![]() Join Date: Jan 2008
Location: Amerika24 alabama: Where if your not first..... your last
Z32 aluminum uprights weight 7-8 lbs. less and that is unsprung weight on the rear
![]() Im about to do mine. Only problem is you will have to use a fork type rear strut like the Z32 or you can weld on a different top piece
![]() Join Date: May 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
I hear what you guys are saying about removing as much as possible. From my experience, the lightest car does not win championships. The most well balanced and consistent car does. And i am just as passionate as the next guy about weight reduction. But unless i see you out there winning contingency money with it, it doesn't mean much. It is just one of many aspects. It isn't rocket science. Once you are happy with your chassis stiffness/weight, you move on to the other areas that need attention. When i started working with World Racing on the super light AWD car, we were all excited for the debut. I flew all the way to Sebring just to support the car. The car sat all weekend due to electrical gremlins. They put alot of work into weight reduction, and spent tens of thousands on hauling a fully staffed crew and rig out there. It is a half a million dollar car! Kognition has two championships allready in the bag with two sponsored time attack teams this season. They are not the lightest nor the most powerful cars in their class. And certainly not the most well funded. They are the most balanced, and consistent cars in their class.
#4 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
As before I do not discredit the bantam weight obsession, I just think there is often to much emphasis put on it for street based cars. Quote:
#5 | |
![]() LOL |
#6 | |
![]() Join Date: Apr 2004
If you were making a general observation of Zilvia, then yea, I'd say a lot of guys spend way too much time obsessing over weight when their car is just not well put together or setup. You'll gain way more time making sure everything works well together vs. taking off 50 lbs on your car and having it be setup like a nightmare. Oh another note, went to a local shop and saw a Koni yellow piston vs. a Stance coilover piston. The stance piston was laughable. So was their adjuster mechanism.
#7 | |
![]() Seriously though... You daily that car don't you? There isn't much for you to do. I have nothing under the dash except wires and an ecu, no stereo, no driver or pass windows, carpet, sound deadening, panels, super light wheels... I could go on but, this is no longer a car anyone should drive on the street.. If you're not using your car to get around anymore, then go for it. If you already took care of suspension and power, which I know you have, the only two things left for you are aero and weight reduction. |
#9 | ||
Trader Rating: (58)
#11 | |
#14 |
Yeah I am definitely going to sell off these Stance coilovers as soon as I have a chance. Riding around like I'm bouncing on a pogo stick is not fun.
#15 | ||||
![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
#17 |
![]() Join Date: Oct 2004
Man, seriously you can't compare cars on the track.... Weight is weight period. It does make the car handle better in corners under breaking and under acceleration period. For comparing cars, that ebisu east course is a power course. Long corners and uphill are for power. If we were more on a flat track with less elevation change and more technical tracks would be an S2k track. Hence that is what the late Tanabe-san from Amuse said at the beginning, both cars have different characteristics therefore the track can make a huge difference.
Adequate power is important, but on our S chassis that is totally not balanced, suspension and rear downforce is the most important period. I do trackdays a lot and so does racepar and lot of other guys that spank porsches all day. But whatever, weight is an all around factor, HP means nothing. 20WHP difference vs 20lb loss, I'd take the 20lb loss especially in the front end of the S chassis. So we can't say a 100/30 whp/tq difference can be made up that easily, but a 20-30 whp can be with weight. I will be at Laguna and another track this month, hopefully I get some video hahaha....
#18 |
20lbs lost in the front is easy. Replacing the stock hood with an aftermarket FRP hood will get you there.
Lighter brakes like Def's new hotness will also help. |
#20 | |
Trader Rating: (58)
When torque isn't readily available (persay in an N/A 2.0 engine) I'd vote for as light as you could get that platform.
#21 | |
![]() 2000lb (wet weight w/o driver) is easy to get to. I'm at 2280 right now, and I haven't messed with the front and rear windshields, hatch, fuel tank, front and rear bumpers, fenders. |
#22 |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
<object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/GCqznVv55ac&hl=en_US&feature=player_embedded&versi on=3"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/GCqznVv55ac&hl=en_US&feature=player_embedded&versi on=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></embed></object>
http://www.youtube.com/watch?v=GCqzn...layer_embedded |
#23 | ||
Hmmm... Sounds like I, as well as the car, need to go on a diet, I weigh about 260~270 lol... I plan on gutting out the car, it's currently a SE model w/o sunroof (thank god!) which I plan on downgrading to a base model, luckily, I have a friend who has a base model and wants all my power accessories, so if/when we finally get around to doing the swap I can weigh all the parts and post that up. I do have a 4.36 final drive to help with the lack of power, and I don't plan on going lexan anytime soon but maybe in the distant future that would be a possibility.The car is currently a rolling shell and I plan on getting it running in stock trim so I can learn the characteristics of the car being that this is my first S chassis and first RWD car. |
#24 | |
Trader Rating: (58)
Good friend of mine had a NX2000 that used to be a full on N/A car with a upgraded final drive and bolt ons(hotshot header, intake, JWT S5 cams, etc etc) and it was a blast to rocket it to north of 8000 rpm) He's since went VVL (which is even more fun as it isn't totally gutless) but man that thing loved the upper RPM
#25 |
If it's VVL then he definitely should be around 8000-8500rpm all day.
If it has a DE bottom end, then forget it, 9000rpm all day. |
#26 |
^^ I think that was a full cf turbo s2k LOL.... Its a great car, but its a beef'ed up miata LOL..... maybe a little better than the miata....
#27 | ||
![]() Quote:
![]() Back to the original topic of this thread... How about going Silvia front, isn't there a significance difference in weight since the pop up lights have all those parts as opposed to the fixed Silvia lights? |
#28 | |
All you have to do is take the motors out and the remaining front light assembly will be VERY LIGHT. |
#29 |
Hmmm... I've always thought the Silvia front was better in the aero dept. and maybe even yeild a better coefficent of drag, I guess I was wrong. I guess it would be smart to at the very least convert to Hella housings for the front end, those should considerably lighter than the glass housings, correct?
#30 | ||
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
s13, weight reduction |
