#62 |
![]() Join Date: Apr 2008
![]() Feedback Score: 15 reviews
Thanks, I sold it to fund this build. Funny story really, I bought it as a shell from a dealer auction it was me and a scrapper bidding on it. I saved it from the crusher and i brought it back to life.
Pics! Czp track rotor adapter bracket for calipers ![]() Big brakes!? 350z track rotors behind 300zx 30's. ![]() I decided to ditch the wicked arms. I got some new spl arms! ![]() stance coils ![]() |
#66 |
Second time installing a new Walbro on this chassis
![]() How I left my subframe today 300zx ebrake assemblies and cables. still need a diff. ![]() little teaser pic.. should be back on the road soon 285/35/18 ![]() |
#67 |
Can i get some info on the KA?
Reliable? good power? what parts had you used? ^those are personal questions but if your interested in having an article written on your car (when your done of course) lemme know. I write for a popular blog. |
#70 |
Swapped the oem fuel Lines from pass. frame rail to the drivers. I also drilled and tapped a few holes to use oem brackets and hardware.
![]() ![]() got the r154 back together, took a few attempts to go in gear haha ![]() |
#72 |
Thanks!
I got the subframe all back together and installed. Il be pulling the diff back out soon to swap in a s15 and paint it then, this will work for now. ![]() Test fit a back wheel but the toe camber and caster are all off. ![]() Last edited by sterlinge; 12-12-2012 at 07:11 PM.. |
#73 |
I run the 300zx brakes all around with the 350Z track rotor upgrade and the 15/16th BMC and the brakes bite hard, also using hawk HPS pads though.
you will really like your braking system ![]() |
#77 |
Long day chasing parts went to san antonio Toyota and austin Toyota dealers today to get some parts I needed.
Clutch release on pressure plate finally ![]() Got the correct flywheel bolts after 3 attempts so the flywheel is officially bolted down. ![]() Lined up the clutch disc with pilot bearing ![]() The trans is now bolted to the engine! ![]() |
#78 |
Got some more work done on the engine. New gates timing belt installed, new oem water pump installed, torqued cam gears back down also cut the upper water neck to use my ka style radiator. New ps pulley also (:
#80 |
Very proper build. I do like where this is going. Just be sure to post lots of action vids once the motor is in and running! What are the plans for the motor anyway? stock twins with BPU or Big single turbo?
#81 |
Thanks guys,
Il be running stock twins for awhile. I will have some badass updates within the next few weeks that everyone will enjoy. Got some FAL 12" fans and derale controller ![]() I made a run to the scrap yard to pick up some part money haha ![]() |
#84 |
DIY fuse box relocation took me about ...Ehh. 10 minutes max and anyone can do it!
Of course you will need to extend a few wires! (Sarcasm) ![]() Ok for real though I started the fuse box relo job today and there is a reason you see no write ups on it. I'm doing one wire at a time right now I'm almost done with shortening the length between the fuse boxes. I should be finished with this tomorrow if I get some time to work on it. Starting ![]() Got a few done here ![]() And this is were i called it a night ![]() |
#85 |
I need to extend maybe half of the loose wires and I will be done! With that part anyways..haha
I'm closer to being finished than the pic shows, thought I took one no big deal. ![]() |
#87 |
Finished with the relo. Leaving it this way till I have the engine harness wired up then Il install the dash again.
![]() Last edited by sterlinge; 12-30-2012 at 09:08 PM.. |
#88 |
Small update. Went alittle crazy with my budget and bought a racepak iq3 display. I still need to buy a usm for it and a few sensors. I'm going to start mounting up the ic pipes when some couplers show up this week. Il keep you guys updated I should be cruising this soon!
#89 |
No pics today just thought i would update. Got the driveshaft on wed and installed it, fit all nice like. I went to test my turn signals after the fuse box relo. They were not working right I beat myself up thinking what it could be while i worked all day thursday. When i got off work I decided to trouble shoot from the basics. I go to check the fuses and they are all fine but i noticed I never tightened the center bolt down for the fuse box harness -_- ... Ok so thats done. I'm going to buy some 240sx harness pigtails so nothing is hardwired and can be removed easily if its needed, Il be starting on that this weekend along with double checking what i have done so far. Il have some actual pics for you guys on monday.
