11-12-2011, 10:15 PM | #8522 |
Hey guys. I have a question... I have my power steering connected and all, but my hose is slightly ripped or torn. I just got my motor rebuild and don't want all that fluid getting everywhere. I wanted to know what belt I can use that just connects to the crank pulley and water pump... maybe there another car that has the belt that can wrap around the crank pulley and water pump...
lmk guys |
11-12-2011, 10:37 PM | #8523 |
Dude, take a piece of string and measure it. Take string to parts store and have them find a right sized belt.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
11-12-2011, 11:04 PM | #8524 | |
One problem, on a KADE the power steering is used as a tensioner. Not an easy fix without doing some fab work. |
11-12-2011, 11:24 PM | #8525 |
Is it possible to remove frame rust from a door jam on the driver side on a kouki? If so how long do you think it would take me to do it if i had all of the necessary parts?
11-12-2011, 11:28 PM | #8526 |
iI know about the measuring, just was curious if u guys knew what exact belt it was from some car ya know. but I guess Ill just measure it. And I would buy a new hose but I have no job and broke. =(
But thanks for answering guys. |
11-13-2011, 12:03 AM | #8528 | |
(Just to clarify, I'd send you a couple of feet of hose for the cost of shipping. I neither have, nor do I sell fittings) |
11-13-2011, 09:55 AM | #8529 | ||
Does it whine all the time? What fluid are you using and is the fluid boiling after a drive? |
11-13-2011, 02:59 PM | #8531 | |
Bump for me. Need some help... |
11-13-2011, 05:47 PM | #8532 |
this is another low oil pressure question. my engine was fully rebuilt back to stock with new oil pump, gt2860rs turbo, and innovate electronic gauge. i had an oil leak from a crack in the timing chain tensioner, but that has been fixed. at start up pressure is at 60psi and holds steady. once its warmed up im getting 40psi @ 3k and 6psi @ idle. i have no idea what to look for. the only thing i can think of is im using the wrong restrictor (.062 from dif ss lines) am i crazy in thinking 6psi is low?
11-13-2011, 07:40 PM | #8533 | |
Trader Rating: (58)
Feedback Score: 58 reviews
11-14-2011, 08:17 PM | #8536 |
I have an s14 sr20det in a s13 and everything works properly but my coolant temperate gauge on my cluster.. What could possibly be the problem why the gauge doesn't work? I know for the fact it's not wiring.. I've changed my thermostat to a nismo one and changed the coolant temperature sensor. What other problems should i check for? re bleed the whole system?
11-14-2011, 08:52 PM | #8537 | ||
80 81 82 83 84 Toyota Cessida tail light taillight 22-104, NO cracks or cut wire | eBay Quote:
Edit: On this piece. It's more obvious than the picture makes it seem.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
11-15-2011, 12:44 PM | #8540 | |
Trader Rating: (31)
Feedback Score: 31 reviews
g-corporation, i'm sure it fits well.
Slip Gypsies Blog Quote:
11-15-2011, 01:57 PM | #8542 |
Just a heads up, there is not very many sides and rear other than gcorp that will look good with that front. Its super low.
11-15-2011, 02:02 PM | #8543 |
the problem is, i got kouki sides, and rear valances,...but i'm not a fan of the OEM Kouki front bumper,...my favorite is GT1 Break ito,...but shipping to germany is killing me :/
11-15-2011, 02:05 PM | #8544 |
Gcorp will not be any better and will not look good with stock sides.
probably cheaper to buy a OEM front bumper from here (USA) and find yourself a GT-1 lip. But even that will hang lower than stock sides. Im not saying dont do it, just trying to help you make an informed decision before throwing money away.
11-15-2011, 02:07 PM | #8545 |
anyone having fitment issues wit hood dampers for the s13? i tried different lengths but the dampers get in the way when closing the hood.... any feed on this would help...
11-15-2011, 02:17 PM | #8546 |
that's the point,...really likin the form of oem sides, but they are high as fuck,...probably it's the best choice to go for a oem front end,...wish the sides would be about an inch lower.
I don't want to waste my money too,...but in common to a g-corp or anything similar a oem one won't be cheaper. What about a Version Select one? |
11-15-2011, 02:25 PM | #8548 |
Mmmh,...at the moment i hate beeing german,...damn you shipping.
Okay...got some time left to make a decision, thanks for your help. It confirmed a lot that i was thinkin |
11-15-2011, 02:41 PM | #8549 |
lol dont hate being German, hate being in Germany.
Good luck tho. Maybe URAS type 2?
