Old 10-16-2007, 08:18 AM   #1
slohybrid
slohybrid's Avatar
slohybrid is an unknown quantity at this point
FS: parting out 91' 240SX hatch SR20DET lots of stuff!!!
I have decided to part out my car. The following items are in almost new condition (LESS THAN 100 MILES ON THE ITEMS):
This stuff comes off of my S13 hatchback:
Chargespeed carbon fiber hood S13 hatch (CF on both sides) w/ hood pins installed--SOLD
345.00--NEW LOWER PRICE
JIC Sparten DE 3” cat-back exhaust
Battle Version rear upper control arms--SOLD
700.00--SHIPPED NEW LOWER PRICE
Power FC w/ hand held commander (MAFS set-up not MAP)
345.00
FC Datalogit w/ USB cable and software
50.00
Tanabe front under brace
280.00--NEW LOWER PRICE
Godspeed bar and plate intercooler kit for a KA24DE top mount w/ extra couplers and clamps
120.00
Aeromotive fuel pressure regulator w/ -6AN fittings and plug
100.00
Apex’I intake filter for Z32 MAFS
Blitz FATT turbo timer w/ P2M turbo harness--SOLD
400.00--NEW LOWER PRICE
Fastbrakes Q45 brake kit (slotted and drilled rotors, stainless steel brake lines, Axxis metal brake pads, Q45 calipers) (4 and 5 lug drilled)
S14 seats (pair)(used in excellent condition)--SOLD
Replacement black carpet hatchback S13 (NEW still in box)--SOLD
Brian Crower 264 cams (set new in box)--SOLD
Nardi Steering Wheel deep corn with Circuit sports quick release and sparco hub--SOLD
Peak Performance inner pro/ and outer street tie rods w/ boots--SOLD
Battle Version tension rods--SOLD
Megan coilovers--SOLD
Whiteline front and rear sway bars w/ links and Whiteline sway bar bushings--SOLD
Peak Boost exhaust manifold (top mount T3 flange), Peak Boost o2 elbow with 3 o2 bungs welded in (one plug, one stock o2 adapter), Peak Boost downpipe, v-band clamp, turbo to manifold gasket, Tial wastegate 38mm with 15# spring--SOLD
GT3076R Garrett turbo w/ ported shroud, heat coating, and polished--SOLD
Driveshaft Shop one piece aluminum driveshaft--SOLD
Koyo aluminum radiator--SOLD
ATI crank damper--SOLD
(4) side feed 1000cc/min. injectors (drop in) (set)--SOLD
(4) side feed 660cc/min. injectors (drop in)(set)--SOLD
Chargespeed carbon fiber S13 hatch headlight covers--SOLD
Aeromotive A1000 fuel pump w/ -10AN and -8AN fittings installed--SOLD
S13 OEM Kouki Type-X front bumper w/ side pieces--SOLD
ARC BOV--SOLD
R33 GTS-T LSD w/ axles (has clutch type LSD in it) already has correct diff. cover for direct bolt on to S13--SOLD
SR20DET motor w/ tranny—SOLD
Fully built SR20DET block by Mazworx--SOLD
It has been sleeved with Golden Eagle ductile iron sleeves 90mm bore--SOLD
O-ringed and comes with stainless steel o-rings (stainless steel wire)--SOLD
oil grooved at the mains
decked with oil pump front cover (included used)--SOLD
macined to accept ½ inch head studs (will include head studs ARP new)--SOLD
(4) CP pistons with rings, lateral gasport, double pin oiler, accumulator grooves, heavy duty wrist pins and locks (set new)--SOLD
(4) Carrilo rods (new)--SOLD
Set of calico coated ACL main bearings and thrust bearings (new)--SOLD
Rear brake calipers--SOLD
OEM side skirts--SOLD
4th Degree Black Belt Hapkido
Skydiver
Got no drifting skills (haven't tried)
slohybrid is offline   Reply With Quote
