Old 11-21-2017, 02:51 AM   #781
xsil20x
xsil20x's Avatar
xsil20x is an unknown quantity at this point
Oh never mind just saw free shipping in US
xsil20x is offline   Reply With Quote
Old 12-20-2017, 02:38 PM   #782
drautomotive.com
drautomotive.com is an unknown quantity at this point
Issue with latest batch of S13 fronts
We've recently discovered that with our most recent batch of S13 front bearings, the factory without our knowledge used a different snap ring than previous productions, causing the fronts not to spin. With this discovery, the factory admitted their mistake and has shipped us replacement snap rings that are arriving shortly. We also have 2 videos (step 1 to remove and step 2 to put on) for the new snap ring here:
https://drive.google.com/drive/folde...Ft?usp=sharing
We can new snap rings to any customers who have been affected.
drautomotive.com is offline   Reply With Quote
Old 12-21-2017, 11:02 AM   #783
xsil20x
xsil20x's Avatar
Anyone had a problem with the snap ring holes edge breaking off how would I get them off ?
Old 12-21-2017, 02:26 PM   #784
Fitelite240
Fitelite240 is on a distinguished road
Looking for a walbro 450 for an e85 set up
Fitelite240 is offline   Reply With Quote
Old 12-27-2017, 08:27 PM   #785
Jcc0033
Jcc0033 is making a name for him/her selfJcc0033 is making a name for him/her self
I had the same issue. Use snap ring pliers but turn them horizontally, so that the pliers are level with the back of the hub and apply inward pressure towards the snap ring. Best way I found to get em off!
Jcc0033 is offline   Reply With Quote
Old 01-02-2018, 01:16 AM   #786
CityHunt3R
CityHunt3R's Avatar
CityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to all
still outta stock??????????
CityHunt3R is offline   Reply With Quote
Old 01-02-2018, 10:34 PM   #787
drautomotive.com
We are out of stock due to the snap ring issue. We are working on replacing all the snap rings with the correct one and as soon as we do that we will make the front hubs available again!
Old 03-06-2018, 09:51 AM   #788
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
I emailed yall, I unfortunately am one of the few that ordered a front pair with the incorrect snap ring. I would like to get the correct snap rings asap so I can finally get the car back down on the ground. Many thanks in advance!
Jonathong is offline   Reply With Quote
Old 03-06-2018, 10:41 AM   #789
drautomotive.com
No problem, if you emailed us we'll send you the new snap ring.
Old 03-06-2018, 10:46 AM   #790
drautomotive.com
These are back in stock FYI
Old 03-06-2018, 11:45 AM   #791
TheRealSy90
TheRealSy90's Avatar
What's your recommended torque for the s13 front hub nut? I've heard the spec in the FSM can be too tight or too loose on aftermarket hubs because the range is so broad. Curious what you recommend for yours.
Such a good signature.
Old 04-30-2018, 08:28 PM   #792
91stockcoupe
91stockcoupe is an unknown quantity at this point
Are these still for sale?
91stockcoupe is offline   Reply With Quote
Old 04-30-2018, 08:29 PM   #793
sviellvoicae
sviellvoicae will become famous soon enoughsviellvoicae will become famous soon enoughsviellvoicae will become famous soon enoughsviellvoicae will become famous soon enough
Link is in his signature
sviellvoicae is offline   Reply With Quote
Old 05-01-2018, 12:12 PM   #794
drautomotive.com
We have limited stock still available. We are almost out of fronts. Then we will be out of stock for about a month.
Old 05-09-2018, 10:53 PM   #795
Misawatwotone
Misawatwotone's Avatar
Misawatwotone is an unknown quantity at this point
Emailed your customer service. received my box in the mail with only rear hubs. look forward to your reply.
Misawatwotone is offline   Reply With Quote
Old 05-10-2018, 04:04 AM   #796
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
I used fsm spec for reference, saw the range and used a number right in the middle. Been on these hubs for about 5 years now and no issues with lots of spirited driving and two track events.
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 06-01-2018, 12:34 PM   #797
tootall4la
tootall4la's Avatar
tootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to all
I bought s14 front hubs.
I need to replace OEM Studs with ARP extended studs for my wheel set up
What ARP extended studs work with the front hubs?
tootall4la is offline   Reply With Quote
Old 06-01-2018, 12:52 PM   #798
drautomotive.com
We don't officially recommend or support any ARP studs any longer, but we've been told that customers have used:
100-7715 for fronts
100-7708 for rears
Old 06-02-2018, 08:15 PM   #799
KB350z
KB350z is an unknown quantity at this point
Just purchased from the link but never received confirmation of my order?
KB350z is offline   Reply With Quote
Old 06-04-2018, 10:10 AM   #800
drautomotive.com
Since we don't know who you are, please contact customer service with your question and info
Old 06-04-2018, 05:27 PM   #801
speedgod^s13
speedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond reputespeedgod^s13 has a reputation beyond repute
Send a message via AIM to speedgod^s13
100-7715 for fronts
100-7708 for rears
How come? Also, when you are expecting a restock of the s13 front and rear conversion?
speedgod^s13 is offline   Reply With Quote
Old 06-04-2018, 05:30 PM   #802
drautomotive.com
Because we had a customer who used the studs and then ruined the hubs and complained to us. He was the only one so far who has had this problem but we can't recommend it as a result.
More should be available early July.
Old 07-14-2018, 12:43 AM   #803
91stockcoupe
Still waiting on my front pair, ordered 2 months ago.
Old 07-14-2018, 08:52 AM   #804
drautomotive.com
What's your name so I can look it up?
Old 07-14-2018, 10:44 AM   #805
91stockcoupe
Pm'd you..
Old 07-30-2018, 12:10 PM   #806
xsil20x
xsil20x's Avatar
U guys still have walbro fuel pumps ? Don’t see it on site.
Old 07-30-2018, 02:40 PM   #807
drautomotive.com
Yes they are on our fuel pumps web site.
It is a dot com of the same name (fuelpumps)
Old 07-30-2018, 02:47 PM   #808
xsil20x
xsil20x's Avatar
Ok thanks
Old 08-02-2018, 06:00 PM   #809
Rolo7
Rolo7's Avatar
Rolo7 is an unknown quantity at this point
Do you guys allow pick up? How much for s14 front wheel bearing assembly for non abs?
Rolo7 is offline   Reply With Quote
Old 08-03-2018, 09:51 AM   #810
drautomotive.com
Hello, we do not allow pickup. All the pricing information should be on our web site.
