#8431 |
![]() Join Date: Sep 2009
![]() Feedback Score: 10 reviews
N00b question, can I clear my 30mm z32 brakes on my s13 if I use 15x8 -30 without any major camber or fender modification? Apreciate it ahead of time.
#8432 |
![]() Join Date: Aug 2006
![]() Feedback Score: 12 reviews
Replaced the maf with a working with and same problem. It would start up and try to stay on for about 5secs and die T_T is it my timing? Extra chassis grounds to the maf?
#8434 |
![]() Join Date: Dec 2010
Trader Rating: (39)
![]() Feedback Score: 39 reviews
Suspension Question
would these POWER MOVE!: Era1 drop spindle kit fix chassis geometry by themselves or will they need PBM rear subframe spacers as well? or if both combined would it mess up the cars geometry all together from both PBM and the era1 combined?
IG - allen.kerose |
#8437 | |
If your coilovers have camber plates on them that would allow you to adjust the front camber only otherwise you couldn't really adjust the rear camber can not be adjusted with stock arms |
#8438 | |
#8439 | ||||
![]() Join Date: Dec 2004
Trader Rating: (58)
![]() Quote:
FWIW: I can't stand MAP based turbo cars at streetable levels. Quote:
The spindles will help fix, the risers just furhter help the rear.
#8441 |
I have Stance GR+ Pro coilovers. Not 100% if they have camber plates on them. If I just want to adjust the camber do all I need is aftermarket arms?
#8442 |
Gauges.
How good of quality are Apexi gauges? I would think pretty decent since it's Apexi, but I never hear or see anything about them. Also, what gauges are worth using? I was planning on boost, water temp, and oil pressure. It seems like most people run the first two and then use oil temp instead of oil pressure. I had heard your water temp and oil temp would be similar at most times, false? Is an oil pressure gauge not as important as I'm thinking it is? Thanks |
#8443 | ||
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Yeah. I didn't really think it would affect anything at all. Just making sure. Thanks.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#8446 |
I just tightened (or tried to) tighten my transmission in today, and 3 of the 4 bolts were a bastard to get even threaded. Only one went on all the way, the other 3 wouldn't even seat against the crossmember. What's going on here? It stays in place but like I said 3 bolts aren't tightened down. I hope I didn't strip anything. They started to go in, then decided they wanted to not.
#8448 |
![]() Join Date: Dec 2007
Trader Rating: (68)
![]() Feedback Score: 68 reviews
Check the heater hoses going into the firewall, there should be two. Those two lines hold coolant and the lines are directly on top of each other.
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! ![]() http://zilvia.net/f/private-sellers/...meistah21.html |
#8449 |
Can anybody tell me whats the best seat rail for the price. I check for nagisa or buddy club... Buddy club is cheap $ compare the nagisa. I search for some information and dont have any answer. People hate or love buddy club. Im 6 feet tall and right now is bottom mount with my bucket momo corse and its like the stock position... So its too high and with my helmet is like hella flush with the roof. My bucket have two setup... buttom and side mount
#8450 |
![]() Anyone run into any mechanical problems or have cons when removing your clutch dampener box? Planning to remove it today since I just replaced the master clutch cylinder and slave, and need to do bleeding. I understand it'll be firmer (and some prefer it) but could anything go wrong?
#8451 | |||
Trader Rating: (58)
#8452 |
![]() Join Date: May 2006
![]() Feedback Score: 6 reviews
Was going to install nismo tstat today in sr20 noticed some slight corrosion in the housing anything i can soak it in to get rid of the corrosion? I plan on getting a radiator flush kit and flushing it when I get it all back together.
#8453 | |
![]() Join Date: Dec 2008
![]() Feedback Score: 15 reviews
New question, KAE and DE transmissions. 240 to truck are they different ratios? It would seem the truck would have longer gears but top speed would lack? |
#8456 | ||||||
![]() Join Date: Dec 2003
15x8 -30? WHY? Quote:
Sounds like a matter of opinion, we cant answer that here. You can ask what companies make Kouki s13 replica aero, and look through them allowing you to decide "the best" for yourself. Quote:
Sounds like you fucked up. take everything out and start over. Quote:
You want the lowest? You want the cheapest? You prefer side/bottom mount? You want the brand that matches your seat? You want someones opinion on what they think is best? Come on people you gotta work with us with these questions. As far as i know there are no years of BMW rims that are 5x114, so no. There are companies that make 5x114 to 5x120 adapter/spacers, however is you ask me what companies they are without typing it into google first I will overnight a honey badger to your house, and tell it you have honey. You guys make me feel all ![]() ![]() These questions are ![]() ![]()
![]() **CoUpe LOve** Member #00 |
#8457 |
![]() Join Date: Mar 2011
im not a stranger to 240s and i have searched google and this sight and im stumped...but i just did a 5speed swap to my 92 SE and now she idles at damn near 1500rpms and i dont know why. the idler screw is all the way in and it still does the same thing. i also checked mythrottle cable and cruise control cable and there both fine. i also still have the auto ECU. 2nd i put in a brand new clutch and now i hear sort of a buzzing noise coming from the tranny near the flywheel. it sounds like the throwout bearing but i dont understand how when its new. you mostly hear it in neutral and when you accelerating in 1st 2nd and 3rd gears. you dont hear it in 4th and 5th. any impu would be appreciated
#8459 |
Depends where the leak is from, and how bad it is... I usually only hear of people using Lucas in their oil if the engine is burning oil.
#8460 |
this is going to sound stupid as fuck,
but i just disassembled my extra s13 rear subframe/ suspension. now i have the axle/axle housing/ hub/ lower control arm still together. i want them apart HOW THE HELL DO I GET THIS DAMN AXLE NUT OFF?!?? the axle keeps spinning and i obviously cant break it loose with the pos spinning, i tried to get crafty and bolt my fender roller to it so i could use my legs/ weight to hold it and my upper body with a breaker bar but no luck. any ideas? i dgaf about everything except the axle housing as id like to cut it for a dual caliper bracker, powdercoat it, replace the bushings, get new axles and components and 5 lug hubs to go with the other new suspendion parts. ideas? im super frusterated right now, almost to the point of saying fuck it and just ordering some from a sslvage yard. just seems like a waste because my dumbass couldnt get the perfect ones i got free from the 20 yr old bullshit |
