10-11-2011, 10:21 PM | #8103 |
Trader Rating: (58)
Feedback Score: 58 reviews
No, the oil filter is not a restictor. You need a journal bearing restrictor
coolant hoses? Not a clue. I don't mess around with KA-E stuff.
10-12-2011, 06:16 AM | #8104 |
stupid question that i'm actually embarassed to ask. nardi classic steering wheel, how the hell does the circle trim piece (that surrounds the horn button) stay on/get secured. mine just kind of rests on the bolts but doesn't snap in or press on. and yes i'm using the supplied nardi bolts.
10-12-2011, 06:55 AM | #8105 |
I don't even know if they are coolant hoses. Only the one connects to the water outlet neck, the other looks like it could be a vacuum for the tranny.
10-12-2011, 07:57 AM | #8106 |
Trader Rating: (58)
Relooked at pictures, looks like fuel rail return line
10-12-2011, 08:09 AM | #8107 |
10-12-2011, 09:27 AM | #8108 | |
I ran that on my 17x8/17x9 setup, as well as my current 17x9/17x10. Its perfect for dailying. Its not "hella-flush" super stretch, but its a good looking size, and looks mean, and grips great.
-Kyle |
10-12-2011, 09:42 AM | #8109 |
I want to know if rota sells the p45r 4x114.3 17x9 +25 offset and if this size will not stick out of the body of an S13 or hit the coilovers or z32 30mm calipers...
thanks |
10-12-2011, 09:52 AM | #8110 |
So I have read that the Evo 8 Recaro seat sits high.
I was wondering.. if I were to run low mount brackets with that seat would it offset the height and bring it down to a normal level?
http://www.nissanroadracing.com/ |
10-12-2011, 10:05 AM | #8111 | |
any feedback?? |
10-12-2011, 11:21 AM | #8113 |
10-12-2011, 11:26 AM | #8114 |
Prime, CodyAce, maybe this will give you a better guess.
This is where the one in the back connects to the manifold. This is where the one under the plenums connects to. Does this help? On a side note, the big hose on the second picture just makes a loop into the water inlet, what's with that? And on that first picture, what's that uncapped steel pipe go to? |
10-12-2011, 01:16 PM | #8116 |
Trader Rating: (22)
Feedback Score: 22 reviews
I know this is a dumb question but.. doing 5 speed swap on the s13.. s14 has already been converted to 5 speed. Can I just use the pedal and slave and master cylinder off the s14 to go into the s13? Or is the S13 diff from the S14? Thanks! Just trying to see how many parts I can actually use off the 14 to put on the S13.
Driftphreak87 |
10-12-2011, 02:04 PM | #8117 | |
10-12-2011, 02:07 PM | #8118 | |
And uh, what is a coolant barb? Is the hose going to bend around that much? And should the uncapped pipe, be capped? |
10-12-2011, 02:44 PM | #8119 |
I currently run 245/40 on my 17x9, a nice, very mild stretch.
10-12-2011, 02:49 PM | #8120 |
My passenger side Energy Suspension steering rack bushing has a slight gap on the bottom. As in, I can see between the bushing and the rack. Is that normal/acceptable?
10-12-2011, 03:00 PM | #8121 |
Do i have to get a helmet recertified after the helmet has been in a minor accident?
i wana use my bike helmet but in jan i got into a small accident and my helmet was fine ( only scratches on the outer shell)...my brother decided to spray paint it and now i want to use it for events.... would it be fine or do tech inspect helmets??? |
10-12-2011, 03:13 PM | #8122 |
Trader Rating: (54)
Feedback Score: 54 reviews
Anybody have a link to 5 lug conversion thread?? I was gonna keep my 4 lugger but changed my mind....I have no idea what parts are compatible.and wat I need...thanks
10-12-2011, 03:13 PM | #8123 |
Should be fine if they are just scratches and not cracks
@matej - Im pretty sure they are supposed to be snug. Did you get 3 bushings with your kit?
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
10-12-2011, 03:24 PM | #8124 | |
The problem is that the rack is not centered in the bushing. Instead of sitting in the center, it is squeezed up against the back of the bushing, which is creating the gap. Perhaps I need to fiddle with the driver side bushing to see if it can be aligned better. Is the driver side (teardrop) bushing the same for both S13 and S14? Also, is it symmetrical, as in, does it matter which side is facing the front and which the back, as long as the pointy end is on top and the round end on the bottom? |
10-12-2011, 04:55 PM | #8126 | |
Trader Rating: (58)
NASA rulebook: Note- the minimum helmet standard starting January 1, 2012 will be: All drivers are required to wear a properly fitted and secured helmet while on track. Helmets must be approved by Snell and carry a sticker of Snell SA2005 or newer*. Ratings other than that of “SA” (Special Application), i.e. “M2000, M2005, or CMR2007”, are not acceptable. *Alternatively, helmets with an FIA certification of 8860-2004 or newer, or an SFI label showing the rating of 31.1/2005 or newer are acceptable. It is strongly recommended that any helmet sustaining any substantial impact be replaced. Unsure how drifting rules are but the NASA rules essentially mimic SCCA rules. Google.com dude.
10-12-2011, 08:37 PM | #8127 |
Ok, so my car will randomly start up missing, sounds like a subaru, but after it warms up it stars firing on all four again. i also have what feels like a stumble at idle but according to my tach its steady at 650.
10-12-2011, 08:42 PM | #8128 |
While engine is running do the following.
Pull each spark plug wire (one at a time) and see if the engine stutters. Pull each Injector connector (one at a time) and see same. Jiggle MAF wires like crazy and check same. Then take 2 and call someone in the morning
10-13-2011, 10:36 AM | #8130 |
Oil
I currently have a 91 240sx with a S14 Ka24de. The motor basically just went over 100,000 miles and I'm driving out to the desert this weekend. Before I go I want to change the oil and do some other necessary things to the car. I usually use Eneos 5w-40. I've been doing some research and I'm thinking I should go with a 10w-30 now, I was thinking about going with this Torco A161033CE SR-1 100% Synthetic Engine Oil 10W-30 1 Liter.
So my questions are: Would it be better to upgrade to a 10w-30 especially with a long trip ahead of me? Is Torco 100% synthetic a good choice to go with? Thanks for reading! |
