#812 |
Nevermind got the car going. Thanks though!
#813 |
I was gonna get Xcessive mounts but decided to go with Get Nuts Labs, Mount's. Figured forrest has to make good mounts, thats what they use. You can find them at driftmotion. These are them before a coat.
G37s - Dropped on DPE 20's - $old S14 - Bone stock |
#815 |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
I need to get down to the lab and get a set of mounts from Forrest. Did he still have a decent supply left? He had quite a few sets the last time i was there.
#817 | |
![]() Join Date: Mar 2009
![]() Feedback Score: 13 reviews
Also now when the ac is on and im driven for a while the ac doesnt blow as cold and all the speeds are the same it just trinkles out. Ill turn off the ac for 5mins or pull over and let the car idle for a few mins then the ac works again. Im runing water wetter and useing a 1jz water temp sensor. I think its the sensor not reading right being its a 1jz sensor in a s14 chasey |
#818 | |
#819 | |
#820 |
Just killed a 97 sc cobra, felt good, pulled 4-5 car lengths on him, t67 @ 13 lbs feels good can't wait for more ha ha
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
#821 |
#822 |
315/35/17 with the s15 3.69 works well, nto5 hold good, but the 3rd race it did spin all of 2nd but very controlled, most of the time they hold up to red line every gear.
#824 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
#825 | |
Do you have any pics of your set up? I was leaning towards chasebays tucked radiator.but your set up can save me couple bucks.i just wanna do it right the first time. |
#826 |
#827 | |
Yeah im shootin for about 450-500 for the road and maybe a little higher just to say I did ![]()
#828 | |
![]() Join Date: Jul 2009
#829 |
Im doing some research on it now ill let u know if im interested. Anyone have any experience with this setup on a JDM Aristo 2jzgte?
#831 |
I have been attempting to improve the cooling capacity on my S14 2JZGTE and ended up installing the stock TT fan clutch setup since it has an operating A/C system. So I have 2 sets of dual electric fans sitting in my garage. They are not junk ebay fans. PM if you're interested.
![]() Note: There are three square holes cut out at the top for rubber flaps to aid cooling at higher speeds, not shown in the pic. Derale Performance High Output Dual RAD Fan and Shroud Kits 16825 - $250 Maximum Fan CFM:4,000 cfm Fan Quantity ![]() Fan Diameter (in):12.000 in. Height (in):15.125 in. Width (in):25.625 in. Thickness (in):3.500 in. Number of Blades:12 blades Blade Material:Plastic Blade Color:Black Shroud Color:Natural Shroud Material:Aluminum Amp Draw:24.80 amps FAL dual electric fans (slim, unkown CFM) will post pics.- $200 Last edited by jetpower; 11-02-2012 at 12:05 AM.. |
#832 | |
#833 |
Hey guys Im currently starting to rebuild a 2JZ-GE and was just wondering if they have any common problems. Im going GE cause I just want some NA fun and figured I could always go NA-T later on if I wanted.
@hcr32love 400whp NEO R32 Sedan |
#835 | |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
DISCONTINUED BUT FEAR NOT WE HAVE A BETTER SOLUTION! - Replacement for GReddy BCC
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#837 |
The front frame needed to be cutout by an inch and a half but it's possible. The only thing is that the temp rises a little at idle only when the A/C is on..sigh....
FYI: you will need to trim the TT blade in order to clear the shroud. Here is my cooling setup: -7M shroud -7M auxiliary fans -TT fan blade -TT clutch -Koyo Radiator ![]() ![]() ![]() ![]() |
