Old 01-08-2009, 08:56 AM   #811
bades
bades is an unknown quantity at this point
all i can say after reading all 27 pages of ur build is WOW!!!!
oo n P.S. thnx for makin my built rb24det build in my s13 seem like complete shit compared to ur awesomeness.... dude u might honestly be my hero now...... car is beautiful and ur track car idea is right up my alley...
thnx for makin my day.... good luck wit ur build
bades is offline
Old 01-08-2009, 09:39 AM   #812
vodka2
Trader Rating: (18)
vodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura about
Feedback Score: 18 reviews
damn , hurry up and finish it i want to see what its gonna look like .. 18x12f 18x13r ! do it.
vodka2 is offline
Old 01-19-2009, 02:22 AM   #813
CursedGTR
CursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfection
I went ahead and made some aluminum door panels today. I have to pick up some rubber grommets and draw string, unless my appeals for chicks underwear strings gets answered (No shit stained tighty whities please )
I started by taping a piece of masking paper to the door and then trimming it to the shape I needed. I took the shape, traced it onto some aluminum and then spent a couple hours cutting shit up.
Drilled a hole and stuck a Riv-Nut in it
Drilled a couple holes in the panels and put them on.
I still have to come up with 2-3 more bolting points and add some foam rubber and rubber edge lining.
Pics As usual:
We are finished with the repaint. The weather was kidn of shitty so I didn't put it outside to take new pictures, I will get them up soon though.
CursedGTR is offline
Old 01-19-2009, 04:10 AM   #814
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
Looks good I will be using sheetmetal for my door panels also.
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline
Old 01-19-2009, 05:41 AM   #815
marv670
marv670 is an unknown quantity at this point
ihate you bro! 27 pages god im suscribing to this
marv670 is offline
Old 01-25-2009, 01:08 AM   #816
jspec240
jspec240's Avatar
jspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfection
sickest build in the world
DREW
SLIDE TO SIDE WORLD WIDE
Feedback!! http://www.zilvia.net/f/showthread.php?t=182673
661 sliders Gymkhana @ buttonwillow
http://zilvia.net/f/south-western-st...-sessions.html
>> Bakersfield Hook up thread <<
jspec240 is offline
Old 02-05-2009, 04:24 AM   #817
CursedGTR
Today I finished up a very near and dear project. My headlight brackets. Now inorder to make suitable headlight brackets that adequately integrated into the mounting poing I had on the intercooler and the bumper retainer bar while remaining nice looking, I decided on two things. They had to be strong and they had to be aluminum.
I took some measurements and went off and purchased some cut pieces of 10mm thick 6061 T6 aluminum. Once I had those, I drill some holes and mocked everything up to determine the location of the upright portion of the bracket. Once those measurements were spot the fuck on, I had a friend weld them up for me. In order to prevent scrating and bending on the intercooler top surface I added some 15mm Hard rubber bumpers to the bottom of the bracket, drilled some more holes and the results of that labor are below. If you compare this to the cheap ass bent up wannabe bracket that I had before, I think you will agree that this approach was not only better looking but much better for the entire thing. Everything is solid with these brackets. I then mocked up a piece of 90 degree 3mm angled aluminum. I will cut it and edge it down to size and mount it to the brackets. This piece of angle will be the support structure for my air dam.
Next was the doors. When we put the door latches on in the stock positions, they barely caught the second latching point and when they did, the ody lines were off by about 1/4 inch (door sunk in), so I had a friend of mine modify the door latch stryker by illongating the holes by 150 percent and what we have as a result is not only a perfectly latching door, but the body lines are all nice and lined up without compromising the purpose of the weather stripping.
Next up, I will finish up and induction llens (I gutted the lights out of it) that I have been working on and will finish up with mounting the hood pins, the front CF ducts and the interior panels (will be plastic for the rear).
Pics Below As Usual.
Old Headlight Bracket full of Fail -
New Headlight Brackets
Door Latch
Body Lines - ( I do not have before shots)
Old 02-05-2009, 05:55 AM   #818
¹²³Klan™
¹²³Klan™ is an unknown quantity at this point
wow, new to zilvia!
this shits INSANE...........
love the WB, molding looks good.
but whats up with the panty string donations?
Going to use them a pulley system of some sort?
¹²³Klan™ is offline
Old 02-05-2009, 06:02 AM   #819
MisawaJason
MisawaJason's Avatar
MisawaJason is an unknown quantity at this point
Jesus god. I remember when you used to post up pics on our site a year or so ago. Totally forgot about this project. Shit looks awesome man!!
MisawaJason is offline
Old 02-05-2009, 08:54 AM   #820
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Lookin good, lookin good.
You should be able to get universal inner door handlers, made to be put in sheet metal inner doors.
Much less ghetto that a string.
and I'm pretty sure most sanctioning bodies wouldn't be down with a string.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline
Old 02-05-2009, 10:31 AM   #821
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
Originally Posted by CursedGTR View Post
sickest shot ever!!!!!
this thread is so f'ing ridiculous. part of me thinks this car should be put into a hyperbaric chamber and preserved for future generations to see how it should be done....
but that RB needs to be abused the way it was designed to be. you ready to drop the engine in any time soon?
96Turbo is offline
Old 02-05-2009, 10:36 AM   #822
jdm_s13driftking
jdm_s13driftking's Avatar
jdm_s13driftking is an unknown quantity at this point
car is sick!!!!!!!!!!!!!!!must be nice...
jdm_s13driftking is offline
Old 02-05-2009, 01:00 PM   #823
Big_E-Dog
Big_E-Dog is an unknown quantity at this point
love the car want to see it finished, the brakes are awsome goes well with the paint scheme. are, and have you considered having the dash and center secton carbon fibered?
Big_E-Dog is offline
Old 02-05-2009, 02:32 PM   #824
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
I hope you finish this car.
I was thinking about the thread the other day and thought "I hope this isn't one of those wild builds that never finishes and just disappears some day."
http://bhworld.wordpress.com/
Brian is offline
Old 02-05-2009, 02:42 PM   #825
Om1kron
Om1kron's Avatar
he will finish it...
Wayne Edwards
https://om1kron.blogspot.com
Om1kron is offline
Old 02-05-2009, 06:24 PM   #826
96Turbo
96Turbo's Avatar
he must......
or else many hearts will be broken
96Turbo is offline
Old 02-05-2009, 07:39 PM   #827
CursedGTR
Yeah, my account kept getting cancelled for some reason, so I just gave up.
Not looking for sanctioning bodies right now and door handles are trivial. I was just looking to tell people that they arte pulling on some unknown chicks underwear when they open the door from the inside.
Yes I considered Carbon Fiber. Originally I was going to have the original dash molded in CF, but it is not cost effective nor was it any fun. THe aluminum dash will be powdered or get some other kind of flat textured cover.
This car will get finished in the United States. I will be prepping it for shipping soon.
Originally Posted by 96Turbo View Post
he must......
No hearts will get broken. I will definitely finish it.
Then I will sell it (maybe)
Old 02-05-2009, 07:48 PM   #828
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
I am not sure if your intercooler is thick enough.....
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline
Old 02-05-2009, 08:33 PM   #829
onepuff
onepuff's Avatar
onepuff is on the path to ruinonepuff is on the path to ruinonepuff is on the path to ruin
Awesome. Where you gonna be back in the states?
onepuff is offline
Old 02-05-2009, 08:46 PM   #830
CursedGTR
Have no clue yet, but I will most likely be in AL for a bit of time. I am looking at taking a defense contractor position overseas for a short time as well.
Old 02-05-2009, 09:26 PM   #831
RedStage
RedStage's Avatar
RedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to beholdRedStage is a splendid one to behold
you know...build aside, I would love to have half the patience that you seem to have...
I'd have been driven crazy by now.
Marc - Yokohama, Japan
RedStage is offline
Old 02-05-2009, 09:30 PM   #832
ZilviaKid
ZilviaKid's Avatar
ZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the rough
this car is WAY too nice. finish soon plox. been following it for way too long.. lol
2004 Nissan 350z
2002 Nissan Silvia
ZilviaKid is offline
Old 02-05-2009, 09:47 PM   #833
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Why is this car so narrow?
Geeze, I thought you'd at least put a widebody on it.
Build looks sick, keep it up.
Blow me, bitches.
Slammed180 is offline
Old 02-05-2009, 09:52 PM   #834
MisawaJason
yeah, we kept on having issues with our forum. It crashed a few times on us and everyone had to re-register
Old 02-05-2009, 10:15 PM   #835
Unique
Unique's Avatar
Unique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura aboutUnique has a spectacular aura about
wow nice build
Unique is offline
Old 02-06-2009, 05:19 AM   #836
Axi$
Axi$ is an unknown quantity at this point
You moved the latches, but what about the windows???
Axi$ is offline
Old 02-06-2009, 05:52 AM   #837
CursedGTR
The seals are all lining up quite nicely on the door. Doubt there will any issues with the windows. When the latches were in the original spot, the door would close properly only with the seals removed, therefore, I doubt I am going to have any further issues at all seeing as in how it is closing tightly with the seals as it sits currently, however, should I have some issues I am confident that I will come up with a proper solution. Truthfully, I think these could have been the wrong door latches (even though they came with the car).
Old 02-06-2009, 06:45 AM   #838
240SX2high2aim
240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore240SX2high2aim is not welcome here anymore
wow I havent seen this thread in a long time and damn it is turning out nice
240SX2high2aim is offline
Old 02-06-2009, 08:50 AM   #839
turbo_dreams
turbo_dreams's Avatar
turbo_dreams is making a name for him/her selfturbo_dreams is making a name for him/her self
i started reading this about 7 something last night, fell asleep, woke up, it is now 11am the next day, i probably spent 5 hrs looking at this thread over and over, amazing, hat's off to you on building my dream motor in one of my fav cars.
www.tm-spl.com
Kouki's & some apple juice.
turbo_dreams is offline
Old 02-06-2009, 12:02 PM   #840
SlideAlliance
SlideAlliance's Avatar
SlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond reputeSlideAlliance has a reputation beyond repute
Door Latch
God dammit Brian. Now I have to fucking go do something else to my car
Battle Idol Works 2015
SlideAlliance is offline
