Old 06-21-2008, 11:20 AM   #61
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Dear Mr. Smog Tech,
My S13 failed NOx last week. Is it likely that it failed because of my 3" exhaust? I have heard that the lack of backpressure doesnt let the EGR operate properly. Any insight into this?
ryguy is offline   Reply With Quote
Old 06-21-2008, 12:36 PM   #62
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
i have a ?. im putting my ka24de s14 back into my s14 its a 95. i want to know if i can pass smog with some header i have. i believe they are obdx headers they have the egr value connectors and so if i install before i drop it in will it pass smog, or would it be better to just put on the regular exhaust manifold and pass smog and then change it?
grnappletree14 is offline   Reply With Quote
Old 06-21-2008, 01:10 PM   #63
murda-c
murda-c's Avatar
When you plug into an OBD2 motor, does it give you information on what type of motor it is?
I'm just wondering if i swap for another obd2 motor and i get it running properly and not throwing codes if they'd even notice.
Old 06-22-2008, 06:03 PM   #64
techn9ne
techn9ne's Avatar
techn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the roughtechn9ne is a jewel in the rough
Send a message via AIM to techn9ne
Originally Posted by ryguy View Post
Dear Mr. Smog Tech,
+1 internets
techn9ne is offline   Reply With Quote
Old 06-22-2008, 06:10 PM   #65
techn9ne
techn9ne's Avatar
it depends. if you get mr by the book smog tech, he will look at the headers and look for a CARB exemption # or an EO (executive order) #. if those arent there, he will fail it on the spot.
if you get the guy that doesnt really care, as long as he sees that the headers have the egr valve connectiors and all the vacuum lines and shit are connected, he probably wont give you grief.
i would just throw on the normal exhaust manifold just to be sure, since your already throwing a whole new engine into the KA, then just swap it later.
Old 06-22-2008, 06:19 PM   #66
techn9ne
techn9ne's Avatar
some obd 2 pcm's will tell you the VIN number of the car they originally came in. but the only thing the smog machine checks for is readiness monitor status and diagnostic trouble codes.
Old 06-23-2008, 12:37 AM   #67
GSXRJJordan
GSXRJJordan's Avatar
+a shit ton for this thread. Thanks a bunch man
Old 06-24-2008, 05:33 PM   #68
shade
shade's Avatar
shade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond repute
What does the visual check comprise of? I'm practically asking for the whole procedure. I might just do what HyperTek said earlier.
shade is offline   Reply With Quote
Old 06-24-2008, 05:42 PM   #69
SilviaS132008
SilviaS132008's Avatar
SilviaS132008 is an unknown quantity at this point
Dude, ok my 240 doesnt turn over, its been sitting for a year. what you think is the problem??
SilviaS132008 is offline   Reply With Quote
Old 06-24-2008, 05:52 PM   #70
slipin101
slipin101's Avatar
slipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura about
Send a message via Yahoo to slipin101
Dear smog tech
i justa had a smog but failed
heres the list of wat i failed...........
fuel evaporative control funtional
MIL/check engine light
everything else is good.
how can i fix that? i know its a leak but how would i go by finding it, i tracked it down to the rear end of the car but no luck finding it. HELP!! need smog ASAP
slipin101 is offline   Reply With Quote
Old 06-24-2008, 08:59 PM   #71
techn9ne
techn9ne's Avatar
heres how most smog techs run the visual. they pull the car in, pop the hood, and read the vehicle emissions control information sticker on the underside of the hood. (if you dont have one, we have a manual that tells us the timing specs, emissions components, etc on every car. we're just too lazy to look at it.) theyll jot down the timing spec, engine size, and emissions components they'll look for on their notepad or whatever, along with the mileage, etc. then your car gets put on the dyno. after the dyno run, the computer asks us to inspect (if applicable) the air injection. so pre-94 240's better have the pulse air shit hooked up. then, we look at the pcv, ignition controls, oxygen sensors, fuel rail/injectors, egr valve, vacuum lines, wiring, look for smoke coming off the engine or out of the tail pipe (new test will fail you for visual smoke), liquid fuel leaks, etc. then it asks if the check engine light is on. 95 and older cars will only fail if the mil is on and the smog tech enters that it is on. 96 and newer fail that test automatically, thanks to obd2. then it asks to check idle speed, and timing.
however, alotta smog techs are lazy as fuck, or if the smog joint is busy, they will not even bother to give the engine a second glance and will just pass everything on the visual.
but generally, you'll have Mr. 'merican performance chevy 350 master, who generally doesnt know what and SR looks like. and if he doesnt bother looking at the engine because "its a goddamn piece of shit rice burner," and "all these 4 bangers are the same"
Old 06-24-2008, 09:00 PM   #72
techn9ne
techn9ne's Avatar
check your blinker fluid and muffler bearing.
Old 06-24-2008, 09:01 PM   #73
techn9ne
techn9ne's Avatar
if that doesnt work, try making sure your rotary seals aren't blown.
Old 06-24-2008, 09:05 PM   #74
techn9ne
techn9ne's Avatar
Originally Posted by slipin101 View Post
Dear smog tech
the evap control functional is that test where they hook that hose up to your gas tank, pinch the line going from the tank to the canister, and pressurize it.
i would check all the rubber hoses connecting from the gas tank up front to the charcoal canister, then the filler neck on your gas tank.
the check engine light on a pre-obd2 car is an insta fail. so try pulling the code off the ecu and go from there.
Old 06-24-2008, 09:18 PM   #75
240trooper
240trooper's Avatar
240trooper is a well-known jackass
Send a message via AIM to 240trooper Send a message via Yahoo to 240trooper
they might need to rotate the headers allso,
2.7L
240trooper is offline   Reply With Quote
Old 06-25-2008, 01:13 AM   #76
dynamicck
dynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to behold
mr. smog tech, I think you should pull the info of where you work off this thread or other threads, and your location.
I would hate to see this thread get into the wrong hands.
Never learned half this info from anywhere else.
+1 for you.
dynamicck is offline   Reply With Quote
Old 06-26-2008, 02:11 PM   #77
techn9ne
techn9ne's Avatar
+1 for you.
im not worried about it. im helping people pass legitimately, i dont see anything wrong about it.
Old 07-12-2008, 04:45 AM   #78
proud2b3black
proud2b3black's Avatar
proud2b3black can only hope to improve
Send a message via AIM to proud2b3black
s14
from what i read earlier it said that if i remove the light bulb for the check engine light then my car can pass smog? im not getting it exactly cause im really looking for a place to smog my car non-legally but if thats all i have to do then let get that done. i know that the check engine light is part of the visual inspection part only so how else would it fail?
1996 zenki 240sx
proud2b3black is offline   Reply With Quote
Old 07-12-2008, 10:06 AM   #79
techn9ne
techn9ne's Avatar
1996 zenki 240sx
for your car, since it is obd2, you cannot pull the check engine light bulb if it is on. 96+ cars we plug into the smog machine and it reads codes directly from the ecu. and you cannot just disconnect the battery either, since the machine will fail you for having incomplete readiness monitors. and to expand a little more, on 95 and older cars, if the check engine light is on, you automatically fail the inspection. if the check engine light doesnt work, you automatically fail the inspection. both of these rules apply to all cars, but since we dont plug 95 and older cars into the smog machine, and the bulb is off, (disconnected or not lit) and the guy does not bother to check if it works, then you will at least have a chance to pass, as long as your car runs the rest of the test fine (visual and tailpipe)
Old 07-12-2008, 10:23 AM   #80
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Originally Posted by twistedsymphony View Post
+1 to this... "astute" techs will notice that the CEL doesn't come on when the car goes through the self test... notice when you first turn the car on all the warning lights come on... this is so you can check if the bulbs are dead. wiring up the CEL to the oil light works great because it will come on with the self test and then go off once the car is up and running.
There are things you can do to the Auto ECU to prevent it from throwing a code, I haven't done it but I've heard its not too difficult, Manaul ECUs go on eBay and the BST all day for $60...
not sure what years yours is but there's a nissan sticker on it with two big letters cross reference those to figure out what it is
Automatic ECUs
11 = 89-90 240sx AT (KA24E) ?
15 = 89-90 240sx AT (KA24E) Cal
25 = 91-94 240sx AT (KA24DE) ?
29 = 91-94 240sx AT (KA24DE)
HU = 95 240sx AT (KA24DE) (mfg before 10/94)
3D = 95 240sx AT (KA24DE) (mfg after 9/94)
CB = 96 240sx AT (KA24DE) Universal
NF = 97-98 240sx AT (KA24DE)
J7 = 97-98 240sx SE AT (KA24DE) (A18-H64 GA4)
Manual ECUs:
10 = 89-90 240sx MT (KA24E) ?
24 = 91-94 240sx MT (KA24DE) ?
28 = 91-94 240sx MT (KA24DE)
HT = 95 240sx MT (KA24DE) (mfg before 10/94) (A18-E07-G90)
3C = 95 240sx MT (KA24DE) (mfg after 9/94)
CA = 96 240sx SE MT (KA24DE) (A18-E27-G46)
^thats a list I've been working on, it's not complete so if you've got something else then you'll need to google about. My car has "HU" because it's an early model 95 with an AT ecu...
i know i know off topic but was wonderin sorry to kill thread
was wondering mine has a EP on it and mine is manual 93 ka24de is there anyway to confrim this ecu actin all wierd
S-Nation S13 is offline   Reply With Quote
Old 07-26-2008, 04:54 PM   #81
nysmo240
nysmo240 is an unknown quantity at this point
Waddup? I have a 96 S14 that passed the emissions test but failed becuz the CEL wouldn't come on. The smog tech said that my ECU wasn't throwin any codes eithr so I though it was a burnt bulb. I then bought a bulb from Nissan and just swapped it out with the old one, and still no light. I unplugged the battery for a good several seconds and reconnected, but still no light. I also put the ECU in diagnostics mode and then had it reset, but still not light. Any ideas?
Also, some of the guys here wrote about rewiring it to the oil pressure light...can anyone tell me how u do that and which wires to rewire on the back of the instrument panel? I'll also be lookin it up in my manual in the meantime to try to figure it out.
Thanks.
"Life is...Vuetiful!"
nysmo240 is offline   Reply With Quote
Old 07-26-2008, 05:45 PM   #82
nysmo240
NVM...for some reason...it's now working. I'm not sure if this may be why, but I stuck a wire from the the oil pressure wire to the CEL wire and then it came on, and stayed on after i removed the wire...maybe it just needed a jumpstart..haha.
Old 07-26-2008, 10:54 PM   #83
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
my speedo in my s13 doesnt work will this be an issue in my next smog test??
redline racer510 is offline   Reply With Quote
Old 07-29-2008, 10:28 AM   #84
techn9ne
techn9ne's Avatar
Thanks.
there might not be power/ground going to the wires that turn that bulb on. the light should come on if the key is in the on position but the car is not on.
Old 07-29-2008, 10:28 AM   #85
techn9ne
techn9ne's Avatar
as long as the check engine light is not on, you should be fine.
Old 07-30-2008, 01:12 AM   #86
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
My girls car...
91 S13.
95 KA-DE.
New cat.
Timing is perfect.
Recently Seafoamed to clear the carbon deposits.
New plugs, wires, cap and rotor.
EGR works perfectly...
Nox is STILL 6 times over the legal limit. Any ideas?
-Kyle
Old 07-30-2008, 01:19 AM   #87
flclsteve
flclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant futureflclsteve has a brilliant future
Originally Posted by soreballz View Post
My girls car...
91 S13.
95 KA-DE.
New cat.
Timing is perfect.
im sure u changed the o2 sensor with the new cat right?
off topic
new plugs and wires still misfiring gonna try a new cap n rotor tommrow too and i also need to check timming
flclsteve is offline   Reply With Quote
Old 08-06-2008, 05:18 PM   #88
techn9ne
techn9ne's Avatar
My girls car...
91 S13.
95 KA-DE.
New cat.
Timing is perfect.
does she have heinous 3" exhaust? (the car) is the backpressure valve working correctly? is the pulse air hooked up? what test is it failing for?
Old 08-06-2008, 06:17 PM   #89
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Wurd. Good oil change? ^^ What did you fail at...
I pass well with.
S14 95 KA
Stock cat
3' exhaust
AEM intake
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 08-06-2008, 08:40 PM   #90
flclsteve
Mr smog tech.
I have a 97 honda civic witch just got approved for assistance with smog repair fees it failed for high Nox during the 15 mile per hour run
any idea what it might be its a bone stock car
