10-13-2011, 02:26 PM | #8131 | |
Read it. All of it. |
10-13-2011, 08:21 PM | #8136 | |
I meant drooping the spring, my bad. And, assuming this guy is removing them cause he can't go low enough with them on (hardly makes a difference) the perches won't go anywhere, if its locked against the bracket.
street dancer. GLEAM |
10-13-2011, 09:03 PM | #8137 |
Trader Rating: (39)
Feedback Score: 39 reviews
hey guys i was reading through a couple clutch adjustment threads and everyone mentions when lowering the clutch pedal
i have to just loosen the bolt spin the fork then tighten the lock bolt and put the bolt&cotter pin in, my question is how do i spin the fork when its wedged in-between the clutch pedal? pic is my clutch pedal , it sits way too high up like im driving a truck, i want it about halfway low so it engages/disengages faster for me, thanks in advance edit: i took the cotter pin and bolt off but the fork doesn't come off enough for me to be able to spin it , the pedal is in the way. (s14 KADE, Original 5spd)
IG - allen.kerose |
10-13-2011, 09:28 PM | #8139 | |
thx but alrdy googled and saw the first link and several others but guess what it doesnt answer my question, so if anyone has an an actual answer instead of posting a link just to be a jack ass please PM me. im gonna go ahead and say that you dont know either |
10-13-2011, 09:30 PM | #8140 | ||
Future Moderator
10-14-2011, 01:25 AM | #8142 | ||
You are an idiot. If you cant get your answer from this then you need to kill yourself. Quote:
So yes you can interchange flanges in between any of the diffs. Therefore As long as the cover matches the car you can swap flanges/R&P/Axles, as long as they match each other. Jackass
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
10-14-2011, 06:39 AM | #8143 |
no i asked if i have a 92-94 j30 diff on my car already which has a 5bolt pattern output shafts (the part that connects the axle to the diff) can i use the output shafts from a 95-97 j30 diff which has a 6bolt pattern and if they are interchangable will stock s13 output shafts work as well. i know the thread pitch on the end of the axle is the same and same size i gives a fuck about that
10-14-2011, 06:46 AM | #8144 |
just picked up s14a and need to swap out all the shit rusted brakes on it..
so was wondering if anybody recommends brembo or ebc pads? anybody had bad experience with them with warping discs on high temps or eating through rotor quickly? im thinking to just use the car on a weekend and some track time, and was looking for something similar in performance to hawk hps pads.. Last edited by spectre14; 10-14-2011 at 09:54 AM.. |
10-14-2011, 07:41 AM | #8145 | |
I have answered your question twice. Feel free to jump off a cliff at your earliest convenience. (when did I even mention thread pitch?)
10-14-2011, 03:42 PM | #8146 |
Trader Rating: (31)
Feedback Score: 31 reviews
VISIT OUR NEW SITE! streetfaction.net |
10-15-2011, 07:14 AM | #8150 |
hey guys got quick question i think one of my rear wheel bearings are going out. can i use a rear wheel bearing from a s14 4lug car? cause i have 5 lug convertion on my car. and what all needs to be pressed when doing a bearing change? thanks!
10-15-2011, 09:24 AM | #8151 | |
Trader Rating: (58)
Feedback Score: 58 reviews
Why? And where are you finding 12 dollar slave cylinders that are decent?
10-15-2011, 12:47 PM | #8152 |
Just finished rebuilding my motor and am curious as to the best way to break in the motor. I know there's the 2 different schools of thought, the old way and the newer break it in hard method. I want to break it in so it lasts. Your thoughts and suggestions..........
in any situation....thou shalt blaze |
10-15-2011, 02:36 PM | #8153 |
i just bought a s14 sr. it came off a clip they had at the shop.the ecu they gave me says 4g does anyone know what year motors came with this ecu? cause i searched and nothing comes up.. anyone can help?
10-15-2011, 05:28 PM | #8155 |
do the rb26 valve covers bolt directly on to the rb25 and is there any benefit to the swap? I have seen a few rb25's with 26 covers.
http://zilvia.net/f/chat/331550-slyd...pic-heavy.html |
10-15-2011, 10:15 PM | #8157 | |
Trader Rating: (58)
As my intial post said, reinstall, and then re bleed the system
I'm confused at what part is 12 dollars, let alone any that I'd trust in that situation.
10-15-2011, 10:28 PM | #8158 |
I'm confused as to why the idea of a person going to a Nissan dealership, to buy an OEM Nissan part, for a Nissan, and paying the price the man behind the counter asked for said part is foreign to you.
10-16-2011, 12:27 AM | #8160 |
Regardless of that he said there's fluid coming out of the boot. I'm like 99% sure fluid shouldn't be in that boot and it's time for a new slave cylinder anyway. I don't know the price of an oem one from the dealer, but I know for a fact it's right around $20 at autozone. Go buy yourself a new one.
