Old 01-17-2012, 09:23 PM   #61
Thethrash
Thethrash is an unknown quantity at this point
Hey guys so i have been trying to smog my 91 240 (dohc)
it passed everything except the nox(common thing with 240s)
so i cleaned the egr valve and the metal pipe that goes around form the exhaust manifold to the air manifold.
My nox was reading 3300. and i was wondering if that's possible, perhaps i hooked the egr back on wrong?
can some one please help me :/
Thethrash is offline   Reply With Quote
Old 01-17-2012, 10:33 PM   #62
darkslide92
darkslide92's Avatar
darkslide92 is an unknown quantity at this point
Did you check to see if the egr works? Squeeze it and see if it dies/stalls
darkslide92 is offline   Reply With Quote
Old 01-19-2012, 03:45 PM   #63
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Damn smog gremlins chasing me again..
15 mph
HC 61/64 FAIL BY 3 CO 0.52/0.07 NO 493/847 FAIL WTF
25 mph
HC 47/41 CO 0.50/0.05 NO 516/952 FAIL WTF
I replaced my egr 2 years ago along with the egr solenoid and the egr BPT .. I cleaned the passage way to the egr via the 10mm hex bolt sea foam the engine except running it crank case I only did gas and intake ??? What else should I do???
S-Nation S13 is offline   Reply With Quote
Old 01-20-2012, 01:40 AM   #64
S-Nation S13
Trader Rating: (92)
No one ? Insight ?.
Old 01-20-2012, 01:49 AM   #65
hassanbakar123
hassanbakar123 is an unknown quantity at this point
is the timing right? what was the CO2 at?
hassanbakar123 is offline   Reply With Quote
Old 01-20-2012, 03:01 AM   #66
koenig
koenig is an unknown quantity at this point
get a little under half a tank of gas in your car, then put in like half a gallon of denatured alcohol in the tank, and take smog again.
Makes your shit CLEAN but then as soon as you leave, go fill up your tank and drive nicely
koenig is offline   Reply With Quote
Old 01-20-2012, 09:08 AM   #67
S-Nation S13
Trader Rating: (92)
Timing is at 18 btdc co2 is at 15 mph 14.2 25 mph 14.3
Old 01-20-2012, 09:18 AM   #68
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
awww what happened to the pics
upsdude is offline   Reply With Quote
Old 01-20-2012, 10:58 AM   #69
S-Nation S13
Trader Rating: (92)
Anyone..this is pissing me off..I'm pretty sure I have a clogged erg pipe into the exhaust mani..but and things else ?? Will sea foam reach that pipe ???
Old 01-20-2012, 04:27 PM   #70
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Exclamation
Try removing it i did & soaked it in gasoline or something strong and run a long wire brush through it thats what i did, Seafoam helps too but seafoam at your own risk
taken from another forum
Seafoam ( Pros and Cons) : General Chat
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 01-21-2012, 10:45 AM   #71
S-Nation S13
Trader Rating: (92)
Since my hc were off by 3 and only on low speed..is it safe to say that my ignition system is good enough..just a little more cleaning ...and since my co where hella low is it safe to say my cat is ok ??? Nox I know primarily has to deal with egr..so I'm assuming I have a clogged egr pipe..bc if my egr was to be completely broken my nox would be at a stupid level ..
Old 01-21-2012, 03:41 PM   #72
S-Nation S13
Trader Rating: (92)
http://240edge.com/manuals/91-94_240sx/ec.pdf
Dc-32
Page EF&EC 107
Any clues
Old 01-21-2012, 05:49 PM   #73
S-Nation S13
Trader Rating: (92)
Checked egr function there is a vacuum source, and the egr valve does move while at 2000 rpm and closes at idle...slapped a brand new o2 sensor just for the hell of it..my question is is it vital or should i just do it ..that I clean out the egr tube to the exhaust manifold?
Old 01-21-2012, 10:33 PM   #74
Thethrash
I just passed my emissions today. my problem was my egr wasn't on completely,clean your pipe with wd40 and your valve. I put 5 gallons of 91 oct. and alcohol set my timing all the way to lean. Passed flying colors. and my nox before was reading 3300.
Old 01-21-2012, 10:57 PM   #75
S-Nation S13
Trader Rating: (92)
How where you able to remove your egr ??? I'm trying to reach the metal tube to the exhaust manifold ??
Old 01-22-2012, 02:05 PM   #76
S-Nation S13
Trader Rating: (92)
Able to remove the egr with the egr tube today..my plan is to spray into the egr tube with carb cleaner..and into the holes they hook up to.. Can I spray into the egr as well ?? My egr is in working condition , that means the egr bpt and egr solenoid is working as well..so I'm thinking a good clean will lower my nox..
Any other tips or cleaning I should do please lemme know ..
Old 01-22-2012, 05:50 PM   #77
S-Nation S13
Trader Rating: (92)
All finished up ..brand new everything..lol gonna run some chevron cleaner and 91 octane..I'll keep you guys posted ..
Old 01-25-2012, 12:27 PM   #78
Thethrash
My no ppm was 3346 (15mph) and 2948 ppm (25mph)
i cleaned my egr valve and bpt, set timing all the way to lean.
91 oct + alcohol. made sure all the vacuum lines where sealed for the egr.
passed with 0008 ppm on (15mph) 0004 ppm (25mph).
Old 01-25-2012, 08:06 PM   #79
S-Nation S13
Trader Rating: (92)
I passed !!!
Shit so close though all numbers were 1 off the max allowed!!! Time for a new cat !!!
Old 04-22-2012, 12:43 AM   #80
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
So I just attempted this and FUCK THAT PLUG. Why the fuck is there an aluminum plug in an aluminum manifold? Now I have to drill it out and get a huge extractor in there and hope the threads survive. At least the plug is like $3 and Nissan still stocks it.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 07-03-2012, 02:01 PM   #81
kingkilburn
Philosopher King
Nox at 3000+ HC slightly high @15mph
Nox around 1200 HC fine @25mph
No cel. EGR works. Cat and o2 sensor replaced. Vacuum lines all new. Passage behind plug cleaned.
Old 07-03-2012, 04:09 PM   #82
niteridaz503
how long ago were the cat & O2 changed? did you heat up the cat nice & pipin hot as well?
Old 07-03-2012, 05:57 PM   #83
kingkilburn
Philosopher King
O2 last year. Cat about 4 months ago and it was hot.
Old 07-12-2012, 06:25 PM   #84
deadlydragon72
deadlydragon72 is an unknown quantity at this point
hey i know this is an old post but its exactly what need to try and i was hoping you might still have the pics and be able to reset them or just send them too me it would be much appreciated!!!!! thanks!
deadlydragon72 is offline   Reply With Quote
