Old 04-24-2012, 08:56 PM   #1
jarend
jarend's Avatar
jarend is an unknown quantity at this point
LOTSSS of S13 sr20det parts you need! *San Diego*
MORE PARTS COMING, STAY TUNED..
NOT DESPERATE TO SELL, BUT EVERYTHING MUST GO! MAKE OFFERS!!
Long story short. Had a friend of a friend do the machine shop work on my black top s13 sr20det, sleeved it for me and it was done wrong.
Here is a rough list of what was installed and never ran, some parts are used but all are in perfect working condition. All prices are picked up in San Diego. --
S13 Rear Upper Control Arm (No Name Brand) - $50
S13 sr20det Coil Pack Cover - $20
S13 sr20det HKS 1.2 mm Metal Head Gasket (Bolted on, never ran.) - $160
S13 sr20det Main Cap Girdle - $20
S13 sr20det OEM Rocker Arm (8) - $40
S13 sr20det Flex Plate - $30
Q45 Throttle Body in good condition - $80
300zx TT 260 LPH Fuel Pump (Walbro's are 255 LPH) - $70
Arias 87.5 mm Pistons very lightly used from previous owner. - $350
Phase 2 MotorTrend Rocker Arm Stoppers - $50
OEM S14 Water Pump Unused - $50
Altima Electric Fans - $40 *Pick Up Only*
S13 sr20det Stock Flywheel - $50
S13 sr20det Stock Clutch Fan *Crack on two of the fins* - $5
Mishimoto Black Front Mount Intercooler and piping complete with couplers, hardware, hotpipe and Greddy Knockoff BOV (COLD PIPE IS CUT TO FIT GREDDY STYLE INTAKE MANIFOLD) - $250 *Pick Up Only*
Set of four (4) Sportmax 006 wheels and tires for sale. The two rear wheels are 18" x 9.5" and the fronts are 18" x 8.5". The lug pattern is 4 x 100 AND 4 x 114.3. The rear wheels are wrapped in 275/35/18 Nankang Ultra Sport NS-II tires while the fronts are 245/40/18 with the same tires. Tires have ~3k miles. - $650 *Pick Up Only*
S13 Harness Bar, Easy Install and Mounts very well! - $160
Unused S13 sr20det ISIS downpipe - $80
S13 sr20det Unused ISIS Cast Top Mount Turbo Manifold - $120
S13 sr20det Oil Dip Stick and Dip Stick Tube Brand New from FRSport - $40
S13 sr20det Valve Cover Shaved down and painted a dark blue (could use a touch up) - $50
SOLD STUFF -
S13 sr20det Freddy Intake Manifold - SOLD
S13 sr20det Unused Timing Chain Kit - SOLD
S13 sr20det Coil Packs (4) - SOLD to datm3
S13 sr20det Transmission NO GRINDS SHIFTS PERFECTLY - SOLD to destruck
S13 sr20det Unorthodox Crank Pulley (Bolted on, never ran) - SOLD
S13 sr20det Crank Shaft - SOLD to roman21716
S13 sr20det Stock Alternator around 60k - 70k miles came off a running sr - SOLD
Synapse Synchronic BOV welded to s13 sr20det hotpipe - SOLD
S13 sr20det Power Steering Pump Bracket - SOLD
S13 sr20det OEM Power Steering Pulley - SOLD
300zx N62 MAF (Orange Sticker) - SOLD to greenwood
S13 Strut Bars Front and Rear - SOLD locally
S13 sr20det Stock MAF Sensor - SOLD to nissansilviasr20
OEM S13 sr20det Water Pump *Came off a running car, worked perfect* - SOLD to znismspeed
S13 sr20det Mishimoto Starter ~2k miles - SOLD
Sentra SER SPEC V GOLD Brembo's that are fully loaded with brand new rotors, nearly new pads and lines. This is a bolt on upgrade for S13 and S14. FULL FRONT BBK - SOLD to nismojunkball
S13 sr20det Unused Koyo Aluminum Radiator - SOLD to randps13
S13 240sx Apexi N1 32 Way Adjustable Coilovers ran for ~3k miles - SOLD to kauaiboy808
No Name Oil Catch Can Polished Silver - SOLD to znismspeed
S13 sr20det Unused Nismo Low Temp Thermostat - SOLD to outlawstar1023
HKS Step 2 Intake and Exhaust Camshafts - SOLD
HKS Adjustable Cam Gears - SOLD
S13 sr20det Crank Angle Sensor - SOLD
Pauter Rods lightly used from previous owner - SOLD to DriftNinjah
S13 sr20det Black Top Valve Cover - SOLD to bladetech8
Pics of everything I was able to get to.
Pictures by ohhfasho - Photobucket
LET ME KNOW IF YOU NEED ANY STOCK PARTS, HAVE A TON OF STUFF.
Call/Text me at 858 822 9613 for fastest response, I'm not on here as often as I used to be.
Can get pictures of whatever you are interested in.
-Thanks
Jaren D.
jarend is offline   Reply With Quote
