixable?
03-12-2010, 10:16 AM | #794 |
thanx.. i drive an s13 so i just wanted to be sure
03-12-2010, 11:09 AM | #795 |
I just bought another s13 w/ rb20det and I'm just wondering what oil filter and spark plugs do I get? If I was to go to kragen, autozone, napa or carquest? Thanks
03-12-2010, 12:19 PM | #796 |
[quote=irritatedmax;3335277]How does height to fender have anything to do with wheel width?
quote] Did I say measure the "heigth"? I said measure from hub to where the fender sits.....horizontally. Like invisible line that goes from fender to the floor. measure the hub to the invisible line. Does that help you? |
03-13-2010, 09:16 PM | #797 |
03-13-2010, 10:28 PM | #799 |
03-14-2010, 07:27 PM | #800 |
im having a problem with my redtop, it runs great but the other day it started smoking out the exhaust like it was on fire. at idle it doesnt do it but after running it hard it smokes pretty bad while its idling at a stop light. it exhaust smells normal but its like a greyish color. i have search the forums and i think the seals in my turbo are going out, any one have this problem before?
03-15-2010, 02:50 AM | #802 |
On a S14, there is this valve type thing connected to a cable on the rear heater hose. I removed this all together when reinstalling the motor. Does anyone know of any ill effects or what this part does?
The valve type thing is mounted on the firewall.
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
03-15-2010, 10:05 AM | #803 | |
Your manner still has nothing to do with fitment. I believe this is to let "hot" coolant into your heater core so you have heat in the cabin. That is the only function I could determine when cleaning up my bay. If you remove it, hot coolant should be flowing through you heater core all the time. So, the heat would always be on?
BRICKHOUSE PRODUCTS
03-15-2010, 11:58 AM | #805 |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
gonna post this question here instead of making a new thread...
heres my situation at the track...transmission is no bueno the shifter goes in and out of every gear, 0 resistance...clutch pedal goes in and out normally, went under the car, and clutch fork engages and disengages as normal... heres the wierd part, if you put the car in gear (1-5), normally, if you were to push it in revense, there would be that resistance...right? if i put my car in reverse with it in gear, itll move backwards with 0 resistance... my thoughts, and others, think , the actual shaft that goes into the motor snapped after overheating... cars originally an MT chassis, has its damper box still...doubt that helps... so...my question is...is it the tranny shaft that snapped...of did the clutch give way... mind you i do not know what clutch i have...all i know is, that everyone that dorve my car agrees its not stock, but it was grabbing great thru out the day till this happened... (yes it was at the track not the streets) edit: please note: the motor still starts, so that tells me its not the flywheel since the starter uses that to crank... and when the car is on, i dont hear any clanking in the bell housing or anything, leading me to believe that it is the shaft, not the clutch...but im unsure, just need help here... ???
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
03-15-2010, 12:00 PM | #806 |
03-15-2010, 01:00 PM | #807 |
ok i wanna lower my s14 more but when i get it to the hieght that i want when i try to turn, the wheel gets stopped by the fenders.. what do i do to fix this?
i am running tein ha coils, 5zigen fno1r-c (offset unknown), 30mm spacer, and i am planning on relocating the wire harness sometime this week
03-15-2010, 01:23 PM | #808 |
not giving a fuck
you need your fenders rolled...google that ...theres plenty of info on that kinda stuff
03-15-2010, 11:23 PM | #809 |
guys what do i need to swap a s14 blacktop sr into my 91 s13 manual hatch? I have a fully built ka that i sold my whole setup trans motor and turbo stuff for the s14sr backtop with motor trans and turbo stuff its just that the sr was in a s14 so what do i need for my car to get it running mostly wiring wise? thank you
03-15-2010, 11:52 PM | #810 | |
last resort would be frp overfenders or flares |
